![]() | | #401 | ![]() |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score The Toyota seals blow easily, they are more of a temporary/emergency fix.
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| The Following User Says Thank You to Mauro_Penguin For This Useful Post: | Jaysspeeed3 (11-18-2016) |
![]() | | #402 | ![]() |
![]() Join Date: Aug 2016 Location: Gatineau Quebec
| Not Ranked : 0 score Great! Thanks for the info. I want to make a good build for My Mazda. Definitely want all the best and top quality Mods for it. Cheers. |
![]() | | #403 | ![]() |
![]() Join Date: Oct 2016 Location: St. Augustine, FL
| Not Ranked : 0 score I got the Toyota seals to see if replacing them will stop the popping/crackling noise I hear. I didn't want to spend big bucks on something I wasn't sure would fix the problem. My plan is to replace the seals with the cheap Toyota ones, and if it fixes the noise, then I'll upgrade them to the cork sport seals. |
![]() | | #404 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Mauro_Penguin (11-19-2016) |
![]() | | #405 | ![]() |
![]() Join Date: Jul 2013 Location: Spokane, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 94
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score I've been using Toyota seals for the 35k miles. Never had an issue.
__________________ 2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials. |
| Injector seals solution. Version A | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 756 | 05-23-2017 10:38 AM |
| Injector seals solution. Version B | paveltol | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 463 | 11-12-2016 09:30 AM |
| CPE or PTP Injector Seals? | Matrix311 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 13 | 11-26-2011 03:12 PM |
