| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
(Thread Starter) | Neutral : +1 score Matt, and I have a lot of history with the MS6, and a whole lot more love. I've been paying attention to the MS6 struggles here. It's taken too long, and this "check back in 4 weeks" nonsense to get a part machined puts it over the top. Long story short, I'm going to do try to solve this issue. Code, I might get in touch with you soon about test fitting for me.
__________________ |
| The Following 18 Users Say Thank You to Farhan@DM For This Useful Post: | batmsp3 (02-02-2016), Code Monkey (01-13-2016), Easter Bunny (01-14-2016), ESA (02-04-2016), Fonsi (01-13-2016), Hargarbl (01-13-2016), Mauro_Penguin (01-14-2016), Mazdazilla6 (01-14-2016), MD1032 (01-27-2016), Micha (01-17-2016), ms6mil (01-27-2016), nindoja (01-20-2016), PhillyCheese (01-13-2016), SamiChicago (02-02-2016), SofaKingAwesome (01-27-2016), speed23 (01-13-2016), Stryker125 (01-26-2016), WetzMS3 (01-14-2016) |
| Not Ranked : 0 score I just got the Treadstone fittings today, will stop by the shop tomorrow and do some test fitting to see which angle works, will report back.
| The Following 6 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (01-14-2016), ESA (02-04-2016), Farhan@DM (01-13-2016), Mazdazilla6 (01-14-2016), Poohster (01-14-2016), WetzMS3 (01-14-2016) |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Thanks for actually looking for a solution for us and to all those that have helped this cause! I'm looking to go BT sometime in the future (not anytime soon) and cannot express how awesome it is that a MSF vendor is stepping up to help. I just wanted to express my interest in this if it helps a solution come to market for the 6. If this is a one-off run item more like a group buy rather than a continuing item, please announce I will buy sooner than later to support this if needed.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score THANK-YOU!!! |
| The Following User Says Thank You to speed23 For This Useful Post: | Farhan@DM (01-14-2016) |
| Not Ranked : 0 score In for results! Drain line is one of the last things I need to buy for my swap. If this doesn't work out I've got something in mind (and my amazon wish list) that should work.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | WetzMS3 (01-14-2016) |
(Thread Starter) | Not Ranked : 0 score Need input from everyone actually needing this. Does this NEED to be adjustable/swivel? I'm not familiar with all the turbo options out there. Can one angle, assuming it's made to accept whatever fitting you need, work for everybody?
It will work out.
__________________ | |
| The Following 2 Users Say Thank You to Farhan@DM For This Useful Post: | Mazdazilla6 (01-14-2016), WetzMS3 (01-14-2016) |
![]() Join Date: Dec 2010 Location: Delanco, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 897
That's just one angle though. It still needs to come back towards the firewall as well. That is the best I can explain it. It's hard to actually understand quite what you're dealing with until you've had to fab a line on a 6 for yourself.
__________________ [SIGPIC][/SIGPIC] ROB MS6GT 2006 Liquid Platinum Metallic Mazdaspeed 6 Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows | |
| The Following User Says Thank You to rob ms6gt For This Useful Post: | Code Monkey (01-19-2016) |
| Not Ranked : 0 score IMO yes it should be adjustable/swivel because people who run top mount setups will need a different angle I believe. I was planning on using this fitting for the block side, it allows for adjustability
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Code Monkey (01-19-2016), SofaKingAwesome (01-27-2016) |
That fitting won't work. Too tall.
| The Following User Says Thank You to Farhan@DM For This Useful Post: | qtrmile beast (02-12-2016) |
I'm pretty sure it'll work, I've seen some people on FB use it with success. What do you think it is going to contact from being too tall?
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| Not Ranked : 0 score @Farhan@DM; check my update -- I am going to order another banjo fitting, if the threads are the same (they should be) I could mail you guys the useless banjo fitting so you can design a flange around it.
(Thread Starter) | Not Ranked : 0 score Won't need the banjo fitting.
| The Following 5 Users Say Thank You to Farhan@DM For This Useful Post: | Code Monkey (01-14-2016), maddocx240 (01-14-2016), Mazdazilla6 (01-14-2016), Omega (01-14-2016), SofaKingAwesome (01-27-2016) |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score I had a leaky turbo drain line on my car for the past two years since I got it back from SP63. It's leaked the entire time, at times from certain area's. Not sure if it works for every turbo but the below links worked together to build a non-leaky one for mine. 10AN Aluminum Turbo Oil Return Drain Flange Garrett GT25 GT28 GT30 Ball Bearing | eBay 10AN Push-On Hose End - 30 Degree- TREADSTONE PERFORMANCE Hi Temp Turbo Rubber Silicone Oil Drain Hose 5 8" 10 An Fast Shipping | eBay 200110BL Fragola 10AN Black Push Lock Straight Race Hose Ends | eBay Turbo Oil Return Drain Flange 38mm Garrett GT15 GT17 GT20 GT22 | eBay 999160 Fragola 10AN Push Lock Clamps Pair | eBay DEI 010419 HEAT SHEATH ALUMINIZED SLEEVING 1 | eBay
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
| The Following 4 Users Say Thank You to Jh8909 For This Useful Post: | Code Monkey (01-14-2016), Mazdazilla6 (01-14-2016), qtrmile beast (02-12-2016), rob ms6gt (01-14-2016) |
(Thread Starter) | Not Ranked : 0 score Teaser. Details tomorrow. Already anticipating round 2, and that should be all it takes.
| The Following 10 Users Say Thank You to Farhan@DM For This Useful Post: | Code Monkey (01-20-2016), DingoDave (01-25-2016), Easter Bunny (01-24-2016), ESA (02-04-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), neganox (01-20-2016), qtrmile beast (02-12-2016), rob ms6gt (01-21-2016), WetzMS3 (01-21-2016) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score and this is why you are awesome @Farhan@DM;. It's a shame I won't ever be pulling my drain line on the 6, otherwise I'd want one of these. Or maybe I should buy one in case I decided to go bigger turbo...
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | Farhan@DM (01-20-2016) |
| Not Ranked : 0 score In for drainage epicness! I've been holding off on getting a drain line to see how this pans out.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | qtrmile beast (02-12-2016) |
| Not Ranked : 0 score Make it 1.75" just in case..... Not sure if one can fit an Allen key on the lower bolt with the TC on but it is worth a shot.
| Not Ranked : 0 score Cut allen key shorter. Solved.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Code Monkey (01-20-2016) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Going for 1.72". Stay tuned for round 2. I'll contact you tomorrow.
| The Following 6 Users Say Thank You to Farhan@DM For This Useful Post: | Code Monkey (01-20-2016), Easter Bunny (01-24-2016), ESA (02-04-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), WetzMS3 (01-21-2016) |
![]() | | #20 | ![]() |
| The Following 6 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (01-24-2016), JSmith (01-26-2016), Mauro_Penguin (01-25-2016), qtrmile beast (02-12-2016), rob ms6gt (01-21-2016), WetzMS3 (01-21-2016) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Much love @Farhan@DM; this is definitely a great looking solution! Thank you guys for continuing to support the community when other vendors have given up.
| The Following User Says Thank You to Omega For This Useful Post: | Farhan@DM (01-21-2016) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score I still think the top of the flange (only around the fitting) should be a bit thicker than the bottom, about 10 percent thicker will give you a nice 5-degree angle which should be good enough for relieving some of the stress on the line and the flange.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (01-24-2016), rob ms6gt (01-23-2016) |
![]() | | #23 | ![]() |
![]() Join Date: Jan 2014 Location: Troy, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I'm interested if this goes into production
__________________ 08 MS3 DD (Sold) 06 Dodge Dakota, V6, 6 speed, 4x4 07 MS6 w/engine block VTA mod (currently going built block, etc) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Any update @Farhan@DM;? I'm itching to see how this turns out.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Farhan@DM (01-25-2016) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score 2 weeks.
![]() | | #26 | ![]() |
Round 2 has been designed, and is off for machining. It will not have the angle away from the block that some have requested. It would significantly increase the cost, and I don't think you need it. Don't you know better by now?
| The Following 4 Users Say Thank You to Farhan@DM For This Useful Post: |
![]() | | #27 | ![]() |
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Code Monkey (01-25-2016), SpeedRebirth (01-25-2016) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Well its been two weeks on those Mazda 5 caliper brackets Plus all vendors are to treated with equal disdain......
![]() | | #29 | ![]() |
Can't comment on price, yet. The fitting will probably cost more than the flange, to be honest. Fair point. ...I never signed up for the caliper brackets.
| The Following 5 Users Say Thank You to Farhan@DM For This Useful Post: | Easter Bunny (01-25-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-25-2016), Micha (01-29-2016), rob ms6gt (01-25-2016) |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score ORB swivel fittings get longer as they are rotated/swivel. Sizes are min, and max you might see with a new stock gasket. It does not tilt out, as that would be expensive, and, I think, unnecessary. It requires a specific XRP fitting. Cheapest I've seen it is $55. The captive washer on the fitting needs to be reduced in diameter; I did it with a dremel in 5 minutes. I'll likely send this to @Code Monkey; to get his nod. Then we'll let @Matt@DamondMotorsports; take care of you guys.
__________________ Last edited by Farhan@DM; 01-27-2016 at 06:22 AM. |
| The Following 8 Users Say Thank You to Farhan@DM For This Useful Post: | ItsNox (01-29-2016), Mauro_Penguin (01-27-2016), Mazdazilla6 (01-26-2016), Micha (01-29-2016), ms6mil (01-26-2016), qtrmile beast (02-12-2016), rob ms6gt (01-27-2016), WetzMS3 (01-27-2016) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Looks pretty sweet! Do you have a picture of the block side of the flange? Just wondering how big the hole opening is and how much material is left on the edges. The XRP fitting you speak of is, I assume, an XRP push-on hose end, page 11 of this catalog? If so, it is possible that a 30-degree or a 60-degree end could work (assuming they swivel).
![]() | | #32 | ![]() |
| The Following 7 Users Say Thank You to Farhan@DM For This Useful Post: | Code Monkey (01-26-2016), Easter Bunny (01-27-2016), ItsNox (01-29-2016), Mauro_Penguin (01-27-2016), Micha (01-29-2016), rob ms6gt (01-27-2016), WetzMS3 (01-27-2016) |
![]() | | #33 | ![]() |
![]() Join Date: Jan 2015 Location: Snohomish, WA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score Perfect timing! I was planning on using the oem return in the next month or so when my gtx3071 goes it. Sounds like this may make my life easier!
__________________ -2006 Speed6- PTE5862 Tial 44mm ewg Cpe exhaust mani, Relentless PnP Intake mani Fmic w/ tr8 +All the things Tuned by: Will Dawson @Purple Drank |
![]() | | #34 | ![]() |
| Not Ranked : 0 score @Farhan@DM; Looks awesome! So the flange uses ORB threads? I'm not familiar with that thread type. Why was that chosen over NPT or AN? Edit: Are you using the part # 989110?
![]() | | #35 | ![]() |
ORB/o-ring port/SAE straight thread/SAE J514 o-ring fittings are all the same. The thread is the same as the AN/JIC 37 fittings you see everywhere, just that there is an o-ring port machined in. Code Monkey's banjo fitting is an ORB. Not an AN fitting because they're a metal-metal seal. They go loose with the smallest bit of rotation. I think that's a bad idea when your hose might actually be rotating the fitting out. They also give you a smaller opening for a fitting size. The XRP 989110 is a JIC37 on the other end, but you'll see it opens up at the angle. Not NPT because I've seen too many leaks at this interface. The fitting would be cheaper with NPT, but may also leak a month later.
| The Following 6 Users Say Thank You to Farhan@DM For This Useful Post: | Easter Bunny (01-27-2016), Mauro_Penguin (01-27-2016), Mazdazilla6 (01-27-2016), Micha (01-29-2016), torquemaniac (01-28-2016), WetzMS3 (01-27-2016) |
![]() | | #36 | ![]() |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 2310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,516
| Not Ranked : 0 score Interested in at least 2 of these.
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars |
| The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post: | Easter Bunny (01-27-2016), Farhan@DM (01-27-2016) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Farhan, is there anyway Matt would be able to include the fitting with the flange to help on price a bit or is it too low run of a part where that's not possible?
![]() | | #38 | ![]() |
| Not Ranked : 0 score I still do not know which fitting it is, @Farhan@DM; do you have the part number?
![]() | | #39 | ![]() |
| The Following User Says Thank You to Farhan@DM For This Useful Post: | Micha (01-29-2016) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Sorry, I meant the push-lock that bolts onto the fitting, thanks.
| MS6 -- possible oil drain line solution? | Code Monkey | Mazdaspeed3/6 General Discussion | 15 | 01-29-2015 07:50 PM |
| bt oil drain line for MS6 | ryein7 | MazdaSpeed 3/6 - Turbo Induction | 17 | 03-14-2012 10:42 AM |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
