![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score Hello everyone! So here is a new tip for all those who face the problem of blown OEM injector seals and don't want to spend hundreds of dollars on OEM or some reinforced seals, there's a solution: The Toyota diesel injector seals. These seals come for every diesel Toyota engine and are proven to be of good quality. These seals have been tested for more than a year on a number of modified Mazda 2.3 DISI Turbo engines, with different power level (from stock to 400hp) running on awful Russian fuel. None of the seals failed so far. Installation does not require any machining or trimming. They fit perfectly. Now, the price. It is USD 7.8 per kit. USD 1.9 each. P/N: 11177-64010 Enjoy. UPDATE: See the pic attached. There is a comparison of OEM Mazda seals (left) and Toyota diesel seals (right). Mazda seals have rubber-like coating, Toyota seals do look like they are made of brass alloy. Surely they do not look as beefy as CP-E seals, but they are proven to be working on a number of modified cars. Two of them are 370hp and 405hp. Different alloys have different properties and as you know diesel engines have extreme pressure spikes in the cam. Still it would actually be useful to find out the limit of these seals' tolerance on Mazda DISI engines.
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
| The Following 2 Users Say Thank You to paveltol For This Useful Post: | seshomaru7 (04-05-2013), unokevin1 (11-18-2016) |
| Injector seals solution. Version A | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 756 | 05-23-2017 10:38 AM |
| Injector seals solution. Version B | paveltol | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 463 | 11-12-2016 09:30 AM |
| CPE or PTP Injector Seals? | Matrix311 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 13 | 11-26-2011 03:12 PM |
