![]() | | #161 | ![]() |
![]() Join Date: Aug 2010 Location: Honolulu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groans: 54
Groaned at 42 Times in 32 Posts
![]() | | #162 | ![]() |
Groans: 54
| Not Ranked : 0 score Well.. Results are in the KMD internals seem to be doing the job. Pump holds well above 1700 PSI throughout the entire band now. Hits 1900 PSI from time to time as well. This upgraded pump seems to be a bit more noisy then the stock one.. But I would assume that is due to the increased size of the internals. Thanks for the help Joe. |
![]() | | #163 | ![]() |
![]() Join Date: Nov 2010 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score I have the hands of a Giant! I am certainly going to try and avoid removing bat. box and intake, but it really doesn't take more than 10 mins or so after you've done it a few times.
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... |
![]() | | #164 | ![]() |
![]() Join Date: Jan 2010 Location: Lake Villa, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,503
| Not Ranked : 0 score The guy who installed my internals pulled the pump in about 10 mins and just removed the lines and IC cover. No battery or intake was hurt during the installation of these internals.
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq |
![]() | | #165 | ![]() |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score So using the ultragauge i checked my fuel pressure and it never dropped below 1650 during wot, saw it get up to 1700. I figure it has to be right cause it is hooked in to the obd II thing. not bad for the mods I have I guess
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() | | #166 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score The problem is that it may be dipping so fast you don't see it on the gauge. Unless that gauge can data log too. If you see other peoples logs, it will dip for a second and then be right on target. |
![]() | | #167 | ![]() |
Groans: 266
| Not Ranked : 0 score I see hmmm, well i have ordered the KMD internals anyways. Have to wait two fucken weeks aleast for them.
![]() | | #168 | ![]() |
Groans: 386
| Not Ranked : 0 score "The Great Fuel Pump Shortage of 2011" strikes again just as well for me, can't afford one now anyway... |
![]() | | #169 | ![]() |
![]() | | #170 | ![]() |
![]() Join Date: May 2010 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,737
| Not Ranked : 0 score Dont feel like reading 5-6 pages... can someone link info on KDM internals in the OP or maybe make a new sticky since its going to be one of the biggest topics in the GenPu forum. |
![]() | | #171 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score Well, God forbid you read a thread in it's entirety. I'm just fuckin with ya. I know that you already got the link that you were looking for on the Cobb AP thread.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
![]() | | #172 | ![]() |
| Not Ranked : 0 score Whats with the No thanks Wolly... you dont think that it might be benificial for a GenPu forum to have a sticky about the most important tuning information (Fuel pump) for the plateform. I sure think so, someone should make it eazy for us to figure out what to buy / where to buy / and how to install. |
![]() | | #173 | ![]() |
Groans: 386
| Not Ranked : 0 score Nata was in a good mood and used sarcasm... I just groaned, didn't feel like typing out a response. The info is everywhere, just search. Also, what makes you so much better than everyone else that you don't have to read? Especially on such an important topic, you will learn much more from reading through some threads on your own than just getting a readers digest version from someone who may be mis-interpreting things. |
![]() | | #174 | ![]() |
| Not Ranked : 0 score i was at work. Sorry, either way i got my link from someone |
![]() | | #175 | ![]() |
Groans: 386
| Not Ranked : 0 score If you are at work then you should be reading everything! What better way to pass some time? What do you think I do all night at work? lol |
![]() | | #176 | ![]() |
| Not Ranked : 0 score Noboy knows how to use Google/Yahoo to search for shit on the internet??? Reading is fundamental...
![]() | | #177 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score lol at faggots not wanting to read theres a wealth of information here. soak it in.
__________________ |
![]() | | #178 | ![]() |
![]() Join Date: Dec 2010 Location: Pompano Beach,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Im skimming through most of the last 2 pages, I did read the first 3 entirely but what I'm looking for in info - not about the pump, it has obviously been well explained and I thank you all for that - But not too much info has been covered about what can monitor the Fuel pressure's for sure. I read questions but not to many answeres. Im looking at both the Dashdaq and the ultragauge. I look at there paramiters and nothing say the that it monitors specifically the HPFP but they are along to lines, saying fuel pressure absolute blah blah. But does anyone know for sure which one of these does monitor the HPFP's pressure? I dont wanna buy then say shit, I dont see it. The dashhawk is just so small of a screen IMO like and old school Apexi S-AFC. |
![]() | | #179 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I would recommend getting a Cobb Accessport. It logs, tunes, clears CELs, etc., etc. The gen 2 software hasn't come out yet. PM me for info.
![]() | | #180 | ![]() |
| Not Ranked : 0 score Thats not really what I was asking for . I'm pretty interested in the Ultragauge since they have it onsale for 60$ UltraGauge Automotive Information Center and OBDII Scan Tool Does anyone at all know for sure that this monitors the high pressure fuel pressure? |
![]() | | #181 | ![]() |
Groans: 266
example
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. | |
![]() | | #182 | ![]() |
| Banned ![]() Join Date: Feb 2010 Location: Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 500
Groans: 132
Groaned at 166 Times in 92 Posts
![]() | | #183 | ![]() |
Groans: 266
| Not Ranked : 0 score Looks nice but i dont have a droid
![]() | | #184 | ![]() |
![]() Join Date: Feb 2011 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score @MS33SM sounds interesting. Where can i get the Mazdaspeed PID´s? Just ordered an EM327 OBDII Bluetooth Modul from Ebay :-) |
![]() | | #185 | ![]() |
Groans: 132
![]() | | #186 | ![]() |
![]() Join Date: Jul 2010 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score waiting on my parts to upgrade as well
__________________ 2010 Mazdaspeed 3 |
![]() | | #187 | ![]() |
| Not Ranked : 0 score i have just about all of the how to's subscribed to, but remember someone recommending a particular tool for the hpfp install... can someone remember off of the top of their head the tool recommended (besides a crowsfoot) for the 19mm nut on the bottom of the pump? |
![]() | | #188 | ![]() |
Groans: 819
| Not Ranked : 0 score The nut on the bottom requires an open ended wrench...and adjustable will not fit The pump itself is held in by 3 E8 inverted (female) torx bolts. I recommend using an extension to get in there. Thats basically it. And be prepared to get sprayed in the face with gasoline...its lots of fun
![]() | | #189 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score The stock fuel pump = bad aftermarket fuel pump = good |
![]() | | #190 | ![]() |
Groans: 132
![]() | | #191 | ![]() |
| Not Ranked : 0 score we need a fuel pump god to appear and solve the shortage problem. that is all.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #192 | ![]() |
i'll be sure to wear some goggles. THANKS AGAIN. | |
![]() | | #193 | ![]() |
Rep Power: 0 ![]() ![]() Thanks: 6
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score I installed a hks cat back exhaust on my 2011 mazda3 and ordered a cobb sri. My queston is that putting my car in danger in anyway? Bare with me i amthe first to admit i am a total noob to this lol |
![]() | | #194 | ![]() |
| Not Ranked : 0 score Read the entire post. You are not going to get any love here if you do not read. Actually, just read the title of this post and you will get your answer. Gen 2 is like a box of chocolates...
![]() | | #195 | ![]() |
![]() Join Date: Feb 2011 Location: Princeton, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,469
Groaned at 61 Times in 40 Posts
| Not Ranked : 0 score I just bought a 2010 ms3 used of course with 13k miles on it. To my knowledge the car only has a cobb sf intake but I haven't been able to get under it for a better look. Anyway I was drivin up an onramp the other day and was in 3rd gear very close to WOT and had a very short but very abrupt cut in power then a second later the it spooled back up and was running fine. I drove it hard the past couple days trying to duplicae the issue but haven't so far. Talked to a friend and he said that it sounded like a fuel cut. Im not completely sure what it was but I would appreciate suggestions for data logging systems or software! |
![]() | | #196 | ![]() |
Groans: 386
| Not Ranked : 0 score AccessPort. |
![]() | | #197 | ![]() |
Groans: 132
Sounds like you bought a previously raped car. | |
![]() | | #198 | ![]() |
Actually i traded a 2004 rx8 with 80k miles and no warranty on a 2010 ms3 with 13k miles and an extended warranty. You may ask why i made such a purchase? i returned from a year deployment in november and found out that verizon is fucking stupid and does not know how to freeze an account so they sent my bill to a collection agency in march and reported bad on my credit until nov when i got it tooken care of....i have bad credit so i got what i could and thankfully it was a ms3. THE CAR MIGHT HAVE BEEN RAPED PREVIOUSLY BUT NOTHING A WARRANTY WONT FIX ![]() Honestly its better than a focus or carolla.....my other options if i didnt get the ms3. It was also inspected and driven plenty before i purchased the vehicle. unsure of the mods cause i have never had a turbo car and dont have a lift to check it out. looks pretty much stock except for intake under the hood. | |
![]() | | #199 | ![]() |
![]() | | #200 | ![]() |
| Not Ranked : 0 score seems like the access port is the way to go! Thx....just have to wait on taxes now |
| 2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely | Nataphen | 2010 MS3 - Fuel, Nitrous & Water Injection | 508 | 07-06-2013 11:44 AM |
| Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 | whitewater | 2010 MS3 - Fuel, Nitrous & Water Injection | 6 | 05-24-2012 02:43 AM |
| recommend me a fuel pump (08ms3) | blue_train | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 01-05-2012 03:09 PM |
| If Fuel Pumps are necessary, why no TSB? | Silver Ecstasy | 2010 MS3 - Fuel, Nitrous & Water Injection | 52 | 09-07-2011 07:19 PM |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
