![]() | | #121 | ![]() |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
| Not Ranked : 0 score
__________________ I used to drive a MazdaSPED 3. It was retarded fast. |
![]() | | #122 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score I'm going to give the PTP big bore internals a try. I will be monitoring it very closely, and I'll let you guys know how things go. I'm also going to try an e85 tune and I'll keep you all updated on that as well. I know that PTP doesn't have a good rep for several good reasons, but I don't see why I can't try and see how it goes for you guys. Looks like I'll be the guinea pig again, but it's for the development of this platform. Hopefully, I won't be taking a bullet on the e85 and/or the pump tests, LOL. Stay tuned.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
![]() | | #123 | ![]() |
![]() Join Date: Aug 2010 Location: Honolulu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groans: 54
Groaned at 42 Times in 32 Posts
![]() | | #124 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score Why Nagga, WHY? Don't try the brand with the worst name in the business. If you could call them one, last I heard, they don't have a business license even. They cost $100 more than KMD. Before you do this, talk to gigs and triple.
__________________ |
![]() | | #125 | ![]() |
![]() Join Date: Apr 2010 Location: Temple, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 317
Groans: 42
Groaned at 53 Times in 14 Posts
I agree with Joe, failures on the internals are most likely due to user error on the installation. I'd be willing to bet a good portion of the failures are from someone setting the damn thing down on a dirty work bench while they put it together, or from doing it in your driveway and letting wind & dust get inside the hole while the pump is off the engine. Even the how-to posted in the Gen 1 section is wrong. It says to soak the internals in a can of gasoline while you are working on them. DONT DO THAT! lol. One of the mods needs to fix that post. If your not mechanically inclined, get the CP-e pump and don't worry about it. If you got some common sense and are used to working on cars a bit, the internals are not that hard to install.
__________________ Sold: 2010 MS3 - I'll miss ya Now: 2013 Mustang GT | |
![]() | | #126 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2009
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
![]() | | #127 | ![]() |
![]() Join Date: Nov 2010 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
Groaned at 10 Times in 3 Posts
__________________ Black Mica 2010 Speed3; Xcel Nano SRI; JBarone short shifter, bushings, shift knob and rear sway bar; Corksport RMM inserts; Ptp HPFP internals; Cobb AP; Corksport TMIC; Denzo ITV22; CP-e CDP; Tuned by Ptuning | ||
![]() | | #128 | ![]() |
Groans: 214
| Not Ranked : 0 score Ok, I understand that PTP is the only one with support for e85 at this time, still, I would use caution.
![]() | | #129 | ![]() |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
It's unfortunate that all the faulty internals have been sent back already because you can tell that the material was the common problem among all the bad kits.
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! | |
![]() | | #130 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I am using caution, and I'm not recommending that ANYONE do what I'm planning to do. I am using the PTP big bore to support the increased volume for e85. Like you said, Ama, it's the only one out there that would be able to do it right now. If CPE had a big bore pump, I'd use it. My recommendations from the OP aren't changing due to this little experiment, but sometimes, you have to take risks to push the platform. I think that running e85 in this car may be able to take it to the next level so that we can unlock some power. Then again, it may all go down in flames. I will be datalogging 100% of the time for a good long time, probably a whole year, so I can see all different temps and weather. You guys just sit back and watch the show, we'll know if this is worth a damn after a little real world R&D. Joe, do you think that any other parts of the fuel system will need an upgrade for this? I don't want to blow if I can help it, pretty sure that that's a given. Are you sure that the other components of the system will support this volume? Mchart mentioned possibly needing a higher volume in tank pump for example.
![]() | | #131 | ![]() |
Groans: 214
| Not Ranked : 0 score Will there be fireworks? hehe
![]() | | #132 | ![]() |
Blanco, yes your right, it was a small sample, but like I said, it was done for our own information, and btw out of my pocket, so if the info is not useful to ya, I'm sorry. Its not meant to be end all be all for pumps, just information if you can use it. For what its worth, we are going to run PTP in one of the race cars, and KMD in the other, and see what happens. Both cars have Aim MXL data dashes, so everything gets logged............ | |
![]() | | #133 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score God I hope not. BBQ at my place if there are though...or wherever I breakdown.
![]() | | #134 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Aw, Amy and Mono, you don't like me for what I've said I see. I still say that nobody else should try this, I'm not telling anyone to go out and buy PTP products. I still recommend ONLY CPE pumps and KMD internals to everyone else. The only reason I'm doing this is for the e85 fueling support, I'm just as worried about the pump as anyone else.
![]() | | #135 | ![]() |
![]() Join Date: Nov 2010 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Can someone elaborate on e85. Is this a different kind of pump??? Searching using "e85" is unsuccessful... Fuck never mind, I just found info on google. This is an ethanol fuel type? For what its worth, I spoke with CP-E yesterday and the lady I spoke with said they should be about 1 week out for the next batch of pumps. I am planning on ordering a CP-E pump and KMD internals kit and keeping my core for a spare!
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... |
![]() | | #136 | ![]() |
| Not Ranked : 0 score Eric, not different really just larger bore, so more fuel per stoke of the pump. More volume = less chance of using more fuel than the pump can supply. Thats the real issue with the stock Hitatchi pump, its right at the limit on delivery volume for the stock cars. Run out of volume= drop in pressure= bad |
![]() | | #137 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Yes, it is 70%-85% ethanol. If the fuel system will handle 100% e85, you can basically run a 110+ octane tune all the time, and the fuel only costs $2.50 a gallon rather than race gas prices. I am told that it's a good idea to fill up with premium about every fourth tank because of the decrease in lubricant from e85. This, in theory, keeps things from getting overly dried out.
![]() | | #138 | ![]() |
| Not Ranked : 0 score on this note (pumps) has anyone heard from Gerry @ AR designs? i.e. i was on the list for a pump since mid December. |
![]() | | #139 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Still on BO last I heard from him, rfinkle.
![]() | | #140 | ![]() |
Groans: 42
Maybe he cut corners with the materials he was using, maybe he had problems with storage / transit... I dunno. Where PTP really failed on this forum was with his customer service and business ethics. Maybe he did take a shortcut somewhere, but we'll never know.
![]() | | #141 | ![]() |
![]() | | #142 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I wasn't on the list, but I talk with him from time to time. 2-3 weeks was what he said earlier this week. drenkel, senor, simmer down. I do not recommend doing business with PTP, I'm using that pump out of necessity for this project. Don't think for a second that I'm going to start telling people to buy them.
![]() | | #143 | ![]() |
Groans: 42
![]() | | #144 | ![]() |
![]() | | #145 | ![]() |
Groans: 214
__________________ | |
![]() | | #146 | ![]() |
i wish i had e85 in my area (south jersey). There were a number of people in the evo crowd running it and they picked up BIG power. AND... your tailpipe stays squeaky clean. | |
![]() | | #147 | ![]() |
| Not Ranked : 0 score AR over extended himself because he is just drop shipping from CP-E. Only CP-E knows how many pumps are available at any given time unless AR actually buys some inventory up front and manages it himself.
![]() | | #148 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Exactly why I want to give it a shot. I'm just not totally sure that our MZR DI system will hold up to it. I'm getting everything set up with Joe right now, we're going to start small and see where/when problems arise. If I monitor constantly, I can always just switch back to 93 octane if it doesn't work out. |
![]() | | #149 | ![]() |
FWIW, everyone was scared of e85 on the evo until a few tuners and drivers took the plunge. Now, if it is available in the area, it is pretty much a staple for those looking for custom tuning. BTW... the guy who tuned my car (super competent) owned an evo himself which was tuned on e85. after a solid year of running it, he took apart everything that was said to be @ risk for deterioration, and not only did everything look fine, it was clean too. depending on if you still have q's or not, there is alot of good info on e85 on evolutionm.net and the forum is actually quite friendly. | |
![]() | | #150 | ![]() |
![]() Join Date: Nov 2009 Location: Lacey, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,314
Groans: 48
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score From what ive heard regarding the KMD's failing, it was installation fail.. my KMD's have been running on my car for about 9k miles with full intake, ets tmic, and dp/rp.. currently running AP as well in 20-40 deg FL weather without issue.. gettin PSI as high as 2000.. these same internals were on aaronc7's car for 40-50k miles and ran hard with no issue.. so there's another testimonial for KMDs on a genpu (not that it matters which gen, but im sure to some folks it does).. and not all stock pumps are made equal.. like some others that have posted here, my stock pump was holding up quite well with sri/tip, dp/rp, stock tmic.. holding 1650+ during WOT operation.. but i couldnt pass up aaron's deal when he parted out (lol ama).. and if you havent modded your car yet , or are slightly modded and are looking for a way to monitor.. borrow someones DH and check your DI Pressure.. if its holding fine then wait for the AP , which will monitor/log/tune all in one package.. its the best $330 (lol x2 ama) ive spent so far on the car..
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT |
![]() | | #151 | ![]() |
Groans: 214
| Not Ranked : 0 score FFFUUU That was totally uncalled for faggot
![]() | | #152 | ![]() |
![]() | | #153 | ![]() |
| Not Ranked : 0 score Years ago, I worked at a Mazda dealership in the parts department. Called up my buddy that is still there and retail on a new HPFP is 484.89. My cost is 310.00. Kinda makes you wonder why CP-E is valuing these cores at $375.00...
![]() | | #154 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
They upgrade the cores they get back. So if you don't send yours back, someone else will have to wait even longer to get theirs. Plus, if you can get it for $310 from your parts guy, you are losing $$! | |
![]() | | #155 | ![]() |
Wow, now I really feel guilty. Give me a break
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... | |
![]() | | #156 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Nate, I'm really excited to see your results running e85. $2.50 a gallon 110 octane > $3.3x a gallon 93 octane Even if you get a few less mpg's it's well worth it IMO. Between this and driver311's thread about e85, I'm excited to see what e85 can do for the ms3. |
![]() | | #157 | ![]() |
Groans: 54
| Not Ranked : 0 score Upgraded my pump today.. To tired to go out and drive and see if it holds or not. Install was mostly painless besides that nearly impossible to access 19mm nut on the underside. Just enough free space between all the lines to be able to turn a short stubby little wrench. |
![]() | | #158 | ![]() |
Thanks
![]() | | #159 | ![]() |
Groans: 54
However, if you have a stubby little 19mm wrench you should be able to have just enough room in the space between all the lines back there to break the nut loose and tighten it. The nut only needs half a turn either way to lock it in place, or break it loose enough to remove it by hand. Or, if you are smart, just buy a 19mm crowsfoot. Really easy to loosen/tighten that nut then. In fact, i'd say anyone doing the pump install should make sure they buy one because it would make the install a hell of a lot faster compared to removing all that shit, or fumbling around with a stubby wrench. | |
![]() | | #160 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score battery removal is not necessary in the least
| 2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely | Nataphen | 2010 MS3 - Fuel, Nitrous & Water Injection | 508 | 07-06-2013 11:44 AM |
| Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 | whitewater | 2010 MS3 - Fuel, Nitrous & Water Injection | 6 | 05-24-2012 02:43 AM |
| recommend me a fuel pump (08ms3) | blue_train | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 01-05-2012 03:09 PM |
| If Fuel Pumps are necessary, why no TSB? | Silver Ecstasy | 2010 MS3 - Fuel, Nitrous & Water Injection | 52 | 09-07-2011 07:19 PM |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
