> Cobb Tuning >
Cobb Access Port/Maps
Like Tree5Likes
  • 1 Post By atvfreek
  • 2 Post By atvfreek
  • 1 Post By 802MS3
 Old 01-13-2014, 06:10 AM   #1
atvfreek's Avatar
Posts: 7,787   (View Stats)
Default V3 won't connect to AP manager
This damn thing refuses to connect to either of my computers. When I first got it, it would act up, but by switching the cable to different USB ports it would eventually connect. Now it won't do anything. About to send this thing back and go back to a v2 AP.
Any suggestions?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
2.0t03speed (01-13-2014), rfinkle2 (01-13-2014)
 Old 01-13-2014, 06:37 AM   #2
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
odds are if it's doing it on more then one computer it's a problem with the ap itself =/. you can try uninstalling ap manager and the associated drivers for the ap then reinstalling, but i don't know if it would help in this situation.
atvfreek (01-13-2014)
 Old 01-13-2014, 07:14 AM   #3
atvfreek's Avatar
After reinstalling everything, it still didn't work. Looks like I had a bad cable. I grabbed another cable from a cell phone and it connects right up.
kritz likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
himurax13 (02-17-2014), rfinkle2 (01-13-2014)
 Old 01-13-2014, 07:23 AM   #4
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Hitting the BL's early homie?
Kidding, yea USB wires cost $0.01 to make in China..so they cut every damn corner possible. The wiring comes apart, makes for a bad connection and eventually no connection.
Sucks, but glad you got it sorted.
Easter Bunny (01-13-2014)
 Old 01-13-2014, 07:46 AM   #5
atvfreek's Avatar
I was about to start hitting them. Frustrating as hell at 7am. lol
I would have thought my brand new cable that came with the AP would have been ok. Apparently not.
rfinkle2 and kritz like this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-13-2014, 07:30 AM   #6
ahh from the op i thought you already tried swapping cables. glad its working again =D
 Old 01-13-2014, 07:20 AM   #7
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Yes, very sensitive to cables.
Nator is what it does.
 Old 01-13-2014, 06:58 PM   #8
@atvfreek; I've heard that if you have a troublesome cable, Cobb will hook you up with a new one if you send in the old one.
 Old 01-13-2014, 07:09 PM   #9
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
hit up @rfinkle2; for some usb cables. hes got the good shit.
'08 CWP MS3 w/ T3 3071r
atvfreek (01-13-2014), rfinkle2 (01-13-2014)
 Old 01-13-2014, 08:30 PM   #10
lilred's Avatar
Posts: 5,792   (View Stats)
Is there anything he doesn't have!
Also I've had Good luck with cables from monoprice.com, helps I work around the corner and just pick up though.
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 02-17-2014, 12:48 AM   #11
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
tapafuck
Did you get a V3? I thought you were poor
Pickles Tune in progress
lilred (02-17-2014)
 Old 01-13-2014, 07:39 PM   #12
kritz's Avatar
Groans: 95
Light a small fire under the ap
Sent from fastest Ko4 Pu.
The Following 2 Users Say Thank You to kritz For This Useful Post:
 Old 02-17-2014, 02:10 AM   #13
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
How are you going to mount it
Gen 1 or pu?
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
 Old 11-09-2014, 11:58 AM   #14
MS6_life's Avatar
Posts: 6   (View Stats)
MS6_life is an unknown quantity at this point
Default Similar issue with V2
I am having a similar issue with my V2 accessport. When I plug it in to install it into my car it refuses to communicate with my ECU. After reading, I found that the 1st gen mazdas have issues with their ports and that it is easy for the prongs to get moved around.
The more bizzare part is this.. if I hold it into place for the 30 mins it will load all the way to 100% and then fail after that. Has anyone else had this issue? All I want to do is run that stage 1!!
2007 Mazdaspeed 6
MS6_life is offline   Reply With Quote
AP Manager 11MZR Gen2 MS3 General Discussion 20 11-07-2012 09:41 PM
AP manager USB 3.0 Jonny Quest MazdaSpeed 3/6 - ECU Computer Tuning 0 01-24-2012 08:58 PM
new AP manager 2.0 problems with x64 bit superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 12-02-2010 06:21 AM
AP Manager help seanmiller09 MazdaSpeed 3/6 - ECU Computer Tuning 4 07-07-2010 08:31 PM
AP manager help boyer MazdaSpeed 3/6 - ECU Computer Tuning 5 01-20-2010 09:33 AM
Page generated in 0.35653 seconds with 29 queries
