> Cobb Tuning >
Cobb Access Port/Maps
 Old 06-02-2019, 07:17 PM   #1
CA_MS3's Avatar
Posts: 22   (View Stats)
CA_MS3 has a spectacular aura aboutCA_MS3 has a spectacular aura about
Default Stage 0 (Emulation of Stock) Map Stronger than Stage 1?
I installed an Accessport v3 on my 2011 Mazdaspeed 3 last weekend. The car has 65k miles, has been well-maintained, and is in essentially stock configuration. The only engine modification is a Cobb cat-back exhaust. I loaded the Stage 1 map and was shocked to find a substantial reduction in mid-range torque, from roughly 2700 to 4500rpm. It almost felt like a safe mode, but no trouble codes were thrown. I drove it for a week like this, figuring the ECU might “learn” and improve, but it did not. Loading the Stage 0 map yesterday brought back the power and seemed to resolve the issue.
Does this seem like a normal response for a stock car?
Has anyone else experienced something like this?
CA_MS3 is offline   Reply With Quote
 Old 06-02-2019, 07:47 PM   #2
Police - Grammarhead
Vansquish's Avatar
Yes. Cobb's off-the-shelf maps are atrocious, neutered, and calibrated to try and be "safe" on any car to which they're installed. You need a tune customized for your modifications by a professional tuner.
CA_MS3 (06-02-2019)
 Old 06-02-2019, 11:24 PM   #3
CA_MS3's Avatar
Thanks, I appreciate the feedback.
 Old 06-03-2019, 07:19 AM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
you may datalog both tune and compare data to see what is going on. You may post it here and we will take a look...
As stated above these tunes are not the best but did you make sure you got the proper one based on what is listed from Cobb website?
I don't know all details about them but if you flash a tune made for a slightly larger intake and still have the oem, it may read higher load values and choke your car power a bit....
Back in time, i remember the biggest change i did notice with stage 1 was removing the boost limit of first and second gears without much feeling of power gains but it was 10 years ago lol.....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Stage 1, Stage 2, and Stage 3 Dual OCC kits Matt@DamondMotorsports Damond Motorsports 0 11-10-2015 04:09 PM
Stock using - Stage 0 vs. Stage 1 vs. Stage 2 BAT-man MazdaSpeed 3/6 - ECU Computer Tuning 30 12-20-2012 08:51 AM
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.26167 seconds with 22 queries
