![]() Join Date: Apr 2010 Location: Oakton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 521
Groans: 39
(Thread Starter) | Not Ranked : 0 score Updated: Some one suggested that I should try the "Stage2+K&NSRI_91 BT-Safe Mode Map" with my mods... Gave it a go and here are my logs... Which map should I be running when comparing logs from the ones posted? FP looks good to me on both... KR, LTFT, and STFT looks good on both too... Or are they bad?? Can I safely run the Stage1 map? Im pretty sure Im making bigger power on that since my calc load and MAF voltage was higher on those logs + boost ================================================== ================================================== ========= Hey guys, Im running the "Stage1+KNSRI 93 v100D BT" map for my 2010 speed. The only other flow mod I have on my car is a test pipe. I heard that I may need to recalibrate my MAF but I don't know what to look for in that section (i don't know what is good). Also, I noticed that my wgdc is maxing out at 100% at times... Should I be running a "Stage2+KNSRI 91 v100D BT Safe Mode", which I believe will lower my wgdc but throw some other parameters off (if so what kind... what should I look for if I do end up testing this map out) All these logs where completed after driving 28 miles and a few key cycles.
__________________ 2010 Liquid Silver MS3 // BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray // // JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers // // 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's // Last edited by ChimmyChong; 03-24-2011 at 10:59 PM. |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score The two I looked at looked pretty good. Considering get a fp soon though. |
Groans: 39
(Thread Starter) | Not Ranked : 0 score Updated OP... Can you guys compare my different map logs?!?!?!?!?
__________________ 2010 Liquid Silver MS3 // BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray // // JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers // // 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's // |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score Stage2 safe mode is for the stock fp. Your pressure is holding up fine, but I'm sure it will tell you to fuck off if you ask much more of it.
__________________ |
| Stage1+SF+TIH+CDFP 93 Octane BT Logs | PapaSmurf | 2010 MS3 - ECU Computer Tuning | 12 | 06-02-2011 06:24 PM |
| Ultimate racing test pipe and down pipe install w pics | 2010 MS3 | 2010 MS3 - Engine, Transmission & Driveline | 28 | 03-17-2010 10:38 AM |
| Brand name test pipe vs. custom muffle shop test pipe | Huligan | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 10-05-2009 07:52 AM |
| SU test pipe vs. turboxs test pipe | ZoomByU | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 08-06-2009 03:09 AM |
