7Likes ![]() |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
(Thread Starter) | Not Ranked : 0 score I think the kits are around $90 and well worth the money for those of us who have had emotional breakdowns over the stock line. Should make turbo swaps a dream. The big thing that makes these special is A. the block adapter and B. the flared ends that will prevent leaking like you get with just cutting the stock pipe in half.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
| The Following 4 Users Say Thank You to GroceryGtr For This Useful Post: |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score If this will work on MS6, I'm all over it like a fat kid on a cupcake...
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
Groans: 60
| Not Ranked : 0 score I never understood why so many have issues with the drain line. I'm glad there is finally an off the shelf solution, but it's really cheap to have a -10 fitting welded to a cut off stock drain line.
(Thread Starter) | Not Ranked : 0 score len - yes it fits the ms6, check codemonkey's race car thread last post he has pics of it installed.
| The Following User Says Thank You to GroceryGtr For This Useful Post: | LenSpeed6 (04-29-2018) |
| The Following User Says Thank You to Code Monkey For This Useful Post: | LenSpeed6 (04-29-2018) |
| Not Ranked : 0 score Any update on a part number for this kit? Can someone easily email BNR and just ask for an oil return line kit? It would be cool if there was a separate link on the website to buy stuff that comes in one of their kits, but I do understand the logic that they would rather sell you a whole turbo kit instead of just certain parts for it.
(Thread Starter) | Not Ranked : 0 score yep, just send bryan an email and he will get you squared away. they are not listed on the site.
![]() Join Date: Oct 2015 Location: Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score For pretty much the same price, why wouldn't you just get one of the nice ones that Eric makes? ![]() ![]() Sent from my SM-G955W using Tapatalk
__________________ 2007 ms6, BNR S3, JBR 3" silcone intake, streetunit tmic, ATP 3" dp, WW 3" dp back, Autotech hpfp, denso itv22 plugs, synapse synchronic bpv, Cobb ebcs, egr block off, cobb ap v3, Damond pmm, AWR tmm, jbr rmm, cpe rear diff mount, AEM trunk mount meth, 3bar map, cpe safeseals, SP63 4032 88mm pistons, Manley H beam rods, bsd w/baffle, mild head and im porting, vtcs delete, balanced bottom end, cm850 w/ steel fw, Innovate failsafe, guardian angel v3 |
| The Following 2 Users Say Thank You to mikey27 For This Useful Post: | impossible (06-24-2018), myarbro1 (05-29-2018) |
Groans: 211
What caused that block to vent?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
(Thread Starter) | Not Ranked : 0 score because I doubt that one would fit the speed6 xfercase clearance, and the bnr is the only one I am aware of that is confirmed to work with the speed 6. There are tons of solutions for the speed 3 guys, bnr is the only one to date verified to fit a 6.
| The Following User Says Thank You to GroceryGtr For This Useful Post: | Thor Hammer (05-23-2018) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Erik's fit the speed6, and he's got versions for most (all? I'm not sure) of the major turbos.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | myarbro1 (05-29-2018) |
(Thread Starter) | Not Ranked : 0 score good, then he should post it up and share it with the rest of the community.
![]() Join Date: Feb 2016 Location: Central Texas
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Not sure if he is on the forums or not otherwise I would tag him.... As far as the oil drain line goes Eric has quite a few options for speed3 and 6 for different turbos. Not sure if the kit that he makes comes pre assembled ready to go or if you have to assemble it which I think you can make what ever length you need for your liking. You can reach Eric on his Facebook page.. he's also the one that makes the best tucked wire harness for the entire speed community. Many options for those as well. (Mazdaspeedwiretuck) https://m.facebook.com/mazdaspeedwiretuck/ |
| The Following 2 Users Say Thank You to SpeedyTurd For This Useful Post: | impossible (06-24-2018), myarbro1 (05-29-2018) |
| Not Ranked : 0 score I have an s4 and didn’t have any issues with the drain line?
| Not Ranked : 0 score I believe the S4 works with the OEM drain line; S5 does not.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Djohns (05-27-2018), Thor Hammer (05-29-2018) |
His pictures, idk. He just uses it for mock-up's.
__________________ 2007 ms6, BNR S3, JBR 3" silcone intake, streetunit tmic, ATP 3" dp, WW 3" dp back, Autotech hpfp, denso itv22 plugs, synapse synchronic bpv, Cobb ebcs, egr block off, cobb ap v3, Damond pmm, AWR tmm, jbr rmm, cpe rear diff mount, AEM trunk mount meth, 3bar map, cpe safeseals, SP63 4032 88mm pistons, Manley H beam rods, bsd w/baffle, mild head and im porting, vtcs delete, balanced bottom end, cm850 w/ steel fw, Innovate failsafe, guardian angel v3 | |||
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 262 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score He's all over the fb groups; a ton of people are running his drain lines and wire tucks.
__________________ Genpoo stuff |
| The Following 2 Users Say Thank You to sharksinspace For This Useful Post: | impossible (06-24-2018), myarbro1 (05-29-2018) |
![]() Join Date: Nov 2012 Location: Riverview, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score Yawn
__________________ Mica Black '06 Speed6 GT #02871: E85 tune by Purple Drank - AT internals - Damond RMM - WW FMM - MF CBE - eBay DP - RamFab 4" intake - Custom FMIC - GS EBCS - TS BOV - CS stress bars - CD rotors - EBC Redstuffs - H&R Sports w/ Koni Yellows - Redline hood struts - PnP IM - MS OCC's - Full Race exhaust mani - GTX2867r - CP-e rear diff mount - SURE Juggernaught - Diff caps - DSS axles - EVO 8 Brembos - lots fucking more |
| The Following User Says Thank You to myarbro1 For This Useful Post: | mikey27 (05-29-2018) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score M
![]() | | #20 | ![]() |
| Not Ranked : 0 score I spy tc’s
![]() | | #21 | ![]() |
![]() Join Date: Mar 2012 Location: Grayson, Ga
Rep Power: 751 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,729
| Not Ranked : 0 score Has anyone used the bnr drain line kit yet? I trried installing my S5 into my 6 yesterday and it was a huge failure. Bottom bracket's spout rests on the transfer case. Upper brackets spout rests against the ewg of the hotside. Not sure how they mocked this kit up but I found no way to get it on. Sent from my Pixel XL using Tapatalk
__________________ |
![]() | | #22 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score I bought a line from Eric along with one of his wiretucked harnesses with the PI dongle for the Split Second controller. I have a Precision 6466 but he still makes them for K04, BNR CS turbo, Garrett and PTE turbos, and his lines are better quality that I'd trust over this setup
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | myarbro1 (08-01-2018) |
![]() | | #23 | ![]() |
OverBoosted - Are you saying the S5 physically wouldn't fit or the included drain kit would not fit? Code Monkey has links to his install above with the drain kit. I have also fitted the drain kit without issue, granted mine was not with a S5.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... | |
| The Following User Says NO Thank You to GroceryGtr For This Un-useful Post: | sharksinspace (07-02-2018) |
![]() | | #24 | ![]() |
I was trying to install it all in the car and with the transfer case installed etc. I dropped the turbo in, bolted the cpe mani in. Then bolted the turbo up to the manifold. tried installing the hose from the two fittings and had no luck. I had to try and bend the lower fitting to get it off the transfer case and it fucked the flat flange up.
__________________ | |
![]() | | #25 | ![]() |
| Not Ranked : 0 score So looking at Code Monkeys pictures I see my issues. Red circle on my car was sitting against the transfer case. so no way to get hose on it. Yellow circle is the fitting that I needed to allow the angles to be right. The BNR fitting goes straight down and when you try to make the line connect it kinks the hose there.
| The Following User Says Thank You to OverBoosted For This Useful Post: | Code Monkey (06-25-2018) |
![]() | | #26 | ![]() |
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score At this point I'm just going to get some AN fittings and make a line. Even if the lower fitting didn't hit the transfer case the upper one won't work. Here is how I ended the night at 2am. I used the upper BNR fitting and a cut stock drain for the block side. Hose is kinked closed.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score yea I'd definitely reach out to Bryan that kit was specifically designed for the S5 so something has to be up. Do you have the slack to clock the turbo a bit towards the block so the fitting clears the ewg, its a straight fitting uptop so it should allow you to snake around the pipe. On the block side fitting I have no clue. I don't remember Code Monkey having any issues he mentioned and I had room when I test fitted everything. Mine is the exact same thickness as the stocker and the actual part you slide the hose on sits above the lip of the xfer case.
| The Following 2 Users Say Thank You to GroceryGtr For This Useful Post: | Code Monkey (06-26-2018), OverBoosted (06-26-2018) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Little Update: Got all the parts in to make the line. The Turbo and Block fittings are top notch for sure. Going to be installing this afternoon so I will update how it goes.
![]() | | #30 | ![]() |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score What you guy's need is not a special oil drain line, but a top-mount manifold
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Yep, a top mount would make it easy to run a drain line on MS6's.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Thankfully you guys won't have to wait much longer. I already fabbed a -10AN line for the S5 and S6. Bryan was good enough to loan me a hotside for both so I could do so.
| Display Modes | |
| Oil Drain Line Flange pre-buy | Matt@DamondMotorsports | Damond Motorsports | 48 | 03-14-2016 12:38 AM |
| MS6 Oil Drain Line Flange | Farhan@DM | Damond Motorsports | 58 | 02-12-2016 12:00 AM |
| bt oil drain line for MS6 | ryein7 | MazdaSpeed 3/6 - Turbo Induction | 17 | 03-14-2012 10:42 AM |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
