Like Tree24Likes
 Old 11-15-2011, 08:33 AM   #81
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
But clipping that wire is a permanent modification that might void my warranty.
I'm guessing you're joking, but if not...
Solder that shit back together and heatshrink it. Like they'll ever open your steering column anyway.
Sent from my DROIDX using Tapatalk
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
 Old 11-15-2011, 08:39 AM   #82
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Yes, I think he was being a bit sarcastic. I know that that is hard to believe on this forum!
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Dano (11-15-2011), silvapain (11-15-2011)
 Old 11-15-2011, 09:04 AM   #83
Yeah, I figured. Subtlety doesn't come across the internet well.
 Old 11-15-2011, 09:11 AM   #84
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
not sure Erich's comment was subtle considering the context...coming from the guy that has a fully built 500+ WHP MS3...warranty is the last thing on his mind
The Following 5 Users Say Thank You to Dano For This Useful Post:
doubleflusher (11-15-2011), kritz (11-15-2011), rigor (11-21-2011), silvapain (11-15-2011), Tokay444 (11-15-2011)
 Old 11-15-2011, 09:57 AM   #85
Thought he might've been one of the big hp ones. It's hard to keep track of everyone and their cars sometimes, especially on the tapatalk without sigs and avatars.
The Following User Says Thank You to Pedal-Force For This Useful Post:
Dano (11-15-2011)
 Old 11-15-2011, 09:59 AM   #86
Trail of Fail
Dano's Avatar
so true...
well I guess you can't say "coming from the guy" anymore...since we have what 3-4 now?
haha
Last edited by Dano; 11-15-2011 at 09:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-15-2011, 10:08 AM   #87
708
Erich's Avatar
Posts: 4,274   (View Stats)
so true...
haha
Fuck that, I'm still the guy. The rest are just following. First 500+ and then slipping clutch.
[\sarcasm] <----- for those that need it
The Following 4 Users Say Thank You to Erich For This Useful Post:
Dano (11-15-2011), djuosnteisn (11-15-2011), doubleflusher (11-15-2011), kritz (11-15-2011)
 Old 11-15-2011, 10:26 AM   #88
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
What clutch do you/did you have?
I killed my OEM after 200 miles.
ACT 6 puck FTW!!
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
rigor (11-21-2011)
 Old 11-15-2011, 10:34 AM   #89
708
Erich's Avatar
Was a sbc feramic street disk. Have an sbc 6 puck ready to go in, just need to find the time.
The Following 3 Users Say Thank You to Erich For This Useful Post:
djuosnteisn (11-16-2011), doubleflusher (11-15-2011), rigor (11-21-2011)
 Old 11-15-2011, 10:53 AM   #90
Trail of Fail
Dano's Avatar
sarcasm...I invented it bitch!
and yes you are the first...the cherry is yours.
 Old 11-15-2011, 05:44 PM   #91
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
waaaaaaaaaaaaaaaaaa!
at 104000 2 bent rods
tuned by nishan
 Old 11-16-2011, 05:15 PM   #92
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Originally Posted by crtguns View Post
Fuck logs... I can seriously feel my car's faster through hard curves. Never realized it till now- how stoopid that computer sensor crap is.
Putting the brakes on for you while you're trying to accellerate through a curve- it's counterproductive. Braking in a curve unlads the rear tires, that will cause slip and slide. Accellerating through and out of a curve keeps the nose up and the rear end planted.
Moreso with a RWD, but still applies here.
Unplug your shit.
It doesn't "put the brakes on."
It simply holds back engine power.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
doubleflusher (11-16-2011), Tokay444 (11-16-2011)
 Old 11-16-2011, 05:25 PM   #93
Trail of Fail
Dano's Avatar
but can/does it modulate brake application to F/R? I swear the very day I disabled my SWAS I almost bit it in a corner that I routinely take and brake at higher speeds...see OP disclaimer.
might have just been coincidence and I took the corner a bit different.
 Old 11-16-2011, 05:55 PM   #94
Nliiitend1's Avatar
I don't believe so, but I have no primary knowledge upon which my belief is based...
**EDIT**
Let me qualify that statemtent...
The SWAS surely plays a role in the behavior of the DSC (which has some power over the braking system), but I think the jury is still out about how interconnected the DSC and ABS (in the "old-fashioned", simply-keep-the-brakes-from-locking fashion) are...
I would hope that the engineers designed the system so that when you push the "DSC off" button it would disable the brake vectoring part of the braking system (along with the traction control) and leave just the "simply-keep-the-brakes-from-locking" portion of the braking system in service. I believe this to be the case with this car. I believe that the power-limiting function of the SWAS is independent of the SWAS's role in DSC. Basically, my working theory is that two systems are operating independently of one another (the power-limiting algorithms in the ECU, and the DSC system) using data from the same sensor. The power reduction that Mazda may or may not employ (not ALL ESC/DSC systems limit power - some do their magic purely through the braking system, and I'm honestly not sure what Mazda claims this car uses) for the DSC system is completely separate from the power reduction used to limit torque-steer/traction problems (the gear 1-2 power limiting and SWAS-dependent power limiting).
That said, if you simply halt the SWAS's ability to send data to BOTH those systems, you would of course expect that you might get some funky behavior out of the DSC system...
If anyone has hard evidence that suggests my theories are unsound, please post it up.
2008 MS3 GT
2016 MX-5 Club
Dano (11-16-2011), Tokay444 (11-16-2011)
 Old 11-16-2011, 06:28 PM   #95
Trail of Fail
Dano's Avatar
I certainly don't know for sure but as you said the SWAS is just a sensor and two system use that sensor in their calculations.
without the SWAS neither knows the steering angle of the car and thus can't even attempt to compensate for any steering angle. my theory is that if you over steer a lil bit the ABS system would kick in and auto apply brake pressure which would assist in the oversteer condition. I found that my car rotated very easily with SWAS disabled compared to when it was plugged in.
.02
Nliiitend1 (11-16-2011)
 Old 11-16-2011, 06:37 PM   #96
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
When dsc is on, the idea is that if it senses oversteer, it brakes the outside front tire in an attempt to push the front end out.
Without a steering angle sensor, I don't see how the car would even know it was oversteering.
I do know that with the dsc off and the squiggly lines lit, the car will snap oversteer at the drop of a had.
It most likely has more to do with suspension geometry than the electronics.
"Exclusivity" - CP-enis
Demodded.
The Seals
Dano (11-16-2011), Nliiitend1 (11-16-2011), XLT_66 (11-17-2011)
 Old 11-18-2011, 12:01 PM   #97
RWDAddict's Avatar
Posts: 340   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
Did the new major release fix these issues?
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 11-18-2011, 12:21 PM   #98
708
Erich's Avatar
I see nothing in the release notes that indicate anything to do with SWAS.
rfinkle2 (11-18-2011)
 Old 11-18-2011, 12:31 PM   #99
I wonder if one of those codes disables the swerving ms3 light?
 Old 11-18-2011, 01:32 PM   #100
Jake5713's Avatar
Posts: 1,775   (View Stats)
+1
I am here: http://maps.google.com/maps?ll=44.738952,-93.065893
-Jake
 Old 11-18-2011, 02:08 PM   #101
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Any of you guys that disconnected the SWAS have any issue's with your power steering going out when turning while moving slow? I'm sure I read a thread somewhere about a Gen2 owner losing his power steering while going under 10mph with the SWAS disconnected. Good thing though, this explains why my car will hesitate sometimes while making a sharp turn trying to go WOT.
 Old 11-18-2011, 11:55 PM   #102
Nliiitend1's Avatar
Seeing as how the Gen 2 uses an electric pump, I'd say it's definitely not out of the realm of possibility that something like that might happen...
2008 MS3 GT
2016 MX-5 Club
 Old 11-19-2011, 12:33 AM   #103
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
From what I can find, the codes dealing with traction control are Mazda-specific, and therefore start with a 1 (P1XXX). There are no manufacturer-specific codes in the DTC list in ATR.
Most Complete List For Mazda Check Engine Light Codes
myt_tuf1 and rfinkle2 like this.
rfinkle2 (11-19-2011)
 Old 11-20-2011, 01:03 PM   #104
Originally Posted by rigor View Post
i just clipped the yellow wire with blue stripe, and wired it to a switch so when its icy or shity out im good to go.
[IM G]http://i1121.photobucket.com/albums/l514/rigor1/2011-11-12123406.jpg[/IMG]
[IM G]http://i1121.photobucket.com/albums/l514/rigor1/2011-11-12123322.jpg[/IMG]
Where'd you run the switch to? I don't really want to drill a hole in my steering column. I'm thinking of using a reed proximity switch. Only problem is that reed switches are all momentary, so I'd need to build a little circuit to turn it into a toggle.
Would anyone be interested in something like this? Once I get moved into my new house and settled (things are crazy right now, it would be after the new year probably), I could build a few and sell them. If there was enough interest I could even have some boards fabbed up and make it look nice. I'll prototype on my car though. Gotta figure out the simplest way to make the toggle work, without taking up too much space.
josurr likes this.
The Following 2 Users Say Thank You to Pedal-Force For This Useful Post:
josurr (11-20-2011), Nliiitend1 (11-20-2011)
 Old 11-20-2011, 01:52 PM   #105
rigor's Avatar
Groans: 40
i prefer the switch switch it off and forget it, till the icy season comes, i don't need another button to forget to push and get power cut lol
i mounted mine here
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
GoSpeed3Go (11-22-2011), kgb (01-15-2012)
 Old 11-20-2011, 05:35 PM   #106
Finished. I ended up not doing the reed switch, just too much work (although it would have been a normal toggle, you wouldn't have needed to hit it each time). I ended up with a little blade toggle switch.
Of course, in my infinite wisdom, I put it sort of in the way of the handle for the tilt/telescope thing. It still works. You kinda just bend the plastic where I put the switch slightly to slide the handle paste. Plus, how often do I use that handle?
Oh well. It's working fine.
 Old 11-20-2011, 07:34 PM   #107
So if anyone is interested in exactly how to put a switch in (I've gotten a PM asking for clarification).
Buy a simple SPST (single pole single switch) toggle switch from Radio Shack or wherever. You can also use a rocker, or a push button. I wouldn't recommend a lighted one because I'm not sure where to find a 12V down there, and also because some of those switches only have three terminals. A +V, a GND, and an ACC. So in order to get light, you have to tie the thing you want to switch into +12V, which isn't what we want. If you can find a proper GND and 12V source down there, and get a 4 terminal SPST switch, feel free to get a lit switch, although you'll be putting it in an invisible place anyway.
Unplug the sensor plug as shown earlier. Cut the tubing around the wires back some so you can get at the wires. Pick a wire from the sensor plug, and cut it about halfway between the sensor and the edge of where you can see it come out of the tubing. It probably doesn't matter what wire you pick. I tested them all, and most are 0V DC. One is .3 V, probably the power for the chips. One is ground, and the rest are probably signal. I picked the power one, but it doesn't matter.
Get a couple feet of wire (18-20 AWG stranded is probably best, approximate match for the sensor wires). Cut it in half and strip each end. Strip the two ends of the sensor wire that you cut.
Take out the third screw and completely remove the bottom piece of plastic from the steering column. Drill a hole in the bottom the size necessary for your switch that you've bought. Make sure you don't drill it in the inset where the tilt handle goes, unless your switch is short enough to clear it. Before you install the switch, solder one end of each of the long wires that you cut to the terminals on the switch. Then install the switch in the plastic. Heatshrink those connections (or electrical tape if you can't heatshrink, but I'd really recommend heatshrink, electrical tape gets nasty after a while). Then slide heatshrink on the long wires and solder one end of each to the cut ends of the sensor wires. Slide the heatshrink over the connections and solder. If 1 foot is gonna be too long, you can cut them to length before you solder, I didn't measure, I just used some pieces of wire I had. Plug the sensor back in, turn the ignition on and see if your switch works. With the toggle off you'll have no SWAS so the lights will be on. If you switch it ON after it has been OFF, the car will still think it has a problem until you turn the car on/off again.
If it's working, put the plastic cover back on the steering column, and tighten it up. You're done.
Simple.
The Following 3 Users Say Thank You to Pedal-Force For This Useful Post:
adlpb (11-22-2011), redneck4Christ (03-09-2012), rfinkle2 (11-22-2011)
 Old 11-21-2011, 04:51 PM   #108
So I'm back from my first drive with the SWAS toggle turned off. Definitely no traction control anymore. It's raining, so in a safe area I put my foot down in 2nd, spun the tires all the way to redline, no nanny at all. The wheel hop is also much, much worse now, so I'll have to deal with that. At least I'm in control of my own car now.
The power steering definitely does something weird though. The pump is still working, because if you turn the wheel the headlights dim. But it's not helping much at all, if any. It's definitely not doing anything at low speed, but I'm not sure it's working at high speed either, you just don't notice because it's not hard to turn the wheel anyway. Definitely annoying.
 Old 11-21-2011, 05:39 PM   #109
708
Erich's Avatar
Must be a genpu thing (electrical vs mechanical). I have not seen that kind of thing with my PS and been driving around with SWAS disconnected for a couple of months now.
 Old 11-21-2011, 05:50 PM   #110
Trail of Fail
Dano's Avatar
same here...guess the SWAS also tells the PSP when to activate or some sort of valve to open on a genpu.
djuosnteisn (11-22-2011), Nliiitend1 (11-22-2011), rfinkle2 (11-22-2011)
 Old 11-21-2011, 06:02 PM   #111
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
This sucks. I hate the SWAS...I find it dangerous, especially if pulling out from a dead stop to get into traffic...I hit the gas and the car sputters and spits and doesn't move...then moves when the wheel straightens. It has caused problems for me more than once. Sure in an extreme corner I can see how it could potentially help...but then again most of the time when going fast in a corner it is on purpose and not unintentional.
We really need to find a way to disable this damn thing on the GenPU AND keep the power steering functioning like normal.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 11-21-2011, 06:10 PM   #112
I think I'd rather have the SWAS disabled than have working power steering. But it's close. Since I have a toggle, I might leave the SWAS turned on unless I want to do logs or screw around.
 Old 11-21-2011, 06:16 PM   #113
Tokay444's Avatar
Groans: 793
I remember when cars didn't have ps
Demodded.
The Seals
doubleflusher (11-21-2011), mazdas4me (12-15-2013), redneck4Christ (03-09-2012)
 Old 11-21-2011, 06:40 PM   #114
Yeah, cars also tended to weigh less, weren't FWD, and didn't have big wide tires. They also had systems that were designed to not have power steering. This car is a bit of a bear at low speeds, honestly. It was obviously designed to have power steering.
I grew up learning to drive stick on a 1985 Alfa Romeo Spider, which didn't have power steering. But the car also weighed all of 2200 lbs, had a big steering wheel, RWD, and was designed for no power steering.
 Old 11-21-2011, 07:49 PM   #115
So if you check the shop manual it shows that the SWAS is part of the logic circuit for the electric power steering.
The code we need to get rid of is C1938 in order to have the lights on the dash go off I think. I tried two other codes, but neither worked.
 Old 11-22-2011, 09:15 AM   #116
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Simple.
Can you please take some pictures of this set-up? I'm looking into doing a similar switch myself.
 Old 11-22-2011, 10:17 AM   #117
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Lol, only mazda would tie that shit into the power steering. I think I am going to keep mine plugged in, until there is a fix that isn't kind of ghetto (come on cobb you can dooo eeeet)
The Following User Says Thank You to G26 For This Useful Post:
Caboose (11-23-2011)
 Old 11-23-2011, 07:48 AM   #118
Pictures of what? There's not much to take pictures of.
Step 1: Disconnect SWAS
Step 2: cut one of the SWAS wires
Step 3: solder a toggle switch in between said wire ends
Step 4: Drill a hole in the steering column for said switch
Step 5: install said switch in said steering column
Step 6: put shit back together
Step 7: go do donuts because you can.
burn813 (11-23-2011), Z32_MS3 (01-13-2015)
 Old 11-23-2011, 07:52 AM   #119
adlpb's Avatar
Groans: 669
I just wanted to see your setup (switch location) to compare to what I was thinking of but thanks anyway
 Old 11-23-2011, 11:05 AM   #120
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
On the gen 1's, the switch boxes by the DSC to the left of the steering wheel pop out real easy. I'll probably put my switch there if i get around to it this weekend.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Dano (11-23-2011), LiEast (01-15-2012), rfinkle2 (11-23-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/swas-how-disable-90739/
Overlooked H Street overdogs? - Page 4 This thread Refback 09-29-2015 07:50 AM
MS3 gen1: How does disabling SWAS affect DSC and TC? : mazda This thread Refback 07-07-2014 02:40 PM
COBB AccessPort This thread Refback 05-23-2014 03:17 PM
Etunning pour Ms3/Ms6 - Page 2 This thread Refback 03-09-2014 02:08 PM
?????? ? ????????? MPS This thread Refback 11-27-2013 02:21 PM
Etunning pour Ms3/Ms6 This thread Refback 07-30-2013 06:18 PM
Mazdaspeed 3 2nd gen !!!!!!!! This thread Refback 07-30-2013 04:27 PM
Flat foot shift - Page 2 - Mazda 3 Quebec This thread Refback 07-30-2013 01:39 PM
MazdaSpeed Forums This thread Refback 09-09-2011 06:39 PM
SWAS - DISCONNECT ON A GEN2 Monotonous ONE 2010 MS3 - How-To's 160 10-07-2018 09:17 PM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
Where is the Steering angle senor (SWAS)?? magoo MazdaSpeed 3 - How-To's 61 12-28-2011 12:07 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.64192 seconds with 37 queries
