Like Tree24Likes
 Old 09-12-2011, 02:21 PM   #41
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
yeah with this car you just never know..LOL
I also think that with the more power your are making the more impact SWAS makes on power reduction when triggered.
This could be a clue as to how it is interacting with other tables I guess. Example, looks like it is using a negative multiplier of sorts and so the more power you are making, a la Load maybe, the more it richens up AF and retards ign advance and what ever else it may do IDK.
but this begs the question, why richen up AF to reduce power? Why not just close the throttle plate? Or is closing TPS causing the rich condition? hum.
Seems when I logged, last AP FW which still had a fairly fast logging rate, I didn't see TPS change when SWAS dropped my face into the wheel.
I need to add that to my list of 1K things to test LOL
djuosnteisn (09-12-2011), Erich (09-12-2011), rfinkle2 (09-12-2011)
 Old 09-12-2011, 02:30 PM   #42
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I've never experienced any of what you guys are talking about.
Then again, I don't believe in driving aids personally, so I've habitually held the button on start up since day one. Even when I thought it didn't do anything more over just pressing the button.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-12-2011, 02:35 PM   #43
708
Erich's Avatar
Posts: 4,274   (View Stats)
Holding the button on start up doesn't fix this problem. At least for me, nothing short of unplugging the SWAS made a difference.
The Following 3 Users Say Thank You to Erich For This Useful Post:
Dano (09-12-2011), djuosnteisn (09-12-2011), Tokay444 (09-12-2011)
 Old 09-12-2011, 02:36 PM   #44
Trail of Fail
Dano's Avatar
I never noticed it until I got to a certain power level...maybe when I put the GT28 on..I don't remember.
djuosnteisn (09-12-2011), Erich (09-12-2011), Tokay444 (09-12-2011)
 Old 09-12-2011, 02:53 PM   #45
708
Erich's Avatar
Yeah, wasn't a big deal with the K04.
The Following 2 Users Say Thank You to Erich For This Useful Post:
 Old 09-12-2011, 03:19 PM   #46
Tokay444's Avatar
Groans: 793
Ok. That help me understand the problem a bit more.
Demodded.
The Seals
 Old 09-12-2011, 03:22 PM   #47
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
philly and i undid the swas years ago.....my chit overboosted like a motherfucker....knocked, backfired.....ran like shit...but it was worth a try lol
years ago......
 Old 09-12-2011, 03:31 PM   #48
Trail of Fail
Dano's Avatar
who is this rodrigo character??
 Old 09-12-2011, 03:35 PM   #49
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
DANO..... i am your father
- nooooooooooooooooooooooooooooooooooooooo
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
 Old 09-12-2011, 03:36 PM   #50
Trail of Fail
Dano's Avatar
hahahahah
good to see you can still type and retained your sense of humor....
 Old 09-12-2011, 03:40 PM   #51
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
im still here.... been pre occupied nigro
 Old 09-12-2011, 03:45 PM   #52
Trail of Fail
Dano's Avatar
gotta beat wasting time in here....
 Old 11-10-2011, 07:55 PM   #53
crtguns's Avatar
Posts: 464   (View Stats)
crtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the world
Groaned at 340 Times in 107 Posts
Originally Posted by redbathtub View Post
Pictures of a 1st gen from another thread:
The 'ABS" above the now disconnected plug... Auto brake system? nothing to do with the Antilock braking system?
I should probably
know better, But I'm doing this first thing in the morning.
crtguns is offline   Reply With Quote
The Following User Says Thank You to crtguns For This Useful Post:
Dano (11-11-2011)
 Old 11-11-2011, 08:15 AM   #54
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I need to do this too. Maybe this weekend.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-11-2011, 08:44 AM   #55
Trail of Fail
Dano's Avatar
my car hasn't spit, sputtered, stumbled, stuttered, any of that since I yanked mine.
djuosnteisn (11-11-2011), Erich (11-11-2011)
 Old 11-11-2011, 08:47 AM   #56
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Same here.
Tapadatass
 Old 11-11-2011, 08:54 AM   #57
Trail of Fail
Dano's Avatar
it would be much cooler if @David@COBB could uncover the tables the ecu switches to when SWAS is triggered.
This way we keep stability control and lose the bad stuff.
I would not put this on the priority list but if he happened to stumble [hehe] across it that would be nice.
When I captured it in a log it appeared to pull timing and richen up AF so at least two tables in play. Very similar to the rich retard after a normal shift when FFS was enabled and he found those tables. [clutch in/out]
Nliiitend1 likes this.
djuosnteisn (11-11-2011), Erich (11-11-2011), Nliiitend1 (11-11-2011)
 Old 11-11-2011, 11:13 AM   #58
708
Erich's Avatar
Same here.
Tapadatass
Same.
Amen.
Dano (11-11-2011), Nliiitend1 (11-11-2011)
 Old 11-11-2011, 11:40 AM   #59
Jake5713's Avatar
Posts: 1,775   (View Stats)
I there any solution to getting rid of dash lights caused by disconnecting SWAS?
Any word on a toggle switch so I don't have to take shit apart all the time??
I am here: http://maps.google.com/maps?ll=44.739837,-93.107838
-Jake
The Following User Says Thank You to Jake5713 For This Useful Post:
 Old 11-11-2011, 11:51 AM   #60
708
Erich's Avatar
I am here: Google Maps
-Jake
I posted it somewhere, but to restate I like the swervy car dash light. It is like my car knows how it is going to get driven before I even start moving.
p057 and redneck4Christ like this.
 Old 11-11-2011, 11:53 AM   #61
Trail of Fail
Dano's Avatar
lol
 Old 11-11-2011, 11:58 AM   #62
Jake5713's Avatar
So no?
I am here: http://maps.google.com/maps?ll=44.739845,-93.107859
-Jake
 Old 11-11-2011, 01:23 PM   #63
silvapain's Avatar
Groans: 136
Pull the instrument cluster out and remove the bulb.
Tapadatass
kgb (04-02-2012)
 Old 11-11-2011, 01:54 PM   #64
Jake5713's Avatar
Tapadatass
Fuck, I wouldn't know where to start
I am here: http://maps.google.com/maps?ll=44.917589,-92.894459
-Jake
 Old 11-11-2011, 01:58 PM   #65
708
Erich's Avatar
and would probably cause a new rattle trying to disable the light. And rattles are WAY more annoying then lights. I pulled the hood off the instrument cluster to hook up the speed pulse cable for my AVIC. I have pulled it apart twice since trying to fix the rattle it caused.
 Old 11-11-2011, 02:08 PM   #66
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I should probably
. . . or ABS plastic. . .
 Old 11-11-2011, 04:48 PM   #67
Captain
Tapadatass
Easier to just keep your eyes shut. Duh.
www.permtuning.com
Dano (11-12-2011), silvapain (11-11-2011)
 Old 11-11-2011, 05:40 PM   #68
Trail of Fail
Dano's Avatar
Or just put electrical tape over the lil amber car.
Tappin
 Old 11-11-2011, 06:43 PM   #69
Tokay444's Avatar
Groans: 793
Who you calling rich retard?
I'm blue collar.
Demodded.
The Seals
Dano (11-12-2011)
 Old 11-11-2011, 06:46 PM   #70
Trail of Fail
Dano's Avatar
u gonna say the cluster bolts are torque to yield?
hahaha
Tokay444 (11-11-2011)
 Old 11-11-2011, 06:48 PM   #71
Tokay444's Avatar
Groans: 793
In case someone misses my joke.
I know it's not funny if you have to explain it, but...
Demodded.
The Seals
Dano (11-12-2011), DingoDave (11-28-2011), djuosnteisn (11-11-2011)
 Old 11-12-2011, 02:29 PM   #72
crtguns's Avatar
Just did mine...Gen1 has 4 screws... the two you can readily see on the bottom of the column, the one you can hardly see way under tyhe column, bahind teh wheel adjuster, but before you get to that one, you gotta pull out the hood release- push in tab on top of the unit, and pull straight out. Then there's a screw right behind it.
All went back on way easier than it came off.
No rattles (taped the white plug down)
I was hoping there would be some wet roads this am to go throw my ass around a little... nothing but sunshine.
 Old 11-12-2011, 02:36 PM   #73
Mizzle's Avatar
Groans: 324
So has anyone compared logs from this to when you hold in the DSC button at start-up?
The Following User Says Thank You to Mizzle For This Useful Post:
Cyberdutch (02-04-2020)
 Old 11-12-2011, 03:07 PM   #74
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
Disconnected my SWAS a few months ago. Just pulled the two screws under the dash, pulled down that part and used a pick tool to push the plug retainer. Took about 4 minutes. Easy to do. I did 4 other Speed 3's in NM one night at a local meet. Took like 15 minutes combined for all 4 in the dark!
I was wondering, for Dano and the others that had oversteer... Are you guys turning off DSC as well? I have never had any issues with breaking loose, or oversteer. But I never leave anywhere with DSC on.
And for the logs... I did a lot of driving and comparing with DSC on, off and holding the button at start up. I will still lose power if the wheel was turned. It seemed harder to do, but it would cut eventually. The logs never gave me any answer. No magic boost number. If the wheel was turned, the SWAS would activate. No issues since unplugged.
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following User Says Thank You to RayRay For This Useful Post:
djuosnteisn (11-15-2011)
 Old 11-12-2011, 05:20 PM   #75
silvapain's Avatar
Groans: 136
With the SWAS disconnected and DSC on, I suspect the car will default to the steering wheel at 0 degrees (straight). That would explain why it no longer limits boost. It would also explain why the car would use rear braking when the system detects yaw and slipping; it's assuming the car is sliding with the wheel straight forward, and is trying to straighten out the rear end.
Tapadatass
 Old 11-12-2011, 05:21 PM   #76
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i just clipped the yellow wire with blue stripe, and wired it to a switch so when its icy or shity out im good to go.
at 104000 2 bent rods
tuned by nishan
The Following 13 Users Say Thank You to rigor For This Useful Post:
daafisch (11-28-2011), Dano (11-15-2011), djuosnteisn (11-15-2011), doubleflusher (11-12-2011), Erich (11-15-2011), evidence (11-13-2011), GLORIFIEDBOZO (04-09-2012), josurr (11-15-2011), kgb (01-15-2012), LiEast (01-15-2012), Nliiitend1 (11-13-2011), RayRay (11-12-2011), silvapain (11-12-2011)
 Old 11-15-2011, 02:15 AM   #77
crtguns's Avatar
Fuck logs... I can seriously feel my car's faster through hard curves. Never realized it till now- how stoopid that computer sensor crap is.
Putting the brakes on for you while you're trying to accellerate through a curve- it's counterproductive. Braking in a curve unlads the rear tires, that will cause slip and slide. Accellerating through and out of a curve keeps the nose up and the rear end planted.
Moreso with a RWD, but still applies here.
Unplug your shit.
 Old 11-15-2011, 03:47 AM   #78
josurr's Avatar
Posts: 954   (View Stats)
josurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the world
Groans: 156
can anyone confirm if it is the same wire on genpu?
also, what type of switch did you use? was it a basic on/off switch or did you get one that you could ground out?
josurr is offline   Reply With Quote
 Old 11-15-2011, 07:19 AM   #79
rigor's Avatar
Groans: 40
you just want to open the circuit, do not ground! just carries a signal so a light duty switch will work
as for gen poo their is a how to on them also
but if you can find the swas, i checked, found the hot, found the ground, put the switch on the signal wire, but i think it would work, if any of the wires are interrupted .
to disable the thing...
tuned by nishan
 Old 11-15-2011, 07:35 AM   #80
708
Erich's Avatar
But clipping that wire is a permanent modification that might void my warranty.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/swas-how-disable-90739/
Overlooked H Street overdogs? - Page 4 This thread Refback 09-29-2015 07:50 AM
MS3 gen1: How does disabling SWAS affect DSC and TC? : mazda This thread Refback 07-07-2014 02:40 PM
COBB AccessPort This thread Refback 05-23-2014 03:17 PM
Etunning pour Ms3/Ms6 - Page 2 This thread Refback 03-09-2014 02:08 PM
?????? ? ????????? MPS This thread Refback 11-27-2013 02:21 PM
Etunning pour Ms3/Ms6 This thread Refback 07-30-2013 06:18 PM
Mazdaspeed 3 2nd gen !!!!!!!! This thread Refback 07-30-2013 04:27 PM
Flat foot shift - Page 2 - Mazda 3 Quebec This thread Refback 07-30-2013 01:39 PM
MazdaSpeed Forums This thread Refback 09-09-2011 06:39 PM
SWAS - DISCONNECT ON A GEN2 Monotonous ONE 2010 MS3 - How-To's 160 10-07-2018 09:17 PM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
Where is the Steering angle senor (SWAS)?? magoo MazdaSpeed 3 - How-To's 61 12-28-2011 12:07 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.60038 seconds with 32 queries
