 Old 07-22-2015, 09:42 AM   #1
dinoxor's Avatar
Posts: 346   (View Stats)
dinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the world
Default Stratified e85 flash tune log review
Recently purchased an e85 flash tune from Stratified and was wondering if anyone sees anything out of the ordinary.
I should have held it longer to 6500 rpm but the road wasn't long enough but at least it was nice and even
The first attachment is the pretty version of the logs where the
bolded the section represents WOT and the
highlighted rows that I think may be of concerned (hpfp and knock)
The second attachment is the raw csv
Everything else seems normal but just wanted some input is all
Thanks!
Black Mica 2008.5
CS SRI+TIP • AT HPFP • TP
dinoxor is offline   Reply With Quote
 Old 07-22-2015, 11:48 AM   #2
The HPFP is fine and fuel trims look good. Boost and loads are in check.
The bit of spool up knock is due to the warm temperatures (BATs and IATs) but it is minor and it's not something concerning at that level. The rest of the run is clean.
dinoxor (07-22-2015), thepatient77 (07-22-2015)
 Old 07-22-2015, 12:52 PM   #3
dinoxor's Avatar
Thanks, I really appreciate the input!
If funding is available around tax season, I may just jump the gun for a real tune!
Black Mica 2008.5
The Stratified Flash Tune (Formerly S-OTS PLUS) Lex Stratified Automotive Controls 312 02-26-2016 12:55 PM
Stratified Flash Tune (Formerly S-OTS+) V2.0 Lex Stratified Automotive Controls 66 05-28-2015 04:21 PM
Stratified S-OTS+ vs. Hypertech Flash Tune Review tfusch4 Stratified Automotive Controls 22 03-21-2015 11:46 AM
Stratified E85 Flash Tune (formerly S-OTS+ E85) jtday Stratified Automotive Controls 0 12-15-2014 05:54 PM
Stratified (Lex) Tune! (330/393 VD) psychophyr Stratified Automotive Controls 11 02-23-2012 04:39 PM
Page generated in 0.23638 seconds with 22 queries
