| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
(Thread Starter) | This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread. Mazdaspeed Forums Spark Plug Index Database Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28 Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug Heat Range Conversion Chart Code: HKS 25 30 35 40 45 50 52.5 55 DENSO 16 20 22 24 27 31 32 34 NGK 5 6 7 8 9 10 10.5 11
NGK Copper Plugs LZTR4A-11 (5306) LZTR5A-13 (4306) BKR7E
| The Following 12 Users Say Thank You to Haltech For This Useful Post: |
Groans: 370
| Not Ranked : 0 score Heh, was about to correct you on the gap. Also perhaps we should sort them by Iridium/Platinum/Copper etc and list a link/price? Great idea though. why preferrably between .03 and .032? I jsut gapped mine to .028 dammit!!! lol |
Groans: 370
| Not Ranked : 0 score Autolite APP5364. Stock heat range as far as I can tell - Platinum - $3.99 AutoZone.com | Shopping | Parts | Product Detail - Spark Plug |
(Thread Starter) | We want colder stage plugs please. We can find stock plug applications all day long, but this isn't why this database is being created. You also do NOT want to be running platinum plugs in boosted applications. Big NONO.. Copper or Iridium plugs only please. Thanks!
![]() Join Date: Mar 2008 Location: Phoenix
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,548
| Not Ranked : 0 score yeah i have always heard the same thing. |
Groans: 370
| Not Ranked : 0 score How is platinum a big no no. WRXs come with them stock |
(Thread Starter) | They are junk in high boost... the electrode usually falls right off into the cylinder because they cant handle constant heat temps that boosted engines put out. Platinum work great in NA stock applications and can take day to day abuse... until you boost them.
Groans: 370
| Not Ranked : 0 score Thanks for the info. Guess I need to change mine again, LOL. At least they were only 16 bucks. Hope we can find some copper ones in the right size. |
(Thread Starter) | Im trying to get some copper numbers, but so far, im having no luck. Hopefully when NGK answers my email, i can get some numbers.
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score sub
__________________ |
Groans: 370
| Not Ranked : 0 score 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug. some useful info: for those looking for a traditional NGK copper core spark plug..... |
| Not Ranked : 0 score here are the specs of the NGK LTR7IX-11 (6510) Iridium IX Plug, 14mm Thread, 25mm (.984") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .044" (1.1mm) Gap |
(Thread Starter) | He should have tried the BR7 series as they are resistor plugs... I run BR7EFs in my truck, which are 2 stages colder than stock.
Groans: 370
| Not Ranked : 0 score yeah good call. i just quit at this whole spark plug thing, lol |
![]() Join Date: Mar 2008 Location: Planet Earth, v3.7
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score Not trying to jump off topic or anything, but would there be a greater benefit to going 2 stages colder plugs? I was gonna go colder, but haven't heard of the 2 steps colder plugs till now. I am mild to heavily (at least soon to be) modded.
__________________ The fastest MS3 in the whole garage... |
(Thread Starter) | 2 stages will make you idle a little more rough but will be fine.. You will lose a bit of power with stage 2 plugs, over stage 1, but your safety margin is greater.
Groans: 370
| Not Ranked : 0 score If a plug is too cold, will it foul easier/faster? |
![]() | | #19 | ![]() |
(Thread Starter) | 2 stages isnt cold enough to cause fouling. Not with 20 psi of boost.
| The Following User Says Thank You to Haltech For This Useful Post: | aaronc7 (05-19-2008) |
![]() | | #20 | ![]() |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Here is some initial work. IMO, the stock plugs for the STi and EVO9 are excellent and should be used where possible. Although, I do like copper plugs due to them being less expensive. The below picture has (from left to right) the MS3 stock 6 temp range plug, a 7 temp range plug for the EVO9, and a 7 temp range plug for the STi. Unfortunately, the STi and EVO9 plugs do not seat against the head the same! Otherwise, these would be excellent stock MS3 replacements. The ILTR6A stock MS3 plug is gapped at ~.031" from the factory. The LFR7AIX Iridium STi (one range colder than stock) plug is gapped at ~.029" from the factory. The ILFR7H Laser Iridium EVO9 plug is gapped at ~.022" from the factory. A few things to note, the different plug MFGs use different numbers for temperature ranges. For NGK and Denso, the higher the number the colder the plug (or the more heat the plug pulls from the combustion chamber and transfers to the head/coolant passages). Temperature ranges of 6 and 7 should be fine choices for most cars. You cannot easily adjust the gap on platinum, iridium, or laser iridium plugs without scratching off the special coatings that make these plugs so expensive...so please be careful. We should be able to find a good replacement spark plug soon, and we will have better input once we analyze the stock used plugs that are being shipped to us by customers. Christian. |
![]() | | #21 | ![]() |
(Thread Starter) | From NGK...
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |||
| The Following User Says Thank You to Haltech For This Useful Post: | Ferdball (05-22-2008) |
![]() | | #22 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score So .036 reduction is the least safest with iridium. Copper would be best then, as said before lol. |
![]() | | #23 | ![]() |
I said on US (backwards) the HKS 50003-M40LF is a heat range of 8, so it's 2 step colder not stock need to edit that first post lol. And don't forget the itv27 3 step colder (or 3.5). Sorry off topic. I really don't like US (backwards) due to a wholesale account not getting done with them. I buy my stuff from PG now. I had $10,000 to do an initial buy from them, so now I'm spending it at PG. And will be coming to this forum more often also. :friday: | |
![]() | | #24 | ![]() |
Groans: 370
| Not Ranked : 0 score Anyone know what the Denso itv-20/22/24s are gapped at? |
![]() | | #25 | ![]() |
| Not Ranked : 0 score itv20 1.1mm or .044 can gap down to .036 itv22 0.8mm or .032 can gap down to .024 itv24 0.8mm or .032 can gap down to .024 itv27 0.8mm or .032 can gap down to .024 |
![]() | | #26 | ![]() |
Groans: 370
| Not Ranked : 0 score Awesome, looks like the ITV 22/24/27 will work great for us |
![]() | | #27 | ![]() |
(Thread Starter) | What heat range is the 27? 3 stage colder or 4?
![]() | | #28 | ![]() |
| Not Ranked : 0 score I'm guessing 3.5, since they are increamenting 2 numbers per 1 heat range number. |
| The Following User Says Thank You to bioevolve For This Useful Post: | Haltech (05-22-2008) |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
| Not Ranked : 0 score Heat Range Conversion Chart HKS 25 30 35 40 45 50 52.5 55 DENSO 16 20 22 24 27 31 32 34 NGK 5 6 7 8 9 10 10.5 11 * Above information is just for reference
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 |
| The Following User Says Thank You to whoosh@Realtune For This Useful Post: | Haltech (05-22-2008) |
![]() | | #30 | ![]() |
M35LF is 7 heat range - 1 step colder M40LF is 8 heat range - 2 step colder | |
![]() | | #31 | ![]() |
(Thread Starter) | fixed
![]() | | #32 | ![]() |
| Haltech's Personal Bitch ![]() Join Date: May 2008 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Do we have any answers as too which are the best plugs to run when upping the boost? |
![]() | | #33 | ![]() |
Groans: 370
| Not Ranked : 0 score denso itv22 recommended by me! |
![]() | | #34 | ![]() |
(Thread Starter) | Denso hands down.
![]() | | #35 | ![]() |
(Thread Starter) | Bump
![]() | | #36 | ![]() |
Groans: 370
| Not Ranked : 0 score at what point do you all think 2 steps colder should be used? |
![]() | | #37 | ![]() |
Groans: 102
| Not Ranked : 0 score I like my ste2 colder, I had requested 1 step colder but got 2 step does this cost power? Car runs great, but am I losing a tad of power with the 24 vs 22?
![]() | | #38 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score sub |
![]() | | #39 | ![]() |
| RIP May 9th, 2012 ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score any sources on the Denso Iridium itv-24 - 2 stage colder heat range plugs? haven't had much luck locally |
![]() | | #40 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
Optionsauto.com <-- got mine here
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 08-24-2009 at 08:53 PM. Reason: MSF Database - Automerged Doublepost | ||
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/spark-plug-database-colder-than-stock-stage-5691/ | ||||
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 01:14 PM | |
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 06:57 AM | |
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 03:39 AM | |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
| Spark Plug Gap | khaydin | Cobb Access Port/Maps | 5 | 12-01-2008 10:17 PM |
| HKS spark plugs installed *2 steps colder than stock | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 10-02-2008 02:15 PM |
| Spark plug gap | Jesse MS3GT | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-16-2008 04:53 PM |
