| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #161 | ![]() |
![]() Join Date: Jul 2012 Location: Keller, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
| Not Ranked : 0 score I do have one question, however. Bucker's ATR guide suggests changing all the 80 values in the DBW tables to 90. Have you tried that on these tables? I haven't tried that yet but I may this weekend. My car runs so well with your current DBW tables that I am hesitant to alter them. BTW...I went to the Austin F1 race last year. It was so amazing! I will have to upload some of my videos. I so want to get my car on that track! I have had my car on Texas Motor Speedway, but only for charity and everyone had to stay below 30. I did do a ride along out there a few years ago. 170 around the turns there is a very weird sensation! @El Beaner - Ah...XDA Developers! I used to spend so much time on that site back in the early Windows Mobile days. Thanks again @snailD for all your work. If you do ever make it to DFW, I'll meet up with your and El Beaner.
__________________ 2010 Celestial Blue Speed 3 - FREEKTUNED - Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's |
![]() | | #162 | ![]() |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
| Not Ranked : 0 score ![]() This may be a stupid question, but I'll ask anyway - better safe than sorry! I should still be able to use these tables without incident if my tuner is limiting the throttle plate in a few areas to control load, right? I don't want to screw up his map... Thanks!
__________________ pedal2plastic.wordpress.com The driving game blog Liquid Silver 2011 Mazdaspeed 3 w/ Tech Package Cobb: AP, SRI & RMM Corksport: TIP, TMIC, RP,SSP Autotech Internals Bilstein PSS Coilovers SPC Rear Camber Arms JBR RSB Gram Lights 57F - 18x8.5 +45 Rfinkle2 tuned @21psi |
![]() | | #163 | ![]() |
I really like how my throttle behaves with the agressive DBW table, along with my own APP table. When I finally get an e-tune, I will be asking my tuner to incorporate these settings.
__________________ 2010 Celestial Blue Speed 3 - FREEKTUNED - Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's | |
![]() | | #164 | ![]() |
![]() Join Date: Oct 2013 Location: Ponder, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score Wow, what a difference the new DBW tables made. From a stop to get going in first is much easier now and doesn't feel like it wants to take off on me. Much easier to control. Power is there in all the gears when you command it but no where near as soon as the aggressive tables. I updated the Stage 1 OTS map along with the Stage 1 CS sri+tih map. Have 4 of each SnailD relaxed SnailD relaxed + pfp's APP SnailD Aggressive SnailD Aggressive + pfp's APP Right now driving with Snails relaxed(post thread update) and and so far it is my favorite of all the iterations I've done(pre update). So in regards to APP settings, the lower the figure the more you have to press to get it to respond, is that correct? Or is it the opposite - the lower the figure the less you have to press?
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 |
![]() | | #165 | ![]() |
![]() | | #166 | ![]() |
This might make the APP tables easier to understand. If you were to make a graph using 1 - 20 (representing the 20 cells of APP values) on the Y axis, and 0 - 100 (representing the amount of pedal pressure applied) on the X axis, it would look just like the movement of the gas pedal on the car. You could, in theory, start with larger values in the first few cells and arc them toward 100 through the remainder of the cells so that your pedal requires more initial pressure to acheive the desired pedal pressure results. Or, lower initial values for more sudden pedal response. Once you are satisfied, you can load the values into your APP tables and see how it feels. I hope this helps.
![]() | | #167 | ![]() |
![]() Join Date: Oct 2013 Location: Tyler, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 272
| Not Ranked : 0 score Ok, sweet, I think I am finally not confused and I am about to update the Map that I have with this on it. Thanks for all the work everyone.
__________________ 2013 Liquid Silver MazdaSpeed Installed Parts:: HTP 3" SRI, Autotech Internals, CP-e Catless DP, CP-e TMIC, FreekTuned, H&R Springs, JBR RSB, Cobb AP V3, JBR 88 RMM, JBR Battery Box, EGR Delete, various CorkSport styling parts, and other things Not Installed Parts:: JBR Stage 2 OCC Future Parts:: JBR 80 PMM/TSM, Coilovers, and much more [SIGPIC][/SIGPIC] ![]() |
![]() | | #168 | ![]() |
__________________ pedal2plastic.wordpress.com The driving game blog Liquid Silver 2011 Mazdaspeed 3 w/ Tech Package Cobb: AP, SRI & RMM Corksport: TIP, TMIC, RP,SSP Autotech Internals Bilstein PSS Coilovers SPC Rear Camber Arms JBR RSB Gram Lights 57F - 18x8.5 +45 Rfinkle2 tuned @21psi | |
![]() | | #169 | ![]() |
| Not Ranked : 0 score If you could let me know what he thinks I would appreciate it. Sent from somewhere...but not here.
![]() | | #170 | ![]() |
| Not Ranked : 0 score Sure thing - I'm sure the poor guy has a full inbox...the price you pay for being as smart/generous of a guy as Rob is.
![]() | | #171 | ![]() |
![]() | | #172 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
(Thread Starter) | Not Ranked : 0 score if you leave the cells in the 1.5-2.0 load region the same as your tuner has it things wont change. copy and past the whole file over into DBW A, then go into dbw B and copy 1.5-2.0 load cells and paste them into at at 1.5 load back in A. then blend them with interpolation vertical (highlight and right click). now copy that whole table and paste it into B and C
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #173 | ![]() |
| Not Ranked : 0 score Ran a 4th gear log today using SnailD's relaxed throttle tables/APP Can anyone tell me if they see anything wrong - I saw a little KR at the beginning and then around 5k rpm but not sure if that was attributed to the road or another issue.
![]() | | #174 | ![]() |
![]() Join Date: Aug 2012 Location: Columbia MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Color me completely confused still. I had copied all the tables, aggressive and mile, to Google Docs after Snail made the corrections awhile back. I just went back and grabbed them again to make sure I had the correct ones. The mild tables in the OP currently did not match what I had for aggressive or mild previously. The ones in the OP at the moment, for example, have an APP table that lands in between the aggressive and the mild I had copied before. Oh well, going to toss the new OP mild on the car tomorrow and see how it feels.
__________________ Mike [SIGPIC][/SIGPIC] |
![]() | | #175 | ![]() |
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 | |
![]() | | #176 | ![]() |
| Not Ranked : 0 score Well I'll be giving it a spin tomorrow. I really enjoyed what I had from him before as the mild build. Gonna try this one though. Who knows.
![]() | | #177 | ![]() |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
![]() | | #178 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score I toned down the "soft" map in the first page, and it's better now, but still find myself boosting all over the place. I'm not sure what affects this phenomena more - the APP or the DWB table.... I agree with the APP being a completely linear function, more or less like a normal throttle body would be, so perhaps it's the DWB table that needs to be even more tuned down. TBH, I'm more worried about heel-and-toeing than regular driving around, as the throttle is much harder to modulate when you're working the brakes with the same foot, and a very progressive throttle could make for a diaper-bound experience.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #179 | ![]() |
After looking at my 4th gear log more, I notice that my pedal poistion is 60% and I am at WOT (throttle position - 76% already) Not sure if that could pose issues. Once I get my intake, I am going to do a Freek OTS tune and hopefully it has ok throttle response.
![]() | | #180 | ![]() |
First, I would suggest using snailD's relaxed DBW table. It is supposed to be similar to stock without the "wall." Second, I would take snailD's relaxed APP table, put it in excel, and multiply the entire table by 1.5, except for 0 and 100. Or, perhaps just multiply against the first 5 or 6 cell. This should result in a need for more pedal pressure to accelerate, either through the full range or just initially. You can experiment with the multiplier to get your desired feel. That's what I did. Sent from somewhere...but not here.
![]() | | #181 | ![]() |
the app is like a percentage of the dbw. if u stopped the app at 10% the car wouldnt go anywhere because the ecu would say the pedal is only at 10% when it was really wide open. the dbw table is what is actually telling the tb what to do, the app is the direct pedal to dbw relationship
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
![]() | | #182 | ![]() |
5th row down, it goes 3.96 for columns 1-4, then 4.08, then 4.20 then back to 4.00 for columns 7-10 and then start of row 6 is 4.5 Not sure if that is intentional or something that should not be there - on your aggressive table it happens more throughout in the first 7 rows as well.
![]() | | #183 | ![]() |
![]() | | #184 | ![]() |
| Not Ranked : 0 score My fault lol - I started messing around with ATR and another DFW NATOR mentioned this thread and well, here we are.
![]() | | #185 | ![]() |
![]() | | #186 | ![]() |
I like your maps and I'm just saying I will need to adjust them a bit for my driving style. You did great work and now folks can use a great base to adapt into their maps and adjust as necessary. Many many thanks, btw.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ | |
![]() | | #187 | ![]() |
| Not Ranked : 0 score Ok, so I do like the "new" mild APP tables a little more. Gives a little more pep right at tip in then acts just like it used to.
![]() | | #188 | ![]() |
| Not Ranked : 0 score So, not for nothing but here is my version of snailD's "relaxed" DBW Table, a bit smoothed out: Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.50 1.50 1.50 1.50 1.50 1.75 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.00 2.25 2.25 2.25 2.25 2.50 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.25 3.25 3.25 3.25 3.50 4.00 4.00 4.00 4.00 4.00 4.00 4.00 4.00 4.00 4.00 4.50 4.50 4.50 4.50 4.75 5.25 5.25 5.25 5.25 5.25 5.25 5.25 5.25 5.25 5.25 5.75 5.75 5.75 5.75 6.25 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 6.75 7.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.25 8.75 9.75 9.75 9.75 9.75 9.75 9.75 9.75 9.75 9.75 9.75 10.00 10.00 10.00 10.00 10.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 11.50 12.50 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.50 13.50 13.50 13.50 14.50 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.50 15.50 15.50 15.50 16.00 16.75 16.75 16.75 16.75 16.75 16.75 16.75 16.75 16.75 16.75 17.50 17.50 17.50 17.50 18.00 19.00 19.00 19.00 19.00 19.00 19.00 19.00 19.00 19.00 19.00 21.00 21.00 21.00 21.00 21.50 22.50 22.50 22.50 22.50 22.50 22.50 22.50 22.50 22.50 22.50 25.00 25.00 25.00 25.00 26.25 27.00 27.00 27.00 27.00 27.00 27.00 27.00 27.00 27.00 27.00 29.50 29.50 29.50 29.50 31.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 34.50 34.50 34.50 34.50 36.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 39.50 39.50 39.50 39.50 41.00 42.00 42.00 42.00 42.00 42.00 42.00 42.00 42.00 42.00 42.00 44.50 44.50 44.50 44.50 46.00 47.50 47.50 47.50 47.50 47.50 47.50 47.50 47.50 47.50 47.50 49.50 49.50 49.50 49.50 51.50 53.00 53.00 53.00 53.00 53.00 53.00 53.00 53.00 53.00 53.00 54.50 54.50 54.50 54.50 56.50 58.50 58.50 58.50 58.50 58.50 58.50 58.50 58.50 58.50 58.50 59.00 59.00 59.00 59.00 61.50 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 64.00 66.50 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 69.00 71.00 73.00 73.00 73.00 73.00 73.00 73.00 73.00 73.00 73.00 73.00 72.50 72.50 72.50 72.50 74.50 76.00 76.00 76.00 76.00 76.00 76.00 76.00 76.00 76.00 76.00 74.00 74.00 74.00 74.00 76.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 74.00 74.00 74.00 74.00 77.00 79.00 79.00 79.00 79.00 79.00 79.00 79.00 79.00 79.00 79.00 74.00 74.00 74.00 74.00 77.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 74.00 74.00 74.00 74.00 77.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 74.00 74.00 74.00 74.00 77.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 74.00 74.00 74.00 74.00 77.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 74.00 74.00 74.00 74.00 77.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 80.00 I've played with the boost tables a bit of course, to make sure my WGDC isn't ramping up too quickly. One thing I noticed was the APP Translation - Speed Comp table. For some reason, even the stock map has it set up so that it targets a multiple of the requested boost, based on speed and throttle position, up to 130% at low APP (up and down is APP, left to right is speed in mph, 0 to 49): Code: 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.30 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.20 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.10 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 Below is DBW table graph pic:
![]() | | #189 | ![]() |
![]() | | #190 | ![]() |
![]() Join Date: Mar 2013 Location: Quebec
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 153
__________________ Mazdaspeed 6 2007 Velocity Red //Cobb AP//CS SRI-TIP//Forge BPV V2//CS Boost/recirc.hoses//Magnaflow CB//Custom Testpipe//CS OCC//EGR delete//CS RMM+TMM Insert//TurbineTech diff.bushing//CS Mudflap//CS Short shift//CS SS clutch line//Oilfilter convertion//OEM Blockheater..lol// //Custom vent Boost gauge//6000k Foglight//AUX input// Next://CP-E safe seal//JBR IM Thermal gasket//CS hpfp// |
![]() | | #191 | ![]() |
| Not Ranked : 0 score Is anyone experiencing more KR with the throttle map update, or did I just get a really bad tank of gas? I know it doesn't make sense, since all it is, is opening the throttle more or less aggressively but... No other changes except this were made, so I gotta ask. Feel free to flame =\
![]() | | #192 | ![]() |
![]() | | #193 | ![]() |
![]() | | #194 | ![]() |
| Not Ranked : 0 score Yeh.... I figured. I'm grasping at straws here, gonna have to revisit all maps and check sensors.
![]() | | #195 | ![]() |
Driving to and from work, same route and similar driving habits, with your throttle table I would see KR in 1st and 2nd gear at times in the 1.5-2 range but that was just normal driving and a peak of 3.5 during a right hand turn(TCS and SWAS not disabled - could have been the cause of the higher number). At WOT I would not see those KR numbers. With the stock OTS map, highest KR I saw driving around was .89 and I did see a 1.69 while making a right hand turn in second gear(did not have TCS or SWAS disabled so both could have been the cause). This probably won't matter either but highest boost I would see at WOT in 3rd/4th was around 16.2psi and with the stock OTS I hit 17.05psi today(which is a first for me seeing boost in the 17 range).
![]() | | #196 | ![]() |
![]() | | #197 | ![]() |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Those DBW and APP tables are like ice cream in summer : soooooooo nice ![]() I was a bit hesitant to play with the DBW and APP tables because my APP redaing are fucked (I have a reading of 31% at idle, and a max of 76% at WOT)...but I loaded this on my CX-7, and it feels like the beast came to life!!! Just made a small change to the 1st gear APP table (its funny to see how wicked the CX-7 tuning is : gear 1-2-4-5-6 APP are all the same, but 3rd gear APP is a lot more softer)
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
![]() | | #198 | ![]() |
![]() Join Date: Jan 2014 Location: Issaquah, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
| Not Ranked : 0 score I know I'm stirring the old thread pot here but this should be a sticky in both the gen1 and 2 tuning forums. I'm currently running stage 2 cobb ots and had the same issues alot of other people had with that map underboosting like crazy. Im sure it had something to do with me bumping the wastegate table a bit but this throttle table fixed everything I hate about the stage 2 map in terms of mushiness. @Raider;
__________________ 2007 MS3/Black Mica/JBR 3.5 Aluminum Whale Penis/CP-E catted downpipe/JBR EBC/JBR EGR Blockoff/CX Racing BOV/Corksport cat back exhaust/Cobb lowering springs/AP Tuner/ Stage 2 -self tooned (E85 Stratafied Stage 2 tune for fun days)/JBR 88a RMM/shaved hatch/corksport mudflaps/Dip'd rims/aftermarket boom boom box |
![]() | | #199 | ![]() |
| Not Ranked : 0 score Discuss: SnailD's Throttle Table Fix |
| SnailD's High Altitude OTS Maps | snailD | 2010 MS3 - ECU Computer Tuning | 123 | 08-27-2019 09:43 PM |
| SnailD's Throttle Table Fix | snailD | 2010 MS3 - ECU Computer Tuning | 250 | 11-16-2017 02:09 PM |
| Snaild on corn | snailD | 2010 MS3 - Dyno Sheets/Discussions | 13 | 11-23-2012 10:58 PM |
