Like Tree11Likes
 Old 06-24-2014, 11:56 AM   #201
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Originally Posted by kashbringer View Post
Need info on how to build the trigger circuit. Bought a "used" kit and it didn't come with it. Kit was wired like a new one and is only reading 1/4th of actual RPM... so yeah. Any help would be appreciated.
you wired all 4 coilpacks in? set it to 4 cyl 4 stroke?
if all the connections are soldered well and the ground is good, you can call splitsecond.
they were helpful in my install.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-24-2014, 12:01 PM   #202
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
The left wire is tapped only on the 4th coil pack like a newer kit.. Kozmic motorsports installed the kit so it's done right but the split second box dosent have the trigger circuit in it like the new kits have. I need one so I can tap all the coil packs to the coil circuit then to the box.
Sent from my SCH-I605 using Tapatalk
Edit.. also it's In 2 cylinder 2 stroke mode like perm recommends. Bringing up the R4 software and looking at rpm it only shows 250 at a 1000rpm idle.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
The Following User Says Thank You to kashbringer For This Useful Post:
mxlplx71 (06-24-2014)
 Old 06-24-2014, 12:52 PM   #203
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Pretty sure your problem is that it is only attached to one coil pack...I am almost positive it needs to be attached to all 4 coil packs.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
 Old 06-24-2014, 01:03 PM   #204
Yes, you are correct. But to do that and have it work I need a trigger circuit like in the original post. I don't have one, so i'm asking if anyone knows how to make one. Dj is pretty busy now a days and im just asking around. 4 coil packs to coil circuit to SS box is how this one needs to be.. New boxes are just 1 coil pack to the box.
Tuned by Voltwings
 Old 06-24-2014, 01:11 PM   #205
mtnrunner's Avatar
I have a new box and it is wired to all 4 coil packs. does your ss controller have 4 yellow wires with black stripes?
 Old 06-24-2014, 01:30 PM   #206
Only one yellow and black wire on mine.
Tuned by Voltwings
 Old 06-24-2014, 01:50 PM   #207
mxlplx71's Avatar
Groans: 128
i wonder if you splice in all 4 coils to that one wire if it would read full rpm.
i use 2cyl 2stroke also.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-24-2014, 04:52 PM   #208
Ziggo's Avatar
Posts: 3,843   (View Stats)
It would make all the plugs fire when any single plug was triggered, and based on DJ's findings there isn't a strong enough pull down on the AIC so it would probably just trigger all the plugs to fire continuously, never letting the coils charge.
Tldr; NO
Each signal needs to be fed through a diode then soldered to the single wire to make an OR circuit of sorts. Then add a pull down resistor to the single wire, I think 1kohm is what DJ used.
Ask Me About My:
 Old 06-24-2014, 04:58 PM   #209
mxlplx71's Avatar
Groans: 128
Tldr; NO
yea it would suck to have all 4 continuously firing out of time.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-25-2014, 01:25 PM   #210
Thanks for all the help guys. Looks like I lucked out and the guy i got the kit from found the trigger circuit! Ready to get this thing goin!
Tuned by Voltwings
mxlplx71 (06-25-2014)
 Old 02-09-2015, 11:15 PM   #211
Airman3454's Avatar
Posts: 567   (View Stats)
Airman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the world
Ordered the Kozmic kit and along with my Cobb piping I figured I might have a space issue with the 2 additional injector piping. Does anyone know if I can extend the cold side approx 6 inches or not? Any ways around this?
Airman3454 is offline   Reply With Quote
 Old 02-10-2015, 06:43 PM   #212
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
You picked the wrong piping kit. Cobb is jampacked near the throttle body area.
 Old 02-17-2015, 06:52 AM   #213
speed3gen1's Avatar
Posts: 139   (View Stats)
speed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the world
I have the kozmic kit installed with cobb piping and I had to do major re routing to get it to work this was the outcome
speed3gen1 is offline   Reply With Quote
The Following User Says Thank You to speed3gen1 For This Useful Post:
09TrueRedGTX (02-17-2015)
 Old 02-17-2015, 08:30 AM   #214
Ziggo's Avatar
I put a 5th port on my cobb kit. The pictures are somewhere in this thread I think. The key is to have a new pipe into the throttle body fabricated with an injector bung welded on and move the BPV to the hot pipe.
Ask Me About My:
Mauro_Penguin (02-24-2015), speed3gen1 (02-17-2015)
 Old 03-23-2015, 07:24 PM   #215
Airman3454's Avatar
So I just got the SS controller and lines hooked up and when I plug the serial to usb up and run the split second program, it will not show any connection. Is this normal until I upload a fuel map?
 Old 03-23-2015, 08:58 PM   #216
mxlplx71's Avatar
Groans: 128
Make sure you have a good ground, I had to try two different cables also.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Mauro_Penguin (03-25-2015)
 Old 07-08-2017, 10:20 AM   #217
irissanen's Avatar
Posts: 89   (View Stats)
irissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond reputeirissanen has a reputation beyond repute
Hi,
Sorry to bring up an old thread.
Having just purchased 6th port fuel kit from Speed Performance, does anyone have an example of the fuel map they have used in the Split Second AIC1 controller? I am wondering what is the recommended ratio of fuel between the stock direct injectors and the aux injectors? I thought to start with constant 5 ms injection pulse times in the map (above 3.5V MAF and above 4500 rpm) but would you recommend something else?
I am running E37.5 blend at the moment but I am planning to bump it up to E58.5 once I get the aux fueling system installed. I am seeing ~12 ms (at 6500 rpm) injection pulse times with my current map w/o aux fueling. Dwell time multiplier is set to 0.95
SPEED PERF6RMANC3 Secondary Injection Fuel Kit For Mazda MZR-DISI - SPEED PERF6RMANC3
My mods: http://www.mazdaspeedforum.org/forum/forum/f511/finland-has-fast-mazdas-too-191514/
irissanen is offline   Reply With Quote
 Old 07-08-2017, 10:45 PM   #218
Etipp98's Avatar
Originally Posted by irissanen View Post
Hi,
Having just purchased the 6th port fuel kit from Speed Performance, does anyone have an example of the fuel map they have used in the Split Second AIC1 controller? I am wondering what is the recommended ratio of fuel between the stock direct injectors and the aux injectors? I thought to start with constant 5 ms injection pulse times in the map (above 3.5V MAF and above 4500 rpm) but would you recommend something else?
if this is something you are not familiar with i suggest contacting a tuner to do this. My maps have always started with .8 or so in the Cells and progressively went higher. Some injectors will not fire at .5 and lower.
CMajor likes this.
 Old 07-09-2017, 02:19 AM   #219
irissanen's Avatar
Thanks for the tip but I have built and tuned the car myself. I want to learn. Would you mind posting a screen capture of your map?
0.8 would be 0.8ms so 5ms is much higher than that.
Did a bit of Excel calculations. If I want to drop the stock DI duty cycle to <100% which means under 9ms pulse width at 6500rpm, I need to use about x ms (EDIT) pulse width for the aux injectors in order to keep the same AFR and account for the additional ~15% higher flow required by the thicker E blend. This gives about xx% DC for the aux system and a ratio of 65%/35% between DI/AUX when it comes to total flow. Does this seem sensible?
 Old 07-10-2017, 03:42 AM   #220
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Did a bit of Excel calculations. If I want to drop the stock DI duty cycle to <100% which means under 9ms pulse width at 6500rpm, I need to use about 16ms pulse width for the aux injectors in order to keep the same AFR and account for the additional ~15% higher flow required by the thicker E blend. This gives about 87% DC for the aux system and a ratio of 65%/35% between DI/AUX when it comes to total flow. Does this seem sensible?
stratified used to have a calculator on their website for setting up their maps.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 07-10-2017, 04:48 AM   #221
irissanen's Avatar
Stratified R4 Calculator
Thank you, this is great help!
Ok, now that I got the correct values from the calculator, I copy/paste them into the R4 fuel map. Values look right until I close and reopen the customer file, which after all the values get rounded down to the closest integer! Any idea why and how to fix it?
EDIT: Split Second customer support was very fast and helpful. The problem was related to Windows language/location settings. Now that I set it to English(US), R4 retains the full 0.1ms resolution.
The Following User Says Thank You to irissanen For This Useful Post:
Yamahafreak (10-08-2018)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/rough-install-guide-5th-port-injection-kits-118264/
I have some turbo cores on their way! | SHO Forum This thread Refback 11-02-2015 04:56 PM
Because everyone in here is going to secretly watch F&F6 :D TURBLO*chat* - Page 59 - Club RSX Message Board This thread Refback 06-15-2013 06:55 AM
I have some turbo cores on their way! - SHOForum This thread Refback 11-20-2012 08:50 PM
Port Injection for 2012 Realgib3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 12-19-2011 03:11 PM
Port Injection Question 6-Speed-6 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 08:02 PM
port injection head cbspeed3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 54 06-28-2009 10:39 AM
New kits with new parts from devilsown injection DevilsOwn MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 30 04-06-2009 11:50 PM
AEM Water/Meth Injection Kits In Stock Performance Racing Mazdaspeed3/6 General Discussion 3 04-10-2008 05:09 PM
Page generated in 0.42000 seconds with 29 queries
