| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #41 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score ![]() DJ FTW!!! PS - F&*K meth.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| The Following 3 Users Say Thank You to Alpha For This Useful Post: |
![]() | | #42 | ![]() |
(Thread Starter) | Not Ranked : 0 score When your built... there's no reason not to now. Clean install Chris. Has anyone else installed? I've failed at the tuning video so far... but will seriously make it happen soon. It's very straight forward... and only one way of approaching it. I'm sure once more people start running this kit, alternative approaches will pop up (namely you ziggo, haha).
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score I'm still working on getting that damn lid off. My tranny mount fiasco set me back a couple of days for getting that tool. I have to order it since no one carries it |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #44 | ![]() |
And crazy no autozone has that tool..... oh well.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #45 | ![]() |
Groans: 125
| Not Ranked : 0 score Whats Chris's name? |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score bcmurphy.
![]() | | #47 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score My approach was supposed to be even more simple. The real baller setup is going to be a PI setup like pablo. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #48 | ![]() |
The fifth port seems to be working pretty good IMO. And it's much less complicated.
![]() | | #49 | ![]() |
| Not Ranked : 0 score I never heard that spraying on a closed valve was bad for power except for here. From my learnin' it is a fuel efficiency/emissions concern. Spraying only when the valve is open helps mixing and atomization when flow rates are low like idle and low throttle, neither of which we care about here. Consider this: PI setups are routinely run to 80-90% duty cycle, and are only not run higher due to concerns over damaging the injectors. The intake valves are open for ~220* out of 720* so if you were to only spray on open valves you wouldn't run your duty cycle above ~30%, if you run to 90% 2/3 of your fuel is being sprayed on a closed valve. Food for thought. Zigatapatalka
| The Following 8 Users Say Thank You to Ziggo For This Useful Post: | Dano (07-17-2012), djuosnteisn (07-17-2012), doubleflusher (07-17-2012), InFeXIoN (07-22-2012), Micha (05-31-2014), phate (12-23-2012), pzr2874 (07-19-2012), uncorked11 (09-04-2012) |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have considered that. My only concern is that some cylinders will be sprayed with an open valve, while others are sprayed with a closed valve... and 2 in between. I just don't have any solid feel on what kind of cylinder to cylinder variation it would introduce.
![]() | | #51 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
Groaned at 30 Times in 25 Posts
| Not Ranked : 0 score 1,0000000 says PTP steals the idea, PATENT THIS BEYOTCH
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler |
| The Following 3 Users Say Thank You to J-Liss For This Useful Post: |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Ford already has a patent on using PI in tandem with DI for high load fueling. I looked into it ~2 years ago. Zigatapatalka
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | djuosnteisn (07-17-2012), J-Liss (07-17-2012) |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Would have to re-read to see if they made it general enough to cover TBI. Zigatapatalka
![]() | | #54 | ![]() |
Groans: 81
| Not Ranked : 0 score ^ so nice he posted it twice. cant he patent his design though? but i guess it would be pointless since it would need to be identical to even stir trouble.
| The Following User Says Thank You to J-Liss For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #55 | ![]() |
Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
![]() | | #56 | ![]() |
| Not Ranked : 0 score I believe Toyota also used both PI and DI.
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score are the valves for any particular cylinder closed for long enough to really matter? since this setup is only for high rpm, how much fuel would really be sprayed into the runner while the valve is closed?
| The Following User Says Thank You to Easter Bunny For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Toyota/Lexus has been on this for a while now with the IS and GS 350's 2GR-FSE engine Quote from an engine of the year award thingy-
White paper with more than you'd likely want to know.... -darn link keeps wanting to imbed the white paper, not just give me a link.... Code: http://www.scribd.com/doc/75062860/Toyota-2GR-FSE-GDI-PFI-Engine-Paper
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | djuosnteisn (07-17-2012) |
![]() | | #59 | ![]() |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post: | djuosnteisn (07-17-2012), TWOptSL0W (07-17-2012) |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Psssshhh... those clowns got it backwards. Supposed to say "PI engaged when pushing the DI well beyond it's design intentions". Seriously though, it's funny that they use DI only during high load.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | Easter Bunny (07-17-2012), Ziggo (07-17-2012) |
![]() | | #61 | ![]() |
Groans: 125
| The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post: | Dano (07-17-2012), djuosnteisn (07-17-2012) |
![]() | | #62 | ![]() |
Groans: 81
| Not Ranked : 0 score ^ explain yourself sir
![]() | | #63 | ![]() |
Groans: 125
the kit from autozone that chris got Last edited by TWOptSL0W; 07-17-2012 at 04:05 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #64 | ![]() |
| Not Ranked : 0 score so who needs the sst tool now lol |
| The Following User Says Thank You to bcmurphy87 For This Useful Post: | djuosnteisn (07-18-2012) |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Me i guess, hahaha. I have a local who's waiting on a filter sock and then needs to swap itfp's. It's nice to know the vatozone unit works well.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | bcmurphy87 (07-19-2012) |
![]() | | #66 | ![]() |
Groans: 125
| Not Ranked : 0 score dont forget to make yourself a new cap for the big hole you cut under the rear seat and mark it with something sharp |
![]() | | #67 | ![]() |
| Not Ranked : 0 score i got lucky i cut slits bent it back, removed and bent metal back into place. added weather stripping over cuts and sealed back up lol |
| The Following User Says Thank You to bcmurphy87 For This Useful Post: | djuosnteisn (07-19-2012) |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score You have to remove WAY more material on the 3's than the 6's. The 6's are just a hair too small. The 3's pretty much just have a hole to access the line and connector.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | bcmurphy87 (07-19-2012), Dano (07-19-2012) |
![]() | | #69 | ![]() |
I need some art work ![]()
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
![]() | | #70 | ![]() |
Groans: 125
| The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post: | Dano (07-19-2012), djuosnteisn (07-19-2012) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score because Nator NY graphic ? lol I'll give you that.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | bcmurphy87 (07-19-2012), djuosnteisn (07-19-2012) |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mine's just the old cover bolted back down, with a rag stuffed under it, hahahahahaha.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #73 | ![]() |
| Not Ranked : 0 score a la' molotov cocktail style....nice!
| The Following 4 Users Say Thank You to Dano For This Useful Post: | djuosnteisn (07-19-2012), doubleflusher (07-23-2012), PapaSmurf (07-19-2012), TWOptSL0W (07-19-2012) |
![]() | | #74 | ![]() |
Groans: 125
| Not Ranked : 0 score no because Nator NJ lol bahahahahahaha Last edited by TWOptSL0W; 07-19-2012 at 05:23 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #75 | ![]() |
| Not Ranked : 0 score oopps...sorry about the "Y" my bad! we all know Nator NJ is waaaaay better than Nator NY. Hell you guys will be the first into the 10s... bwahhhhhhhhh
| The Following 2 Users Say Thank You to Dano For This Useful Post: | djuosnteisn (07-19-2012), TWOptSL0W (07-19-2012) |
![]() | | #76 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score But wouldn't that just go back and forth ? 1-3/2-4 ? |
| The Following User Says Thank You to pzr2874 For This Useful Post: | djuosnteisn (07-20-2012) |
![]() | | #77 | ![]() |
(Thread Starter) | Not Ranked : 0 score Largely depends on how the SS controller is setup. In 4 stroke 4 cylinder mode, it fires every other trigger pulse, so once per crank rotation, or every other intake stroke. In 2 stroke 2 cylinder mode, it fires every trigger pulse, so twice per crank rotation, or once per intake stroke.... in which case i guess things would balance out just fine. 1 squirt per cycle means all cylinders receive equal "squirting", lol.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | pzr2874 (07-20-2012) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score so whos gona be first to install this?
| The Following User Says Thank You to superskaterxes For This Useful Post: | djuosnteisn (07-20-2012) |
![]() | | #79 | ![]() |
Groans: 125
| Not Ranked : 0 score as soon as my serial cable comes in, i can finish the install. aside from the pump, everything else should take about an hour DJ, does the injector boss have to be parallel with the ground with the injectors spraying down? Can it be sideways or not exactly straight? im concerned about the fitment a bit |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | djuosnteisn (07-20-2012) |
![]() | | #80 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Because racecar
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | djuosnteisn (07-20-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/rough-install-guide-5th-port-injection-kits-118264/ | ||||
| I have some turbo cores on their way! | SHO Forum | This thread | Refback | 11-02-2015 04:56 PM | |
| Because everyone in here is going to secretly watch F&F6 :D TURBLO*chat* - Page 59 - Club RSX Message Board | This thread | Refback | 06-15-2013 06:55 AM | |
| I have some turbo cores on their way! - SHOForum | This thread | Refback | 11-20-2012 08:50 PM | |
| Port Injection for 2012 | Realgib3 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 29 | 12-19-2011 03:11 PM |
| Port Injection Question | 6-Speed-6 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 07-16-2009 08:02 PM |
| port injection head | cbspeed3 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 54 | 06-28-2009 10:39 AM |
| New kits with new parts from devilsown injection | DevilsOwn | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 30 | 04-06-2009 11:50 PM |
| AEM Water/Meth Injection Kits In Stock | Performance Racing | Mazdaspeed3/6 General Discussion | 3 | 04-10-2008 05:09 PM |
