| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
(Thread Starter) | Not Ranked : 0 score Here is the issue the second log is when I hooked back up my meth 50/50 and targeted 12.4. What in the fuck is all I can say. 10's for AFR? Really? What the hell are you doing ECU? I assumed that because the meth is injected AFTER the maf that under WOT conditions you would see a few tenths richer than your target. In the past I was seeing maybe .5 or so richer from targeted. Interesting thing is that at my dyno the sniffer said 10.6 while my AP on the old tune and meth said 11.8. Funny today I see nearly the same AFR on meth as the sniffer saw a few weeks back. Is it even possible that the meth could drop my AFR's by 1.5? Need some ideas of where to start with this guys.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score I have no experience with with meth, nor that much with the Mazda platform yet. But I just wanted throw the idea of an o2 sensor out there.
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
| The Following User Says Thank You to Boost_creep For This Useful Post: | dsmluck (09-03-2011) |
| The Following User Says NO Thank You to Boost_creep For This Un-useful Post: | manelscout4life (09-04-2011) |
Groans: 60
(Thread Starter) | Not Ranked : 0 score If it was the 02 sensor I don't think my non meth tune would be spot on. I can connect and disconnect the meth and watch the same results happen. It may not be a tuning issue. Maybe my meth nozzle is screwed up and just dumping meth in at a higher rate. Right now I really don't know.
| Not Ranked : 0 score Hmm that is interesting. Sorry I couldn't be of more assistance.
![]() Join Date: May 2010 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score I would throw the meth away....top log looks excellent but I guess it's always good to squeeze the juice bottle a little harder. Good luck in trying to find that ams...problem beats me but def. meth is throwing of AFR....
__________________ 2008 MAZDASPEED 3 METRO GREY SOLD 2009 BMW 335i STOCK FOR NOW |
| The Following User Says Thank You to racingred For This Useful Post: | dsmluck (09-03-2011) |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score on an unrelated and unhelpful sidenote...your mass airflow is teh sexual intercourse
__________________ |
![]() Join Date: Sep 2009 Location: salem oregon
Rep Power: 187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Yes it can.
__________________ Boobs.....because you can't motorboat a personality. |
| Not Ranked : 0 score how about some more info like what meth kit and nozzle? Are you running a PRO tune for meth or for the 3076? Maybe try adjusting the flow rate if possible.
__________________ Boobs.....because you can't motorboat a personality. Last edited by YokiMazoku; 09-03-2011 at 11:42 PM. Reason: can't read :) |
| The Following User Says Thank You to YokiMazoku For This Useful Post: | dsmluck (09-04-2011) |
Groans: 60
So is it feasible to see a nearly 1.5 point drop in AFR from a 50/50 mixture and a 225 ml/m nozzle? If I am targeting 12.4 AFR on the meth and hitting mid to high 10's that would mean that I would have to target 14 AFR @ WOT to hit my 12 AFR target on meth. That sounds like it leads to a thread that starts with "motor" and end with "boom". Is that normally how people tune for methanol?
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph | |
| Not Ranked : 0 score Ops 3076r my bad. You know i dont have a good answer for you however if it were me with your current setup ( makes a big different ) i would try a smaller nozzle. I agree with you tho tuning for meth with you're current setup doesn't sound like the best idea. You can also try changing the mixture 75% water and 25% meth will fix your problem.
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score I would look further at the wmi kit you are running. Could be anything from the mix not atomizing properly to the placement of nozzle or the size of nozzle. Although the do5 should be ok. |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | dsmluck (09-04-2011) |
Groans: 60
On a side note I ran another log today in the cool morning temps. Hit nearly 25 psi (yikes) and 405 Maf g/s. Pull soo damn hard. Don't mind the AFR that was right after a flash and it settled to targeted levels a few minutes later. Also was getting spark blowout and some very minor knock.
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score yea i wouls pull the nozzle. I know on my aem kit there is a way to test the system and make it spray with driving the car. If snow has that feature pull the nozzle and watch the spray pattern. |
| The Following User Says Thank You to bcmurphy87 For This Useful Post: | dsmluck (09-04-2011) |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score man 400g/s at your altitude...fuckin awesome. sorry, I'm no help since i don't fux with meth. I'm kind of a purist. If you got good fuel, block off the EGR and just roll with trageting 12.0. DI ftw.
__________________ '08 CWP MS3 w/ T3 3071r |
Groans: 60
What do 3076r's put down for g/s normally at sea level?
Groans: 224
| Not Ranked : 0 score I would say your issue is a way too big meth nozzle but that's definitely not the case. Try a new nozzle and see what happens.
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | dsmluck (09-04-2011) |
Groans: 60
(Thread Starter) | Not Ranked : 0 score Well I don't think it was my meth. My AFRs consistently shit the bed whether its spraying or not. Recent map targeted 12.3 and i was seeing high 10's low 11's. Maf Cal is dead on except my idle trims keep wandering. Also keep popping P0101. I should have listened before when multiple people kept telling me to do a boost leak test. That's gotta be my issue. Time to put one together. I just hope its something easy and not a fucking cracked manifold.
| The Following User Says Thank You to dsmluck For This Useful Post: | SLOWHATCH (09-06-2011) |
| TMIC w/Meth vs. FMIC w/Meth | adlpb | 2010 MS3 - Turbo Induction | 95 | 09-10-2011 05:32 PM |
| Pro-tune question... meth and upgraded ebcs? | dougefresh_ | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 07-23-2010 12:31 AM |
| Meth Injection without a tune? | nynhex | 2010 MS3 - Fuel, Nitrous & Water Injection | 7 | 03-27-2010 01:59 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
| meth injection problem. | 1quik3 | MazdaSpeed 3/6 - Turbo Induction | 3 | 08-10-2009 02:06 PM |
