| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Here is a closer picture. Seem to says "Kicker." |
Groans: 60
| The Following User Says Thank You to SSinstaller For This Useful Post: | Thor Hammer (12-06-2018) |
![]() Join Date: Dec 2016 Location: Mississauga, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score LOL. thats good. its a fuse holder man, from the aftermarket stereo that was probably in there at some point
__________________ 2011 ms3 Cobb AP, Forge bypass valve, HPFP internals, Cobb downpipe, Custom fmic w/mishimoto core, Cobb RMM, Cobb EBC, KW coilovers, whiteline RSB, stop tech fluid, stop tech SS brake lines, hawk HP+ pads, ACT 6 puck clutch, ATP 3071r, HTP 3.5" intake, Damond catch can, TunedbyNishan |
| Not Ranked : 0 score Most of the time to alter ecu control on obd2 cars, it is something that just re-flash the oem ecu.
Groans: 111
| Not Ranked : 0 score Just on the right of that Kicker thing you can see the ECU connectors, they're so big and clear that they almost shout at you "I am here! I am here!!".
(Thread Starter) | Not Ranked : 0 score I feel a little stupid lol. Thought it was some kind of aftermarket ECU. I’ve seen some speed owners do some stupid shit before, what can I expect. Thanks for the info! I’ll be on these forums a lot more frequently if I get it. 150k miles and really cheap. so definitely will need a rebuild soon. |
![]() Join Date: May 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score do you have a subwoofer in your car? if not, see where the other end of that wire goes to... that looks like the power wire to the amplifier. if they took that stuff out of the car, you may want to see where that end leads to and possible remove it or take the fuse out or disconnect it... i would disconnect it to be on the safe side |
(Thread Starter) | Not Ranked : 0 score I still haven’t gotten my hands on the MS3, and there is probably no possible way of me going to see the car. Technically it’s a “blind” purchase as for I only see the pictures of the car. It’s really cheap so I have nothing to really nothing to lose. If the worst comes, I’ll be parting it out. Although I’ll keep you updated when if I get it. |
| Not Ranked : 0 score you still talk about ''such a great price'' i hope it is below 4k?. Do you have a video of it running if you gonna buy it without inspection and seeing it in person, you need at least to see if the engine isn't knocking.... A blown doesn't worth much....
(Thread Starter) | Not Ranked : 0 score Buying it for way below 4k. Don’t have a video of how it runs but it definitely runs. At this price, a blown engine are my expectations with this car. |
| Possibly getting a 3 | seeyalaterbye | Gen2 MS3 General Discussion | 40 | 07-01-2012 11:24 AM |
