 Old 07-18-2010, 11:39 PM   #1
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
Default Not hitting full boost on Hypertech Cobb flash
So i did a few 3rd gear logs after i flashed with the hypertech...used the cobb sri flash. Removed 0-60 throttle restriction so i assumed i will be hitting full boost even on 3rd gear. On my first run, i peaked at 18 psi which is what i'm supposed to be hitting with the HT flash but it would gradually decrease and not hold 18 psi. I thought i might have a boost leak so I did a couple more runs with WGDC% to check for leaks. WG duty values should be high to compensate for a leak but values are around 40% so i dont think i have a leak. all clamps are on pretty tight.
Is there another way to detect a leak asides from high WGDC values? Why am i not holding 18 psi? stock bpv?
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 07-19-2010, 12:27 AM   #2
JohnMS3's Avatar
nobody?
-John
 Old 07-19-2010, 01:04 AM   #3
flyrevs2's Avatar
Posts: 1,235   (View Stats)
checkout my thread on the HT, I was able to hit 18, then hold 16psi
what are your mods ?
2013 Mazdaspeed3 Gen2
flyrevs2 is offline   Reply With Quote
 Old 07-19-2010, 01:39 AM   #4
JohnMS3's Avatar
i will be happy if i hold 16 psi but i'm losing boost quickly. i'm already at 13 psi by 5500 rpm. just have need to do a boost leak test...but shouldnt wgdc be high if i have a leak?
mods are cobb sri/tip, cs test pipe, mazdaspeed cbe
-John
 Old 07-19-2010, 01:56 AM   #5
JohnMS3's Avatar
here is also my first log when i got my HT. used the cpe flash on this log. boost is still the same. peaks at 18 psi and drops down rather quickly...only at 10 psi by 5300 rpm. .7 kr as well
-John
 Old 07-19-2010, 06:17 AM   #6
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
Try logging load? Maybe one of you pros can chime in here, but is it possible he's making the load target at 13 psi?
banditscout is offline   Reply With Quote
 Old 07-19-2010, 06:27 AM   #7
spnkr21's Avatar
Posts: 2,827   (View Stats)
Wg duty cycle would be high if it was the turbo not being able to handle it. Since it is particularly low maybe there is a leak.
http://forum.mazda6club.com/mazdaspeed6/219844-how-find-boost-leak.html
I just made one of these last week for 15 bucks. Best way to find the leak. Thank djuosnteisn for the write up.
2012 WRX HB w/mudflaps yo!
 Old 07-19-2010, 08:18 AM   #8
bahndrvr's Avatar
Posts: 21   (View Stats)
bahndrvr is a jewel in the roughbahndrvr is a jewel in the roughbahndrvr is a jewel in the rough
Groaned at 7 Times in 1 Post
Honestly man, that stock dv is probably bleeding it off, it's setup to do so on the stock load so I'm sure it's really highlighted right now by the extra boost, if you want it to be quiet and work well, you can't beat Forge - ran there products for years on my Audi's and VW's.
02 Saleen Vert - Blown, T-56 Viper Spec, IRS, MM coilovers, IRS, etc.. For Sale need 4 doors, it's why I'm here
92 4Runner - lifted, locked, planned to upgrade but now will be my downpayment for the MS3
bahndrvr is offline   Reply With Quote
 Old 07-19-2010, 11:25 AM   #9
JohnMS3's Avatar
i saw that boost leak tester before but i dont have a an air compressor. i want to verify if the bpv is leaking before i invest in one.
i might do a couple of runs on stock tune but i dont think its the tune that is causing my low boost pressure.
any more ideas?
-John
 Old 07-19-2010, 11:36 AM   #10
spnkr21's Avatar
You must know someone with an air compressor.
 Old 07-19-2010, 11:43 AM   #11
drenkel's Avatar
Posts: 604   (View Stats)
drenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the worlddrenkel is the leader of the world
Groans: 42
Groaned at 53 Times in 14 Posts
You can get a small compressor for like 40 bucks. Trust me it's well worth it for investment. You'd be surprised how many things you use it for once you have one lol.
Sold: 2010 MS3 - I'll miss ya
Now: 2013 Mustang GT
drenkel is offline   Reply With Quote
 Old 07-19-2010, 11:49 AM   #12
JohnMS3's Avatar
yeah i do. how about the stock bpv? how can you check if it's bleeding boost?
-John
 Old 07-19-2010, 01:05 PM   #13
Nachtsturm's Avatar
Posts: 87   (View Stats)
Nachtsturm is a glorious beacon of lightNachtsturm is a glorious beacon of lightNachtsturm is a glorious beacon of lightNachtsturm is a glorious beacon of lightNachtsturm is a glorious beacon of lightNachtsturm is a glorious beacon of light
Just get a Forge BPV. If you still have the problem its somewhere else. If not, u still have an upgraded part.
2006 Mazdaspeed6 GT - SOLD
[Magnaflow CBE]
223awhp 242awtq - Mustang Dyno
2008 Mazdaspeed3 Sport - SOLD
[Cobb SRI] [Forge BPV] [TWM STS]
14.514@98.67 *Stock*
Nachtsturm is offline   Reply With Quote
 Old 07-19-2010, 01:09 PM   #14
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
I have your solution.
Try with a different map. Even if you have the COBB Intake (like I do), set your Hypertech to the CP-E Nano map or the HKS intake map. Those setups will let your turbo hit at least 17 psi in 3rd gear and 18 in 4rd.
Check the thread to see dyno results between different maps:
Hypertech Intake Maps results
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 07-19-2010, 01:33 PM   #15
JohnMS3's Avatar
the 4th log that i posted is using the cpe flash. thats actually the first log that i ran. i removed it due to high ltft's and kr at wot. i'll just borrow a forge bpv to see if the stock bpv bleeds boost...if my stocker doesnt i might have to make up a boost leak tester. shouldnt my wgdc be high indicating a boost leak?
-John
 Old 07-19-2010, 04:58 PM   #16
JohnMS3's Avatar
bump
can WGDC values be low if there is a boost leak or should it always be high? just want to know if my inability to hold boost is due to a leak or this can be a result of the HT tune. I didnt do any stock logs and will do one at night.
-John
 Old 07-19-2010, 05:04 PM   #17
flyrevs2's Avatar
had same problem on 1st HT flash, re-flashed and all was good
I suggest you flash back to stock, the re-flash, this fixed my problem
There is a flakey issue sometimes with HT, esp. if you are not coming from a stock tune. Other people have had to flash twice to get it working properly, no big deal only takes 5 extra minutes.
Annoying but easy fix.... try it and post back results
 Old 07-20-2010, 06:41 AM   #18
Police
ganque's Avatar
Try with HKS tune.
TEH MEXICAN'T PERM!
 Old 07-20-2010, 12:22 PM   #19
JohnMS3's Avatar
reflashed with stock tuning thenc cobb...hopefully this is just a tuning issue. will post logs later on
-John
 Old 07-21-2010, 10:50 PM   #20
JohnMS3's Avatar
did a few more logs tonight and just want to get some feedback on these logs...i'm not pleased with my hypertech flash at all and boost is not holding at the advertised 18 psi. it's like i have stock tune on except that 1st to 3rd gear boost limits are removed. i flashed three times already and no change. can i have a boost leak without wastegate duty increasing?
1st log is on 3rd and 4th gear. knock on both and had to shift early due to approaching traffic.
3rd gear
-John
 Old 07-21-2010, 11:06 PM   #21
JohnMS3's Avatar
how do you change the dark blue field on these logs to something brighter?
-John
 Old 07-22-2010, 03:13 PM   #22
Base14's Avatar
Posts: 220   (View Stats)
Base14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond reputeBase14 has a reputation beyond repute
The dyno doesn't tell the whole story.. I'd be careful using the cpe tune with a cobb intake. If you do, I'd watch your LTFTs and FP like a hawk because the CPE tune causes the car to run super rich. I posted a thread about logging the differences between each tune with my cobb intake, and the results were startling. The CPE tune may pull harder, but its because my fuel trims were being increased 13% at WOT and my boost was spiking to 20 and holding at 19. Not exactly safe imo.
http://www.mazdaspeedforum.org/forum/foru...sri-tip-61898/
2008.5 MS3 GT | Hypertech Flash | Cobb SRI | Cobb TIP | SU Test Pipe | Forge BPV | JBarone SSP w/ bushings | Matt Damond's OCC kit | SU RMM | 20% tint | LED swap | Raptor DDE Halo kit | Rally Armor Mud flaps | Sideskirts | TRS clear lenses | DashHawk with CPE mount
278 whp, 300 wtq
Base14 is offline   Reply With Quote
 Old 07-22-2010, 04:33 PM   #23
fjames's Avatar
Posts: 1,058   (View Stats)
Right click the chart->edit->channels. Or you could change the background.
Hypertech Boost issue? ANMSPD3 MazdaSpeed 3/6 - ECU Computer Tuning 26 05-04-2010 08:48 AM
Not hitting right psi for cobb map stage 1!! gt5 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-21-2010 05:50 PM
Cobb Accessport flash remove boost limit in 1st and 2nd? TongMan MazdaSpeed 3/6 - ECU Computer Tuning 24 11-20-2009 07:21 PM
Not hitting boost targets, Underboosting spheed3
Cobb ATR Support
17 08-09-2009 12:24 PM
Page generated in 0.40671 seconds with 29 queries
