| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Apr 2019
Rep Power: 13 ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hey all, so I had the opportunity to get a 4th gear pull today, logging with the AP. I was hoping anyone with a good mind about them could take a look at the numbers and spot any glaring concerns. 2008 MS3 on 93 Octane - 86k Cobb AP 1 +SF OTS tune Cobb TIP Cobb SRI AutoTech Internals Damond RMM Damond Short Shift Plate |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score Looks decent. There's a little knock retard, check that your spark plugs are in good shape and gapped 0.026-0.028", and make sure you're using good fuel. Get used to regularly monitoring your car, look up how to read and interpret these datalogs to hopefully spot problems. here's a very basic reference from Cobb http://accessecu.com/support/docs/su...0Guidance.html
__________________ 94 M MS6 IS350 |
