| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
(Thread Starter) |
| The Following 5 Users Say Thank You to Haltech For This Useful Post: | Dash08 (08-30-2008), FreeFlyFreak (07-11-2008), SLS MS3 (03-21-2008), wyosaint (05-23-2009), yager (08-06-2008) |
(Thread Starter) | See attached for detailed codes...
| The Following User Says Thank You to Haltech For This Useful Post: | jcolton (10-14-2015) |
| Banned ![]() Join Date: Mar 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Think you can stick this in the Speed6 section as well? Show some love! |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| The Following User Says Thank You to NYpest For This Useful Post: | occschemguy (03-22-2008) |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score thx |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score having trouble opening
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: Jun 2018
| Not Ranked : 0 score hello my name is Bill I live in Utah and just bought a 08 mazda speed 3 |
![]() Join Date: Jun 2019
| Not Ranked : 0 score Thank you for the add onto the forum, will help me out a lot in the future. I have a blacked out 2008 gen 1 ms3, still a noob I’ve had it for 3 months but I’ve been in the Mazda wave for a while. Here to learn and grow. |
| Not Ranked : 0 score So if my car is running rich on idle bank one would I have change my o2 sensors, fuel system flush, ecu tune, get a Cobb, or what else would be another form to turn off my cel (check engine light) |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
To do a search simply use Google. Begin your search with the term "mazdaspeedforums" (remove quotation marks) followed by your CEL code number. Then read the threads that correspond to that code. Chances are high that there will be multiple threads that will help you diagnose and solve the problem. If not, then start a new thread based on the results of your search and remaining unresolved issue.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/mazda-obd-ii-trouble-codes-281/ | ||||
| MazdaSpeed 3 - ECU Computer Tuning [Archive] - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-30-2008 10:03 PM | |
| Turboxs FMIC trouble. | Davidb | MazdaSpeed 3/6 - Turbo Induction | 4 | 04-03-2008 10:03 AM |
| Link to trouble codes...... | winniep | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 03-20-2008 07:22 PM |
