| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Oct 2011 Location: Clermont, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 8 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score -Thanks |
| Not Ranked : 0 score The car is running a little lean for my tastes. Also what is the overall timing? You should definitely be logging that. Is this also a common occurrence or did it happen in that 1 log?
(Thread Starter) | Not Ranked : 0 score That was the first time I felt anything like that, didnt feel it after that one log either. I'll have to add back in the overal timing in the datalog, I have no idea. Bad gas maybe? How does my fuel pressure look? Last edited by AlecLarson; 09-01-2012 at 11:12 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Fuel pressure looks fine. When asking for help also give more information such as what your mods are as well as what map you're running etc.
(Thread Starter) | Not Ranked : 0 score I should have put my mods in my sig by now. Cobb sri/tih, dp, tp, resonators removed, bpv, stock hpfp (i know, i know, I'm watching it closely). Just running the ots stage 2 SF/TIH map. |
![]() Join Date: Feb 2011 Location: Nellis AFB , NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 92 Times in 11 Posts
| Not Ranked : 0 score Your AFR's went lean as fuck after your flat foot shift. If you notice you started climbing into the high 12's almost 13:1 AFRs which undoubtedly cause the KR onset which only got higher with the car leaning out further. I know theres a couple dudes around here that have been trying to tune out this lean condition from flat foot shifting, but, the thread kinda died. I cant remember where it went. I just dont do it. Haha.
__________________ --Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned -- |
(Thread Starter) | Not Ranked : 0 score Interesting, I have noticed this does only happen when I flat floot shift and at the same time. Yeah, it would be nice if it could be tuned properly to not run so lean during ffs. |
| Knock Knock Knock..Whose There? (<===total noob) | thomas_cory2000 | MazdaSpeed 3/6 - ECU Computer Tuning | 158 | 06-12-2014 11:57 PM |
| Terrible Gas Mileage - Please Help | DRS211 | CX-7 > Issues & Troubleshooting | 43 | 09-16-2013 08:30 PM |
| Terrible response with BNR S3! | EmPeEs6 | MazdaSpeed 3/6 - Big Turbo Builds | 17 | 07-16-2012 05:52 PM |
| Terrible Radio reception | dcphantom | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 06-04-2009 07:31 PM |
| Low knock, good boost, but terrible AFR's | kgb | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 11-26-2008 10:15 PM |
