  • 1 Post By magoo
 Old 02-20-2009, 05:15 PM   #1
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
Default I need SWAS pictures!
can you guys post up the pics that were in the old swas thread that some1 took down. I want teh boost while turning
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 02-20-2009, 05:17 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
SWAS?
 Old 02-20-2009, 05:20 PM   #3
mexicant's Avatar
Groans: 147
SWAS?
Yeah , you better act right before you get smacked right bitch!
NATOR PERFORMANCE
 Old 02-20-2009, 05:23 PM   #4
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Its the Steering Wheel Angle(maybe) Sensor. It detects if the wheel is turned so the car can limit boost. Unplugging the sensor allows you to full boost while in corners (and apparently does not affect anything else).
MattJackson86 is offline   Reply With Quote
 Old 02-20-2009, 05:25 PM   #5
mexicant's Avatar
Groans: 147
yeah.
me wants 20 psi while doing 90 degree turn (hahaha understeer ftw)
it also turns off the dsc/tcs, and some claim it lets the car overboost
NATOR PERFORMANCE
 Old 02-20-2009, 05:26 PM   #6
aaronc7's Avatar
Groans: 370
you could just unplug the ABS sensor and see what that does.............
phillyb (02-20-2009)
 Old 02-20-2009, 05:29 PM   #7
mexicant's Avatar
Groans: 147
:n ono::1 zhelp::1zh elp::1zhel p::p arty::bigeyes ::si lly:
NATOR PERFORMANCE
 Old 02-20-2009, 05:48 PM   #8
magoo's Avatar
Posts: 97   (View Stats)
magoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant futuremagoo has a brilliant future
Ask and you shall recieve.
magoo is offline   Reply With Quote
The Following 13 Users Say Thank You to magoo For This Useful Post:
doubleflusher (07-21-2011), ELiTeNeSs (10-10-2011), FreeFlyFreak (11-14-2010), impossible (06-25-2014), kgb (01-12-2012), madvillain (11-26-2010), Menace1 (02-10-2013), mexicant (02-20-2009), MS3 Ventura (06-11-2010), RichieRichness (08-01-2011), Tommy (10-23-2012), xcoldricex (04-21-2010), Z32_MS3 (04-14-2014)
 Old 02-20-2009, 07:19 PM   #9
mexicant's Avatar
Groans: 147
magoo>god
NATOR PERFORMANCE
 Old 02-20-2009, 07:22 PM   #10
tagkat's Avatar
Posts: 269   (View Stats)
tagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to behold
Okay update this with how it feels w/it off.
tagkat is offline   Reply With Quote
 Old 02-20-2009, 08:16 PM   #11
magoo's Avatar
Had it removed for 6+ months now. Cant drive with it attached anymore.
Big difference. Im in control now, not Mazdas pita Electrics
project86 likes this.
 Old 02-20-2009, 08:17 PM   #12
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
hahahahahhaa, i can't believe you went there. hahahahahha
 Old 02-20-2009, 08:21 PM   #13
tagkat's Avatar
Doesn't this disable the DSC?
 Old 02-20-2009, 08:32 PM   #14
phillyb's Avatar
Groans: 1,940
no
 Old 02-20-2009, 08:40 PM   #15
magoo's Avatar
No.
TC will remain lit at all times on your dash, DSC is still switcheable as per normal. ABS is unaffected.
There are zero draw backs guys.
 Old 02-20-2009, 11:10 PM   #16
mexicant's Avatar
Groans: 147
CALL PHOENIX PD, BECAUSE MY ASS IS GOING LOCO ANOCHE!!!! AYEAYEAYEYAYEYE BOOST WHEN TURNING
NATOR PERFORMANCE
 Old 02-21-2009, 11:39 AM   #17
phantom6294's Avatar
Posts: 255   (View Stats)
phantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the world
Originally Posted by mordant80 View Post
Edit: Yea, look at the DSC system here: MAZDA:Active Safety Technologies | Safety Initiatives It uses the SWAS sensor, there's no way DSC still works properly with it disconnected.
My thoughts exactly... one of the ways DSC determines if you're 'out of control' is to compare how much you 'want' the car to turn/rotate by looking at your steering wheel input (the SWAS) and comparing that to the readings from a yaw sensor. When those two don't match up DSC takes actions to correct. Without the SWAS, the car doesn't have a freaking clue if you're understeering, oversteering, etc. DSC may not 'freak out' if it unplugged, but I don't see how it could properly operate.
phantom6294 is offline   Reply With Quote
The Following User Says Thank You to phantom6294 For This Useful Post:
FreeFlyFreak (06-04-2010)
 Old 02-21-2009, 11:58 AM   #18
Fratman's Avatar
Posts: 260   (View Stats)
Fratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond reputeFratman has a reputation beyond repute
im going to try it
Fratman is offline   Reply With Quote
 Old 02-21-2009, 01:08 PM   #19
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
i'll go ahead and keep my SWAS plugged in... idk if the Cobb map gives me more boost when turning but it's pretty clear that WOT + turn = understeer + wheelspin. what's the point unless you're trying to spin up the tires..? maybe with some sticky-ass tires it'd be better to have full snail.
IMHO the stock config is 'good enough' for turning. that being said, i can think of times when i 'know better' than the ECU as to what i'm trying to do.
PS i've read that the following method gives full boost when turning:
1) turn ignition on but don't turn over the engine
2) hold DSC button for 5secs
3) turn on engine, DSC and TC buttons should be illuminated
anyone know if this works?
08_ms3_gt is offline   Reply With Quote
 Old 02-21-2009, 06:39 PM   #20
magoo's Avatar
No it will not sorry
 Old 11-26-2010, 06:02 AM   #21
misiekwaw's Avatar
Posts: 49   (View Stats)
misiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud of
Working method that gives full boost when turning:
1) hold DSC button
2) when still holding DSC button, turn ignition on and wait for TC icon flash
3) release DSC button
4) turn on engine, DSC and TC icons should be illuminated
This give You full boost when turning until Your ignition is turned off.
Sunlight Silver 2007 Mazda 3 MPS by DISI-tune 303whp 352lbs
mazdaEdit tune, StreetShadows Garage 3" catless DP, 2,75" cat-back and test-pipe, HTP 3" Intake with custom airbox, Precision FMIC with StreetShadows Garage 2,5" piping, KMD Internals, Forge BPV, ACT 6 puck, OZ Ultraleggera 18x8, Kumho KU36 225/40R18, Bilstein B8, Eibach springs, James Barone Racing Rear Sway Bar, Corksport Front Lower Arm Bar, AWR Rear Engine Mount, James Barone Racing Passenger Side Engine Mount, TWM shifter Bushings, Hawk HPS F/R, Goodridge Brakelines, Motul RBF600, MazdaSpeed rear wing, STRI Racing gauges with custom pod
misiekwaw is offline   Reply With Quote
 Old 11-26-2010, 06:12 AM   #22
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
1) hold DSC button
No it doesn't. This is very old news and doesn't totally kill dsc & tcs. Use a tuning solution to get full control of your throttle plate and you will still see the cut out (or just push the car harder). Unplugging the swas is the only way to totally kill it on gen1 cars. Good luck finding a real solution for gen2.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 11-26-2010, 06:30 AM   #23
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
1) hold DSC button
Erroneous! Must unplug the SWAS. Have had mine unplugged for a while now
 Old 11-26-2010, 08:28 AM   #24
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
Damn, never heard of this. Wish I would have a long time ago. What are your impressions of unplugging the SWAS compared to being plugged in. Full boost with turns would be great. Thanks Tyler for any input
 Old 04-22-2011, 04:23 PM   #25
Daddy's Avatar
Posts: 144   (View Stats)
Daddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud ofDaddy has much to be proud of
Groaned at 5 Times in 1 Post
I'll be doing this this afternoon.
6k HID's - Cobb SRI - BC Racing Coilovers - UR CB - J-Spec Tail Lights
Daddy is offline   Reply With Quote
 Old 10-07-2011, 01:00 PM   #26
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
I'm, waking this thread up from the dead but how do you pop the bottom cover off of the steering wheel housing?
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline   Reply With Quote
 Old 10-07-2011, 01:18 PM   #27
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
should be like 4 screws on the bottom and you may want to drop the bigger panel but dont quote me. get under it and look up should see some screw holes like 3-4 total.
The Following 2 Users Say Thank You to skeeter149 For This Useful Post:
rfinkle2 (10-07-2011), RichB (10-07-2011)
 Old 10-07-2011, 01:21 PM   #28
RichB's Avatar
Thanks!
 Old 10-07-2011, 04:38 PM   #29
Jake5713's Avatar
Posts: 1,775   (View Stats)
Mine looks different would like to confirm which plug?
I am here: http://maps.google.com/maps?ll=44.739802,-93.107992
-Jake
File Type: jpg ImageUploadedByTapatalk1318027017.197300.jpg (982.9 KB, 126 views)
File Type: jpg ImageUploadedByTapatalk1318027058.149920.jpg (883.1 KB, 117 views)
 Old 10-07-2011, 04:50 PM   #30
aaronc7's Avatar
Groans: 370
i miss mexicant/08ms3bm
NJSPEED3 (12-14-2011)
 Old 12-14-2011, 04:04 PM   #31
travis9935's Avatar
Posts: 371   (View Stats)
travis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond repute
Groaned at 41 Times in 24 Posts
Anyone left it plugged in and hooked a switch up to this, for easier off and on? If so which wires?
HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2
travis9935 is offline   Reply With Quote
 Old 10-21-2016, 10:20 AM   #32
Nickhxc4life's Avatar
Posts: 27   (View Stats)
Nickhxc4life will become famous soon enough
Sorry to dig up an old thread but I am replacing my clockspring and the new one doesn't have the socket to plug swas cord in. Does the old swas sensor come off the old clock spring?
Nickhxc4life is offline   Reply With Quote
 Old 10-21-2016, 02:20 PM   #33
frothy's Avatar
Posts: 1,067   (View Stats)
The Following 3 Users Say Thank You to frothy For This Useful Post:
FSRRM (10-29-2016), meicalnissyen (10-26-2016), Vader (10-27-2016)
 Old 10-26-2016, 07:23 PM   #34
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Frothy my brother, My random part ID guru....
I found this clip
can you ID it ??
what kind of clip is it??
@wes3id;
Vincent Furnier Is NOT, an acceptable answer
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/i-need-swas-pictures-21764/
Forum Mazda Performance Series - Zobacz temat - TCS nonstop This thread Refback 05-29-2012 07:23 AM
AutoZone Québec, le forum de Essai-Auto.com - Voir le sujet - Après 200 000 km sur ma Speed (enfin, presque 200 000) This thread Refback 06-10-2011 07:19 AM
Drive with DSC off? This thread Refback 04-23-2011 01:35 AM
removing the swas? 3 mps This thread Pingback 10-27-2009 06:01 AM
Where is the Steering angle senor (SWAS)?? magoo MazdaSpeed 3 - How-To's 61 12-28-2011 12:07 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Some pictures of the FMIC and PTP CAI. skeeter149 Mazdaspeed3/6 General Discussion 16 01-19-2009 10:48 PM
Page generated in 0.52238 seconds with 41 queries
