 Old 11-20-2009, 03:45 PM   #81
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
PM me your paypal and cost of shipping and i'll send you the shipping cost tonight.
ty
 Old 11-20-2009, 03:46 PM   #82
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
It's on the first page AFAIK. I'll double check.
Yup, still there, post #1.
I'll pm shipping costs after i ship them. Prob won't ship till tomorrow, pretty busy at work.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 11-20-2009 at 03:47 PM. Reason: MSF Database - Automerged Doublepost
SpeedSixxx (11-20-2009)
 Old 11-20-2009, 05:08 PM   #83
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
Cant wait to see you guys make for power with these! Good luck!
The Following User Says Thank You to Fagwagon For This Useful Post:
 Old 11-20-2009, 05:14 PM   #84
SpeedSixxx's Avatar
Groans: 778
I promise to be the first stock block BT MZR to make 500 whp and blow cause of it.
at least I can say I was the first to find out how much power the stock block really can handle before zum zoom wanna wanna bing bang boom nukka!
 Old 11-20-2009, 07:18 PM   #85
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
I hate to say this but the Turbo you bought isn't capable of making 500 whp. Only the gt3076 and above is. your stuck at 450 pussy
The Following 2 Users Say Thank You to For This Useful Post:
mexicant (11-24-2009), SpeedSixxx (11-20-2009)
 Old 11-20-2009, 08:48 PM   #86
SpeedSixxx's Avatar
Groans: 778
lololol......tiss it thee turbo it'self that makes yee only 450 hp.
He <== tiss thinks not....
sell and buy another turbo yee shall do ith my droogy!
 Old 11-20-2009, 09:58 PM   #87
Captain
I bet you could come pretty damn close to five if you pushed it like some push the stocker.
PM'd tracking numbers to everyone.
All circuits were set to minimum before shipping, and i tested them out a couple times.
I put stickers on the backside indicating which end goes towards the sensor, and which end goes towards the ecu.
You'll have to cut the three wires for the ms6:
left (brown) is the ground, and get's soldered to the black wire on the ckt.
middle (brown/black) is the signal line, and gets soldered to the green wire on the ckt.
right (red/black) is teh 5V, and get's soldered to the red wire on the ckt.
The MS3 has different colors, but maybe Lex or somebody can snap a pic. I'd be willing to bet that it's located on the same connector, but possibly different colors. They should be "ohmed out" to be certain which wire is which.
Here's a rough idea of what tuning i think will be required.
-Theory-
Once this circuit is installed, and adjusted for more pressure than stock, we are essentially throwing off the ecu's fueling calculations. It will run very rich if we don't do any tuning at all.
So how do we "correct" the ecu's fueling calculations? We trick it into thinking there is less air coming into the engine, thus requiring less fuel. This is done by skewing the MAF table, reducing the values for all voltages.
Skewing the MAF table will work fine for correcting the fueling, but...
*this is important*
... It will trick the ecu into thinking it's running at a lighter load than it really is!
This is where the real tuning is needed. Every table that uses Load as one of it's input parameters will need to be skewed as well. These tables are:
LOAD DEPENDENT TABLES
* Closed Loop Max Load A
* Closed Loop Max Load B
* Closed Loop Max Load C
* Closed Loop Max Load D
* Fuel CL Commanded EQ (base)
* Fuel OL/Part Throttle Commanded EQ (knocking)
* Fuel OL/Part Throttle Commanded EQ (no knock)
* Fuel OL/Part Throttle Commanded EQ (unused)
* Ign Table - High Throttle/OL (knocking)
* Ign Table - High Throttle/OL (no knock)
* Ign Table - Low Throttle/CL (knocking)
* Ign Table - Low Throttle/CL (no knock)
* DBW Throttle A
* DBW Throttle B
* DBW Throttle C
* VVT Intake Cam Adv.
- Load in these tables isn't an input parameter (on an axis), but instead an output. They need to be scaled still. For instance if you reduced your maf by 20%, and didn't change your TRL load value, you'd be targeting a load 20% higher than you were before -
LOAD CALCULATED TABLES
* Abs Load Limit - Fuel Cut
* Abs Load Targets (isn't used afaik, but might as well scale it to be safe)
* Throttle - Req. Load - 1st Gear (High BAT)
* Throttle - Req. Load - 1st Gear (Low BAT)
* Throttle - Req. Load - 2nd Gear (High BAT)
* Throttle - Req. Load - 2ndGear (Low BAT)
* Throttle - Req. Load - 3rdGear (High BAT)
* Throttle - Req. Load - 3rd Gear (Low BAT)
* Throttle - Req. Load - 4th Gear (High BAT)
* Throttle - Req. Load - 4th Gear (Low BAT)
* Throttle - Req. Load - 5th Gear (High BAT)
* Throttle - Req. Load - 5th Gear (Low BAT)
* Throttle - Req. Load - 6th Gear (High BAT)
* Throttle - Req. Load - 6th Gear (Low BAT)
* Throttle - Req. Load - Max A
* Throttle - Req. Load - Max B
* Throttle - Req. Load : Baro v. RPM
* Throttle - Req. Load A
* Throttle - Req. Load B
* Throttle - Req. Load C
Here's a quick example of why we have to scale all these tables essentially.
Say before at wot, you'd target a load of 2.0. This load corresponds to a given MAF g/s which in turn corresponds to a given voltage. We now skew that MAF setup, saying that the given voltage represents less g/s (air). Say we scale it by 20%.
So if you didn't change your load target of 2.0, the ecu would still try for it, but this 2.0 target will now be 20% more g/s than before, or alternatively, quite a bit more boost, lol.
Also now, the other tables like spark advance and CL fueling, will have a given spark and fuel target for a given load. But load now represents 20% more g/s than before, so this spark and fueling will be WAY too aggressive (e.g. too far advanced and too lean). This is why we have to scale these tables.
That's pretty much the theory on it. How to go about it? I'm not entirely sure yet, lol. I think the best way is to assume a safe percentage, and adjust all the tables listed above by copying and pasting values from Loads 25% higher, into Loads 25% lower for the LOAD DEPENDENT TABLES and simply reducing load values in the LOAD CALCULATED TABLES.
Visual example:
This CL fuel table:
Code:
LOAD	500rpm	1000rpm	1500rpm	2000rpm	2500rpm	3000rpm	3500rpm	4000rpm	4500rpm	5000rpm
1.75	14.500	14.500	14.500	13.000	12.965	12.462	12.186	11.978	9.943	9.755
1.81	14.500	14.500	14.500	13.000	12.883	12.286	12.045	11.910	9.943	9.755
1.88	14.500	14.500	14.500	13.000	12.765	12.095	11.919	11.793	9.943	9.755
1.94	14.500	14.500	14.500	13.000	12.633	11.919	11.728	11.675	9.943	9.755
2.00	14.500	14.500	14.500	13.000	12.516	11.728	10.994	10.516	9.943	9.755
2.06	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
2.13	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
Would become:
Code:
1.75	14.500	14.500	14.500	13.000	12.516	11.728	10.994	10.516	9.943	9.755
1.81	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
1.88	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
1.94	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
2.00	14.500	14.500	14.500	13.000	11.884	11.044	11.044	10.516	9.943	9.755
You can see that the 2.0 load was shifted down to the 1.75 load row, the 2.06 was shifted to teh 1.81 etc etc. I just maxed all the higher rows to the value that was in 2.13, but if you want to, you can actually reduce the values from 1.94 load to 2.13 load by 25%, since there is no row to copy into these. Probably safe either way.
A TRL example:
2nd gear, normal BAT
Code:
500	1000	1500	2000	2250	2500	3000	3500	4000	4500	5000	5500	6000	6500	7000
0.70	0.83	0.97	1.15	1.46	1.64	1.87	1.97	2.01	2.03	2.03	2.03	2.03	2.03	2.03
Would be come
Code:
0.52	0.62	0.73	0.86	1.10	1.23	1.40	1.48	1.51	1.52	1.52	1.52	1.52	1.52	1.52
(simply multiplied by 0.75)
Looks like a lot of work now that i actually wrote this up, let's hope its worth it, lol.
I'll prob get my first map ready some time next week, and if anyone wants me to email them a before and after map to check out, i can.
And i've said it many times already, but by all means, if you don't feel comfortable doing this, i'll will definitely guinea pig it, and simply post up my results.
Once i get a new map dialed in the way i like it with full scaling, i will dyno with both zero scaling and full scaling and post up any gains. I'll also do some comparisons with the scope so we get a better idea of how much more fuel we're getting out of this trick.
fuck the double post merge.
www.permtuning.com
Last edited by djuosnteisn; 11-21-2009 at 02:12 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
MarkyMark (11-25-2009), mexicant (11-24-2009), SpeedSixxx (11-20-2009), thanox2 (12-05-2009)
 Old 11-21-2009, 05:47 PM   #88
Bump because of automerge - I will add my comments to this later - must prepare for dinner now
 Old 11-23-2009, 08:58 AM   #89
To tune:
After upping the pressure, scale the MAF sensor. Then move on to the other tables once your STFTs and LTFTs are in check. Don't load the car up prior to changing these other tables.
To start out, I would change the timing tables first. I would shift all the timing row values down to a lower load. In other words, if you were seeing 6 deg advance at 1.89 load, now you would want to see 6 degrees at ~1.45. do this for all the rows of the table.
Secondly, I would move to the fuel tables. the closed loop section of the table, leave alone. The open loop section of the table, shift the rows down to the lower loads as you did with the timing.
Next, scale when the car enters/exits close loop. If it was at 1.89 before, change it to ~1.45. You get the idea.
Now that your timing and fueling are safe, start rolling into the throttle. You will likely see more boost being run since the MAF is scaled lower. In this case, lower your requested load tables as described for the timing and fueling tables.
Keep an eye on pressure. It should stay healthy across the board - at the values you were seeing before this mod. If you see it dropping, the fuel pump is not keeping up or something has gone wrong. Always keep an eye on AFRs and timing.
If anyone could make these changes and make it to a dyno, it would be very nice to see the results.
IshiKage (11-23-2009), SpeedSixxx (11-23-2009)
 Old 11-23-2009, 09:33 AM   #90
Captain
I will probably be at the dyno in a week or two.
www.permtuning.com
 Old 11-23-2009, 09:39 AM   #91
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
What about with a MBC?
You shouldnt have to worry about requested load.
What can i skip if i'm using a manual boost controller?
 Old 11-23-2009, 09:48 AM   #92
Captain
I'll be using a MBC as well, but just out of safety, i'll be changing all my TRL tables. Best to just change everything IMO.
www.permtuning.com
 Old 11-23-2009, 04:02 PM   #93
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
cant wait for this!!!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 11-23-2009, 04:09 PM   #94
Captain
My pump won't be here till Wednesday, so i'll have to do some tuning with a turkey leg in my mouth.
www.permtuning.com
Deadman (11-23-2009), jmhinkle (11-23-2009), mexicant (11-24-2009), superskaterxes (11-23-2009), tmtbiker (11-24-2009)
 Old 11-23-2009, 04:42 PM   #95
Deadman's Avatar
Posts: 868   (View Stats)
rofl
Deadman is offline   Reply With Quote
 Old 11-23-2009, 04:43 PM   #96
SpeedSixxx's Avatar
Groans: 778
what with the cpe pro fuel controller?
how does it control fuel?
why even offer a product named pro fuel controller if it doesnt control the pressure like we are doing here??..
please explain to me what their product does compared to this pressure mod.
 Old 11-23-2009, 04:46 PM   #97
Captain
Never heard of that product. Probably made to work with auxiliary fueling or meth.
ding ding ding
The cp-e™ ProFuel™ controller is an integrated, fully progressive supplemental fueling controller that can be used to operate either a secondary set of batch fire injectors, or a water/methanol pump. Now you can fine tune both primary and secondary fueling using a single controller, and with tremendous versatility
It's a fancy meth controller, and probably rad if you run a SB.
www.permtuning.com
Last edited by djuosnteisn; 11-23-2009 at 04:50 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-23-2009, 05:46 PM   #98
Stickied... You sure you wouldnt rather have this in the fuel/nitrous section?
djuosnteisn (11-23-2009)
 Old 11-23-2009, 05:53 PM   #99
socks's Avatar
Groans: 125
my circuit came, i will work on it tonight or tomorrow.
i need to trace the wires and it may be too dark right now :-\
EDIT*
so, i wired it in. Car wouldnt start. Stumbled, but couldnt make enough pressure to crank.
So i took it out, and now the car is idling high (600psi+) at first it was idling at 800, but its worked its way down.
I dont know if it just adjusted for something I did wrong. I will try to do it again tomorrow when i have more time to mess with the wiring.
DJ, can you tell me what the colors on your sensor are? All the pics have been removed.
The Following 2 Users Say Thank You to socks For This Useful Post:
djuosnteisn (11-23-2009), SpeedSixxx (11-23-2009)
 Old 11-23-2009, 06:10 PM   #100
Captain
Put it where you see fit! Wasn't sure cause it was a "how-to" heavily ATR dependent and fuel related, lol.
Socks, call me if you have any questions at all! And i will definitely be moving forward on it if you want to wait, but by all means go forward if you want and keep us updated! I'm pretty sure you have my number, but i'll pm it to you again just in case.
www.permtuning.com
 Old 11-23-2009, 06:49 PM   #101
socks's Avatar
Groans: 125
Ok,
From the sensor, I have:
Brown, White/Green Stripe, and Yellow
These change at the plug to:
Brown/Green Stripe, White/Green Stripe, and Green/Black Stripe (respectively).
 Old 11-23-2009, 07:00 PM   #102
Must Have Teh 10's!
yah dustin you forgot to add what wires to tap on the sensor size
 Old 11-23-2009, 07:01 PM   #103
socks's Avatar
Groans: 125
No,
You run them all to that side of the plug, but the ms3 has different colors than the ms6 :-\
Ok, so here is the High pressure sensor on the MS3:
Then, at the plug:
Other side of the plug:
At that plug, Brown turns to Brown/Green,
White/Green stays white green
Yellow turns to Green/Black.
We just need to relate the MS3 and MS6 colors at the sensor.
I think I accidentally wired the circuit in backwards, how, i dont know.
Anyways, this will cause the ECU to see constant 5v, and attempt to lower the pressure, so thats why i wasnt making enough pressure for a start.
Last edited by socks; 11-23-2009 at 07:37 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to socks For This Useful Post:
 Old 11-23-2009, 09:03 PM   #104
Captain
This thread was one giant trick by me, and you all fell for it, muhahahahaha. My name is Mike and i drive a bmw.
Jk, Sean, i'm 99% sure i didn't label your circuit backwards, but who knows maybe i did. I think you traced all the wires perfectly, but it does sound like it was in backwards, or broken. I guess let us know if / when you try it the other way. I know it does work, cause i did it, and it worked perfectly. I'd feel horrible if i sent you a bad circuit, i tested them like 5 times each just to be sure, lol. Let us know.
Rock on with your Socks on!
www.permtuning.com
Last edited by djuosnteisn; 11-24-2009 at 02:54 PM. Reason: MSF Database - Automerged Doublepost
socks (11-24-2009), SpeedSixxx (11-23-2009), superskaterxes (11-24-2009)
 Old 11-24-2009, 03:16 PM   #105
socks's Avatar
Groans: 125
Ok, so i rewired it in, double and triple checking. This time i soldered/heatshrinked the wires. This time it functioned correctly.
Here you can see the MS3 colored wires, and how they relate to the DJ CKT (Thats what im gonna call this thing from now on).
This is it cleaned up:
And for fun:
Thats right, Almost every time i work in the engine bay I take the hood off. With it getting dark so much earlier now, it helps out bigtime, and is so easy.
So, with the pot halfway, i get about -10% trim difference.
It runs almost a full point richer at WOT with no changes to the tune. And thats just halfway! I figure (and confirmed with dustin) if you dont lie to the maf table, and just change your requested Open Loop AFR table, that may be the only thing you have to change. I'll mess with it later.
game on.
djuosnteisn (11-24-2009), SpeedSixxx (11-24-2009)
 Old 11-24-2009, 03:34 PM   #106
Captain
I'm soooo excited right now!
Just to clarify, *ahem* i was the first with this on my car, lol, but socks your the first to go wot! I love it!
And yeah, modifying fuel tables alone would probably work (i'll think more about it once i leave work and clear my head), but only draw back is that your fuel tables will never align with logged afr's, but that's actually a small price to pay considering you wouldn't be "lying" to the ecu via maf tweak.
Great stuff Sean!
www.permtuning.com
socks (11-24-2009), SpeedSixxx (11-24-2009)
 Old 11-24-2009, 03:39 PM   #107
socks's Avatar
Groans: 125
The only thing wrong with that, is that you would then also have higher fuel trims.
unless you only modified the values under 100g/s to get the part throttle tuned, and then the OL Commanded AFR at higher loads.
 Old 11-24-2009, 03:42 PM   #108
Fagwagon's Avatar
Groans: 75
game on.
turn up the fuckin boost and lean it out a bit! this is exciting shit.
 Old 11-24-2009, 03:54 PM   #109
Captain
If this all plays out well (cause these circuits are mainly just "proof of concept" pieces), i will design a better, more forgiving (tune wise) solution. Something where there is no tuning needed at all for part throttle situations, and only mild tuning needed wot!
So far though, seems like this concept is getting some proof!
www.permtuning.com
 Old 11-24-2009, 04:44 PM   #110
SpeedSixxx's Avatar
Groans: 778
ok ok...i just got it in the mail today. looks simple enough to install.
I say this....I will be doing my install of a shit load of parts soon enough and then I'll be driving to NJ for a tune via Akuma.
I'll be sure to install in between dyno pulls in the tuning session to see what the diff is and have John tune for it.
I'll also be sure to have him read this ENTIRE thread so he knows what the deal is.
I can expect over 400 whp with the mods i'm installing and when I confirm this via kuma tune/dyno pull ill then install the fuel pressure mod and have it tuned/dyno'd again.
I know John/Akuma tune for the most performance gains at the safest level possible so I'll see how much "safe" power I can get out of this mod without going boom on 53k on the motor.
ty , ty, ty so much DJ for the "gift" and i'll be sure to send you some funds by thursday.
wish me luck on the install and tune!
i'll make my own official thread in the weeks to come!
 Old 11-24-2009, 04:49 PM   #111
Captain
Let us proof this out a lil bit before you spend money for john to tune for it. There are likely bugs to figure out. I'd let him tune you safely without the ckt at first, and then you can possibly put it in later and just tweak the tune you paid for.
www.permtuning.com
 Old 11-24-2009, 07:07 PM   #112
socks's Avatar
Groans: 125
so, on the mazdaspeed3 at least, there is a fuel rail pressure relief. if it goes above 1850 (spec) psi, the valve relieves pressure.
but, im able to see that with the dial turned up half way, im reading 1550psi when its relieving pressure, and all the way up, im reading 1420 when it relieves pressure.
so you can see that this with the dial all the way up, its scaling voltage enough for 430 or so more psi.
If we can somehow raise the relief valves pressure, we can assume that when we're reading 1780-1800psi, we are really getting 2200psi. however, until i can adjust that valve somehow (whether it be a new spring, or hopefully as easy as a shim), im stuck at 1850psi.
Dustin is having different results on his car, so the pressure relief may not exist on the speed6, or its at a higher pressure.
 Old 11-24-2009, 07:22 PM   #113
Deadman's Avatar
according to Ron "whoosh" who i talked to today he did say this:
Just an FYI the speed3 is different than the speed6 in the whole fueling situation..and i hope the speed3 guys know this
well i was looking through my phone for the txt but i cant seem to find it... im sure he will jump in somewhere. (he mentioned something on these terms anyways..)
Just a coincidence that you brought this up now and i talked to ron at like 9am
The Following 2 Users Say Thank You to Deadman For This Useful Post:
 Old 11-24-2009, 07:27 PM   #114
Captain
Yup, (i can't drive around at wot, but i can sit in drive way and floor it to my launch control rpm), i can see a steady 1600psi ish, with my dial all the way up, and car unbelievably rich.
We need another 6 *ahem* super *ahem* to try it out and see. And another 3 *ahem*, anyone who wants a dj ckt *ahem*.
My car is a 2007, in case that ends up playing a role.
www.permtuning.com
 Old 11-24-2009, 07:42 PM   #115
socks's Avatar
Groans: 125
Ok, so, here is the pressure relief valve:
also:
I know john@ptp has been modifying these, Ill have to look into how it works, and how to modify it.
 Old 11-24-2009, 07:46 PM   #116
Captain
LOL amazing timing, i just grabbed this spare fuel rail i bought a few weeks ago. Took a look, and what do you know.
Great find on the documentation Sean.
The pressure release is incorporated inside the nipple when you unscrew it. I'll post a better picture in a sec.
I guess speed 6 nipples are soon to be in high demand, haha. We need to find a way to shim this though.
www.permtuning.com
 Old 11-24-2009, 07:50 PM   #117
socks's Avatar
Groans: 125
Im curious the difference.
I'll talk to Jason @ onlinemazdaparts tomorrow to see if he knows the difference, or what.
does that valve screw into the rail?
 Old 11-24-2009, 07:58 PM   #118
Captain
Yup, threaded right in there. Maybe you could buy a ms6 one for cheap? Easiest mod of all, lol.
Here's where it threads in:
Here's an up close of it:
Looks too complicated to modify by itself. It would likely need some sort of pressure reducer or something the thread into, but i'm not sure how to build such a thing.
It would still be easiest to buy a ms6 one as a replacement, unless they've been modified or use the same part as the new 3's, then there's no point.
One possible fix is to put two of them in a row, and then theoretically it would take double the pressure to open it, right?
www.permtuning.com
Last edited by djuosnteisn; 11-24-2009 at 08:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-24-2009, 08:00 PM   #119
socks's Avatar
Groans: 125
its actually a BITCH to get to.
Its behind the hard high pressure fuel line, and a coolant line.
I'd like to see how john@ptp is modifying them
or in what ways we test the ms6 one to be different.
 Old 11-24-2009, 08:13 PM   #120
Is that pressure relief used during normal vehicle operation or is it a safety measure? If it's a safety measure alone and you assume the risk, you can simply block it off.
You can also make the feed orifice to it smaller by introducing a washer with a smaller hole between the valve and the rail. This will reduce flow and should maintain higher rail pressure. You can play with hole size until you get it right.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/how-scale-hpfp-pressure-sensor-42364/
PERM's MS6 This thread Refback 09-12-2012 07:34 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback 05-02-2012 07:56 AM
Fuel Pressure Tuning - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-04-2010 03:54 PM
DCR Needs a MS6 for measurements - Mazda6 / Atenza This thread Refback 12-01-2009 02:50 PM
albuquerque nm mazda 6 owners - Mazda6 / Atenza This thread Refback 11-25-2009 07:58 AM
North American Mazdaspeed club This thread Refback 11-16-2009 09:52 AM
Fuel Pressure Tuning - Mazda6 / Atenza This thread Refback 11-15-2009 08:22 AM
2010 Mazdaspeed 3 Weight on Scale - Input cheez 2010 MS3 - Engine, Transmission & Driveline 46 12-09-2009 07:19 PM
GM Keeps Opel for Scale and Innovation: Analysis Haltech Automotive News 0 11-04-2009 01:00 PM
P0107 - Barometric pressure sensor low input vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-14-2009 01:31 PM
Spec out your own Maserati - in 1/43 scale Haltech Automotive News 0 06-19-2009 05:00 PM
Ford sees no large-scale aid for Visteon Haltech Automotive News 0 01-29-2009 01:30 PM
Page generated in 0.59850 seconds with 28 queries
