 Old 11-16-2009, 12:43 PM   #41
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
what kind of answer is that...tease.
 Old 11-16-2009, 07:07 PM   #42
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
fuck fuel
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRayBauder For This Useful Post:
djuosnteisn (11-16-2009), superskaterxes (11-17-2009)
 Old 11-16-2009, 09:00 PM   #43
Applied Tuning's Avatar
Posts: 20   (View Stats)
Applied Tuning is just really niceApplied Tuning is just really niceApplied Tuning is just really niceApplied Tuning is just really niceApplied Tuning is just really nice
We will have some results of what the MAzdaEdit software can do in about 3 days. 08 MS3 with an intake and turbo-back.
Did have some decent luck with it on a 07 2.5 n/a car today. Even though it wasn't developed for that ecu. Good results nonetheless. Still needs some work. But I have more positive aspirations about the MS3's.
Applied Tuning is offline   Reply With Quote
The Following User Says NO Thank You to Applied Tuning For This Un-useful Post:
 Old 11-16-2009, 09:15 PM   #44
Not sure what you mean by this. Is your software able to address fuel delivery as discussed in this thread?
cpolly69 (11-17-2009), SpeedSixxx (11-17-2009)
 Old 11-16-2009, 10:39 PM   #45
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Yeah man. I've had enough secrets and hype for this car. I can't stand it anymore. If this can control the fuel injectors, let us know. Can it control timing? Or rail pressure? Both?
How well are the tables defined?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
06Speed6 (11-18-2009), cpolly69 (11-17-2009), SpeedSixxx (11-17-2009)
 Old 11-17-2009, 06:44 AM   #46
Fagwagon's Avatar
Groans: 75
I really do hope that you posted here in this thread because you have a way of controlling the fuel rail pressure if not then stfu.
The Following User Says Thank You to Fagwagon For This Useful Post:
 Old 11-17-2009, 07:16 AM   #47
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
I've been looking around, and there are a number of 3000 psi sensors that may be candidates for replacing the stock sensor. I think because of the electrical headroom issue with the stock sensor, a 3000 psi sensor with an electrical scaling circuit may be a best final solution.
Of course, if the pump can't make 2200+ psi, or the injectors don't function properly at excessive pressures, it may be a moot point.
KoukiS14 is offline   Reply With Quote
 Old 11-17-2009, 09:16 AM   #48
Captain
I've heard that the pump can make up to 6000psi, and blow up the fuel rail, lol, so pressures should not be an issue, but injector function is a definite concern.
I'm sure it would be fairly easy to make an adapter plug to run a different sensor. And if the new sensor was on a 3000psi scale, it may not even need a scaling circuit, just some tuning.
I think baby steps are important though, hahaha. I built 2 circuits last night, need to get a few more parts tonight and build 3 more.
I think the likely candidates are:
Socks
JJ
Superskater
Mark (if he wants one, not sure if he does since his stand back already does it)
... and who else do you guys think?
www.permtuning.com
JumpingJackson (11-17-2009), SpeedSixxx (11-17-2009)
 Old 11-17-2009, 09:39 AM   #49
tmtbiker's Avatar
Posts: 287   (View Stats)
tmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the world
Socks
JJ
Superskater
Mark
Yoichi..although he may be close to maxing out the 2871
SS..isnt he close to running? is he using the sb?
and wtf is randy up to these days? there used to be so much DCR hype..just another mirage i guess.
thats about all i can think of.
Originally Posted by huffentuff09 View Post
Some Dude with bike in his name from FLA don't like my pointless posts..
tmtbiker is offline   Reply With Quote
The Following User Says Thank You to tmtbiker For This Useful Post:
 Old 11-17-2009, 09:46 AM   #50
Captain
Yoichi is SB AFAIK, so is SS. They're welcome to them if they want it.
Speedsixx guy is going BT and getting built right? don't think he's running yet though.
Lex, you want one to play with? I know your not super BT power hungry mofo, but you'd probably like to play with one, right?
www.permtuning.com
Last edited by djuosnteisn; 11-17-2009 at 09:47 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-17-2009, 02:13 PM   #51
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
samsel450r might be a good candidate as well.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
 Old 11-17-2009, 05:02 PM   #52
Originally Posted by Dadasracecar
Rating: 5
View Member Profile
Add as Friend
Send Message
Find Member's Topics
Find Member's Posts
Find Member's Registry Entries
post Nov 15 2009, 05:34 AM
Post #1
∆Suniv > 0
Group: Mazda Members
So I was tuning a customer's car last week using both versions of the SB software - the speedranker writes faster but Lou's version is what I'm used to. Anyway, I got the maps confused and ended up putting the meth values in the fuel pressure map. The car acted weird and when I had discovered what I'd done I knew that we could manipulate fuel pressure. In later discussions with our machine shop owner - builds Winston Cup engines so I listen to him - he indicated that one of the reasons he felt we were having problems making 5-600 hp was fueling. He wanted us to change the injector pulse timing. We can't do that yet - Lou's new standalone will be able to - but we can alter fuel pressure.
I'll be the first to admit that I have never believed the fueling arguments that Haltech, Lex, and others have made. Our cars were pig rich at the tailpipe and made power when we leaned them out. But, have dyno, will test.... I tuned Orlando's car using fuel pressure as one of the variables and his car REALLY responded. I don't have that dyno but I'm sure he'll post it soon.
Finally, Haltech, you were right. Man, that hurt...
I guess hell finally does freeze over, eh?
The Following 5 Users Say Thank You to Haltech For This Useful Post:
06Speed6 (11-18-2009), bf360 (11-17-2009), djuosnteisn (11-17-2009), SpeedSixxx (11-17-2009), whoosh@Realtune (11-17-2009)
 Old 11-17-2009, 05:05 PM   #53
Captain
Hey hal, you want one?
www.permtuning.com
 Old 11-17-2009, 05:10 PM   #54
You should give them to the big power guys first bro. But i commend you on pulling this off... its going to be the start of something good DJ.
 Old 11-17-2009, 05:17 PM   #55
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Kevin,
i was curious if you saw that.
DJuosnteisn,
let me know when your ready to send it out, ill cover parts and shipping at the least.
 Old 11-17-2009, 05:23 PM   #56
Captain
Part's are pretty cheap man, i almost consider this beta batch a gift to our platform in hopes that indeed something good comes from it.
I'll take you up on the shipping though . Probably ship in a day or two.
www.permtuning.com
FreeFlyFreak (12-12-2009)
 Old 11-17-2009, 05:27 PM   #57
Kevin,
DJuosnteisn,
I havent had much time to hit the forums and read much with 16 hr days at work and family. My jaw pretty much dropped when i saw that post.
 Old 11-17-2009, 06:03 PM   #58
Dustin, won't need this now as my car has a stock turbo and is going away for the winter as we discussed.
If the beta tests go well, I have some good ideas on refining the product.
 Old 11-17-2009, 06:12 PM   #59
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
looking forward to results!
-- Mario Andretti --
 Old 11-17-2009, 06:33 PM   #60
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
I can volunteer my car.....when i get some time.. I have standback and all the flashes, big MAF, 3076, built motor, port injected meth
All wagon, No traction
wassup61 is offline   Reply With Quote
 Old 11-17-2009, 06:39 PM   #61
socks's Avatar
Groans: 125
you dont need it if you have the standback...
The Following User Says Thank You to socks For This Useful Post:
 Old 11-17-2009, 07:50 PM   #62
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
to tell ya the truth yes I have a gt3071 with most supporting mods but I planned on doing the install on stock bottom end.
If my set up is anything like 18PSIWhiteMs3 i will make more then 400 whp and that scurred the crap outta me.
seeing how I have 50k on the dot as of tonight and 18psi has 8k? lol
when I do the install I plan on driving to Akuma ASAP to get dyno tuned.
I trust stock bottom end with 400whp is safe enough with a good tune but lets say I install this new sensor and have Akuma tune for it?..
I don't wanna be the first guy to find out how much power a 2.3mzr can make before I go boom on stock block!...lol
I suggest 18PSIwhitems3 and or samsel....they both have gt3076's on stock motors and maybe one will be willing to see how much more power they can make with the new sensor and tune.
If you can get this sensor out to one of them and we see well over 400whp on stock bottom blocks then I'll deff be down for the senor.
as of now I'll do my install (hope to make 400whp) and when I feel the time is right i'll build my motor. I hope installing the 3071 with 50k I won't blow a hole in the block if anything goes wrong..lets just hope for a fried piston ring and low compression then I will have the will to build..if hole in block...I'll have to think real hard on what I wanna do.
again...contact 18psi and samsel and lets hope they are down for makin 500 whp on stock bottom. if they can I will....
ty for thinking of me as "that speedsixxx guy" lol =)
 Old 11-17-2009, 10:15 PM   #63
Captain
Okay, cool! GL, your brave to run that setup on 50k, might wanna start saving a bit month to month for a build just in case. Look forward to your tune.
www.permtuning.com
SpeedSixxx (11-18-2009)
 Old 11-18-2009, 12:23 AM   #64
SpeedSixxx's Avatar
Groans: 778
are you Canadian Dj?
 Old 11-18-2009, 12:23 AM   #65
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
im not trying shit. my car runs fine, i dont want anymore power on my stock motor. i spent 1000 on tuning in the last month between the SST and this gt3076. Im done spending money on tuning lol.
i think you have a man crush on my speedsixxx. your always talking about me and shit. leave me out of this. why don't u try to pop your motor.
Last edited by 18psiWhiteMS3; 11-18-2009 at 12:31 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to For This Useful Post:
 Old 11-18-2009, 09:44 AM   #66
Captain
I am not canadian.
I'm a cowboy.
www.permtuning.com
MarkyMark (11-18-2009), SpeedSixxx (11-18-2009)
 Old 11-18-2009, 10:47 AM   #67
phantom3's Avatar
Groans: 190
We have cowboys in Canada. I just finished working the Canadian Finals Rodeo...
Bullfighters are pussies.
The Following User Says Thank You to phantom3 For This Useful Post:
 Old 11-18-2009, 05:32 PM   #68
SpeedSixxx's Avatar
Groans: 778
18psi will pop in t-minus 400 hours!
 Old 11-18-2009, 06:34 PM   #69
bf360's Avatar
Posts: 2,069   (View Stats)
bf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the world
Groaned at 42 Times in 35 Posts
so now that weve established 18psi is a pussy, who has the balls to try this?
bf360 is offline   Reply With Quote
The Following User Says Thank You to bf360 For This Useful Post:
 Old 11-18-2009, 06:37 PM   #70
SpeedSixxx's Avatar
Groans: 778
ill take one DJ if ya wanna send me a built unit..
when i get tuned i'll leave it off and see what i make..
then i;'ll add it and re tune same day and see what i can get out of it..
fuck if i blow i blow. then i'll build..
up to you DJ wanna send me a unit?...
my goal is to make more whp then 18psi so when i roll race him i rape him...im not pussy!
 Old 11-18-2009, 06:42 PM   #71
bf360's Avatar
lol your guna need about 420whp to beat him from a roll
but he wont race yet anyway his car is a garage queen lol
 Old 11-18-2009, 06:44 PM   #72
18psiWhiteMS3
Lurkers
Posts: n/a
garage queen till the spring : O )
 Old 11-18-2009, 06:48 PM   #73
SpeedSixxx's Avatar
Groans: 778
ill be waiting till then.....hope ur 8k motor holds compression when u restart it after months of sitting...
 Old 11-18-2009, 07:56 PM   #74
Captain
Sure i'll send one. I've got to finish em up and test it out. Hopefully have em done manana, and ship on friday. PM me your addy speedsixxx.
www.permtuning.com
 Old 11-20-2009, 01:55 PM   #75
Captain
Double post merge will probably kill my bump, but oh well
All ckts are built. I need to test them one more time in their housings, and will probably ship them tomorrow (sat) or next monday. I'm leaning towards monday, cause that will give me a chance to at least list the tables that will likely require tuning.
I also want to stress that this is completely experimental on all our part. Install at your own will, and nobody's responsible for any damage incurred if there is any. If you guys want to wait till my pump shows up, and let me do all the guinea work, i will, and i'll post up any issues as they pop up.
Right now i'm just sending out 4 units, to Socks, Super, JJ, and speedsixxx.
Only concern i can think of right now, is that the circuit's output (since it's a single supply op-amp) clips at a lil above 4V and just below 1V (on the output, ecu side). But from what i understand, the ecu would never be commanding for >4V or <1V, since idle is 1.4V or so, and 1600psi is 3.8V. Again, i'll guinea this shit if you guys want to wait.
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
kgb (11-20-2009), Lex (11-20-2009), phantom3 (11-20-2009), SpeedSixxx (11-20-2009)
 Old 11-20-2009, 02:29 PM   #76
Deadman's Avatar
Posts: 868   (View Stats)
great news dude.... things are beginning to get interesting!
Deadman is offline   Reply With Quote
 Old 11-20-2009, 02:48 PM   #77
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
shits cracka lackin'!!!!!!!!!!!
on another note, dustin did make these for free and isent charging for shipping or parts cause hes that chill a dude but i threw him 10 bux anyway to cover it all. dont be a jewbert and send the boy some $$$
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
Last edited by superskaterxes; 11-20-2009 at 03:01 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-20-2009, 03:19 PM   #78
Captain
Send me lots of moneyz, then put these mini bombs on your carz. Each scalar circuit comes with moth ballz for the gas tankz!
I'm down for pitch-ins on the shipping, but wouldn't ever charge for a "beta" circuit. This is purely R+D in my mind.
www.permtuning.com
 Old 11-20-2009, 03:23 PM   #79
Must Have Teh 10's!
yea but RR charges people for things before they are even available so they can continue to do R&D how come you dont do that?
ROFL
Fagwagon (11-20-2009)
 Old 11-20-2009, 03:25 PM   #80
phantom3's Avatar
Groans: 190
DJ,
Do you have a schematic of these available? I wouldn't mind making one up and testing it.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/how-scale-hpfp-pressure-sensor-42364/
PERM's MS6 This thread Refback 09-12-2012 07:34 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback 05-02-2012 07:56 AM
Fuel Pressure Tuning - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-04-2010 03:54 PM
DCR Needs a MS6 for measurements - Mazda6 / Atenza This thread Refback 12-01-2009 02:50 PM
albuquerque nm mazda 6 owners - Mazda6 / Atenza This thread Refback 11-25-2009 07:58 AM
North American Mazdaspeed club This thread Refback 11-16-2009 09:52 AM
Fuel Pressure Tuning - Mazda6 / Atenza This thread Refback 11-15-2009 08:22 AM
2010 Mazdaspeed 3 Weight on Scale - Input cheez 2010 MS3 - Engine, Transmission & Driveline 46 12-09-2009 07:19 PM
GM Keeps Opel for Scale and Innovation: Analysis Haltech Automotive News 0 11-04-2009 01:00 PM
P0107 - Barometric pressure sensor low input vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-14-2009 01:31 PM
Spec out your own Maserati - in 1/43 scale Haltech Automotive News 0 06-19-2009 05:00 PM
Ford sees no large-scale aid for Visteon Haltech Automotive News 0 01-29-2009 01:30 PM
Page generated in 0.57799 seconds with 36 queries
