 Old 06-20-2012, 04:45 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default COBB Tuning AccessTUNER Race Tuning Software for ADM Mazda3 and Mazda6 MPS and More
COBB Tuning is proud to announce the immediate availability of AccessTUNER Race for Australian Mazda3 and Mazda6 MPS vehicles. Now owners of AccessPORT-equipped, turbocharged Mazda3 and Mazda6 vehicles have the same ability to custom-tune their ECU calibrations using the same free AccessTUNER Race tuning software enjoyed by U.S. MAZDASPEED enthusiasts! We are also releasing minor updates that address the Australia maps P0101 DTC code issue as well as the 2010 MAZDASPEED3 hesitation issue that some users have experienced. Read on for more information regarding these updates.
AccessTUNER Race for ADM Mazda3 and Mazda6 MPS
COBB Tuning announces the release of AccessTUNER Race tuning software for AccessPORT-equipped Australian 2007-2011 Mazda3 MPS and 2004-2006 Mazda6 MPS vehicles. The AccessPORT is the only hand-held OEM ECU flashing, managing and monitoring device available for the turbocharged Mazda3 and Mazda6 MPS. When combined with AccessTUNER Race software, the result is an unrivaled, self-tunable engine management system with all of the sophistication and drivability inherent to the factory ECU.
The availability of AccessTUNER Race rounds out the suite of COBB Tuning engine management products available for the Australian Mazda3 and Mazda6 MPS. AccessTUNER Race tuning software has the same powerful feature-set as our AccessTUNER Pro tuning software. Its capabilities range from making minor tweaks to COBB Tuning Off-The-Shelf maps for maximum performance, all the way to authoring fully customized maps for major modification upgrades. AccessTUNER Race puts full tuning control in the hands of the end user.
To acquire your free copy of AccessTUNER Race, simply fill out the AccessTUNER Race Download Request Form and you will soon receive an email with a download link. If you already have AccessTUNER Race on your PC, click on Help in the Menu Bar, select Updates and follow the instructions.
Australia Map P0101 DTC Bug Fix
Some Australian users have been experiencing P0101 DTC codes (Mass Air Flow Sensor Inconsistent with Throttle Position Sensor). All ADM v230 maps in the Mazda AccessPORT Off-The-Shelf Map Database have been updated to eliminate this code. If you have experienced a P0101 code, remove all of the current ADM v230 maps from your AccessPORT, download the latest ADM v230 maps from the Off-The-Shelf Map Database, transfer the new maps to your AccessPORT and flash to the ECU using the Change Map feature.
If you are using a customized version of the ADM v230 maps, simply open the map in the latest version of AccessTUNER Race, turn off the P0101 code in the DTC Defeat menu, save the map and flash to your ECU.
2010 MAZDASPEED3 Hesitation Bug Fix
The hesitation issues experienced by 2010 MAZDASPEED3 owners running load-based logic maps have been traced to the transition between open-loop and closed-loop modes. This issue has been resolved in the latest version of AccessTUNER Race. Simply update your AccessTUNER Race tuning software by clicking Help in the Menu bar, select Update and follow the prompts. Once the software has been updated to version 1.9.1.0-4169, open and resave your map in AccessTUNER Race before reflashing it to your vehicle. The hesitation issue will be resolved.
As always, if you have any questions about the AccessPORT and AccessTUNER, or any other COBB Tuning products, please call us at 866-922-3059. Get up-to-date product announcements and COBB Tuning news via our COBB Tuning Mailing List. You can always be a part of the latest conversations with COBB Tuning by tuning in to our our facebook.com/cobbtuning and twitter.com/cobbtuning pages.
MAZDASPEED EXPERT GROUP
- ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE
The Following 8 Users Say Thank You to Cobb Tuning For This Useful Post:
Black Metal (06-20-2012), Boost_creep (06-20-2012), Keko (07-01-2012), kgb (06-20-2012), Lex (06-20-2012), Speed3eak (06-26-2012), steviekfc (07-01-2012), TWOptSL0W (06-20-2012)
 Old 06-20-2012, 04:55 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
upside down picture fail?
edie: or because down under
 Old 06-20-2012, 04:57 PM   #3
OneBAMFpog's Avatar
Posts: 642   (View Stats)
OneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the world
Groaned at 25 Times in 11 Posts
It's Mazdaspeeds for the other side of the world... That's why it's upside down... "Down under" Joke.
2010 Black Mica Mazdaspeed 3 Stock
2010 Velocity Red Mica Mazdaspeed 3
Current Mods:
COBB SRI -- TIH -- ACCESSPORT -- EBCS
CP-E DP AUTOTECH FP INTERNALS CORKSPORT 80 MM DUAL EXHAUST
JBR SOLID SHIFTER BUSHINGS -- 88 DURO RMM -- TMM -- PMM--TIG AND COOLANT BYPASS FORGE BPV
ACT ZX5-HDG6 CLUTCH KIT DEVIL'SOWN METH KIT
EDDIE BAUER CARSEAT MOD
DJ tuned: 302 whp and 339 wtq
"YOU PULLED ON ME LIKE A FREIGHT TRAIN!"
OneBAMFpog is offline   Reply With Quote
The Following 2 Users Say Thank You to OneBAMFpog For This Useful Post:
kgb (06-20-2012), TWOptSL0W (06-20-2012)
 Old 06-20-2012, 05:01 PM   #4
It's actually quite clever
atvfreek (06-20-2012), Black Metal (06-20-2012), lilred (06-20-2012)
 Old 07-01-2012, 05:40 AM   #5
steviekfc's Avatar
Posts: 73   (View Stats)
steviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant futuresteviekfc has a brilliant future
Just bought mine for the MPS 3, fuckin stoked yeeeeew
steviekfc is offline   Reply With Quote
 Old 07-01-2012, 12:26 PM   #6
Karmat's Avatar
Posts: 1,179   (View Stats)
Everything is upside down in Australia
Sent from my DROID RAZR using Tapatalk
2002 Corvette Z06 (Black)
 Old 07-01-2012, 12:30 PM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
So far, the ADM ATR is working beautifully. Good job as Cobb!
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 07-01-2012, 12:42 PM   #8
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
So... What about the Mexican MS3?? lol I don't really care but just wondering lol
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
COBB Tuning AccessPORT for Australian MAZDA3 MPS and MAZDA6 MPS Cobb Tuning 2010 MS3 - ECU Computer Tuning 11 05-17-2012 11:46 PM
COBB Tuning AccessPORT for Australian MAZDA3 MPS and MAZDA6 MPS Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 3 05-17-2012 08:21 AM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 18 07-07-2011 05:22 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning Cobb Tuning 0 06-30-2011 03:32 PM
Page generated in 0.31026 seconds with 27 queries
