| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Oct 2008 Location: Orlando/ Daytona Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
(Thread Starter) | Not Ranked : 0 score I built a new computer with windows 7 64-bit home on it! My brother has a laptop with xp 32-bit (like my old desktop was running) and everything for the AP runs fine. I installed the updater and the AP doesnt even see the computer. It doesnt want to connect to the computer and the updater keepts telling me to connect the ap to the computer. So i download Manager to see if it has the same connection problem and it does. Same goes for ATR. I tried a number of ways on connecting it like plug it in before running the program and after running it and stuff but still no good. Anyone with Windows 7 having the same issue? Oh and lookded on cobbs site but didnt find much except bioevole had the same prob!
__________________ 09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic [Today 11:50 PM] aaronc7: i just measured mine, a little over 12 |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Best bet is to run Windows Virtual Machine (free from MS) and put XP on that. That solves all these old-style hardware/software-new OS issues. It works absolutely rock-solid. |
(Thread Starter) | Not Ranked : 0 score I think i found the problem! It works if i move the wire on the ap a certain way cause it wont read my ecu either sometimes unless i move the usb cord in the perfect position! but whats weird is that it still powers up but doesnt read! plus virtual pc only work if you have proffessional and up which is retarded! thanks for the help though!
![]() Join Date: Mar 2009 Location: West Hartford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score get a new cord a radio shack! 20$ |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score Just in case anyone is still googling this issue.... Just had this problem after it working previously. It seems significant to use the USB cable that the AP came with, it's grey. At least this was the case for me when I tried to use it with another USB cable.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| Not Ranked : 0 score Also if the AP itself is tweaking out in your car with mad-ass readings. Flash ECU to another tune, then back to the one you want.
| AP not connecting | Tomas | Cobb ATR Support | 7 | 08-04-2009 10:31 AM |
| Connecting the Dots: Hyundai's 2011 product plans | Haltech | Automotive News | 0 | 06-22-2009 03:00 PM |
| Manley "turbo tuff" I-Beam connecting rods *oem replacements | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 02-12-2009 04:40 PM |
| Finally affordable connecting rods that have some quality behind them. | ptperformance | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 02-11-2009 01:30 AM |
