| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Dec 2010 Location: Richmond VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I am not looking for someone to research for me I just want to know if i am thinking the right way. I don't want to mess up my car. I have been just reading the forums for 2 months trying to absorb all the info. There is a ton of it on here. Current parts i have to install. Corksport SRI with turbo inlet CP-E DP catted. rear motor mount insert (i know nothing to do with tuning.) From what I have read I need to get an Cobb access port if i want these mods to work correctly with my car? If I do not do an access port I will not get the power out of the mods. I have not seen another option that would give me the same benifits of the AP? am I missing a better option that provides the easy of plug and play? I know i can get a custom tune but would rather not do that. I think for the same price the AP could get me where i want and still be able to do monitoring of my car. I am not looking to do big power on the car. Just some bolt on mods to give it more power but continue to use it as a daily driver. I guess I am just looking for a "hey noob you are on the right track" or a "do some more reading and learn more before you post!" Also on a side note. Does anyone know of a shop in the richmond va area that would do a DP instalation? I would even drive to NoVa. Its a little cold out for me to do this in my driveway. Thank you for the help. |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score you dont have to get a ap but what you are going to want is a fuel pump upgrade. your pressure will be sure to drop with the mods
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| The Following User Says Thank You to IshiKage For This Useful Post: | m4tic (02-03-2011) |
| Not Ranked : 0 score While you don't need a tune with the parts you are planning for, you will get the maximum out of the car with one. That doesn't mean you won't gain any power with just the bolt-ons, because you definitely will. You could run it for a while and then, down the road, get a tune. The AP and CPE's standback are the most flexible products for tuning, and the Hypertech is just a plug and play deal with canned tunes (no custom tuning). The AP has a datalogging feature that is worth the money, alone. The standback and hypertech do not have this functionality. Each have their ups and downs; there are good threads about this. |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score upgrade your fuel pump and lose the stock top mount intercooler
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following User Says Thank You to m4tic For This Useful Post: | IshiKage (02-03-2011) |
(Thread Starter) | Not Ranked : 0 score So to add a downpipe and intake i also have to add a tmic and a fuel pump? maybe my question was not clear. i just wanted to know if adding a dp and intake along with a tune will be safe to run and ok for the car. if i have to do a fuel pump and a top mount intercooler to upgrade my downpipe and air intake.. i might as well sell the car and just get something that is out of the box faster. |
| Not Ranked : 0 score no it will not... your fuel pump IS going to fail with flow mods as it cant meet higher volume demands the stock tmic runs the turbo too hard to attain stock boost, let alone upped psi from a tune spend a little more $$$ to alleviate these issues or drop more money on a new car
![]() Join Date: Sep 2009 Location: Estero, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score not true....you can run these mods without needing a fuel pump......you can monitor your fuel pressure on the cobb ap and if you see that it is not holding then ok, but i have ran the mods in my sig for the last 6 months with no problems with fuel pressure
__________________ Mods: DJ E-Tune, Cobb AP, Cobb SRI, RPMC Turbo Inlet, CxRacing FMIC, HKS SSQV, PG Manifold, TurboXS Catless DP, Turbo XS Test pipe, HKS Catback, Twm Short Shifter, Desert Eagle Shift Knob, Denso itv22 plugs, BS Delete mod, H&R Lowering Springs, NextMod spoiler, Kazera Kz-K Wheels, tinted 15% |
| Not Ranked : 0 score yes leave it up to chance and run your car on the stock fuel pump an upgraded pump is just a strong suggestion
Groans: 278
intake, dp, fp, fmic, ap is the route i would go, in that order. my fuel pressure dropped with intake, tp and ap. so his pump will drop pressure with intake and dp, so UPFP should be next then FMIC to keep the bats cooler thus not losing power b.c of the shitty tmic
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
| The Following 2 Users Say Thank You to IshiKage For This Useful Post: | m4tic (02-04-2011), Vanilla Gorilla (02-09-2011) |
![]() Join Date: Jan 2011 Location: Thornton, Co
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 17 Times in 2 Posts
| Not Ranked : 0 score Wheres a good place to buy a upgraded FP for a speed 6? Ive looked o streetunit and they dont carry one. |
| Not Ranked : 0 score KMDtuning.com or cp-e.com you can also order internals from goapr.com or awe-tuning.com ... everything is catered to AUDI/VW except for cp-e
| The Following User Says Thank You to m4tic For This Useful Post: | IshiKage (02-05-2011) |
I know cp-e makes one but $700 might be a little high on the price for me. | |
![]() Join Date: Jan 2011 Location: Tampa/Wesley Chapel, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score $700 now will save you 4 times that when failure comes into the playing field. Better to be safe than sorry my man... |
![]() Join Date: Nov 2010 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
Groaned at 10 Times in 3 Posts
| Not Ranked : 0 score I got a $380 quote from PTuning in Manassas to install a CP-e catted downpipe on my 2010 speed3.
__________________ Black Mica 2010 Speed3; Xcel Nano SRI; JBarone short shifter, bushings, shift knob and rear sway bar; Corksport RMM inserts; Ptp HPFP internals; Cobb AP; Corksport TMIC; Denzo ITV22; CP-e CDP; Tuned by Ptuning |
| Not Ranked : 0 score The only other option would be to send your pump out and have them do the rebuild. That would still require you to unhook the lines, pull the pump, and re-install. Check with KMD to see if they would do it. BUT, once you have it out of the car, its not much more to pull it apart and do it yourself. The hardest part is getting the damn thing out. |
| Cobb Access Port....Canadian! | MPS | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 10-13-2008 03:57 PM |
| Surgeline Tuning to offer custom tunes for Access Port customers | PDXImportRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 54 | 09-07-2008 06:02 PM |
