| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Sep 2008 Location: USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 392
| Moving this to ECU Tuning
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score I may be wrong don't hold me too this but on the dash hawk at the bottom right hand corner doesn't that little box that goes C,O and L on a 4 box pid screen tell you if your in open or closed loop? if so im closed loop most of the time with blips of open near or between 2k and 3.5 k while im accelerating slowly im all open loop if coasting OUT of gear. coasting in gear is mainly C and L. Now don't hold me to this just yet I could be completely off.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous Last edited by Darksun280; 09-22-2008 at 06:40 PM. |
| Not Ranked : 0 score the car is ALWAYS in closed loop unless you are WOT or you are decelerating with your foot off the gas completely. this is a widely talked about topic so just do some googling....
| The Following User Says Thank You to superskaterxes For This Useful Post: | Sasuke-kun (01-12-2019) |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
| Not Ranked : 0 score I've seen a few threads now with people claiming it's in open loop above 3000-4000RPM regardless of WOT. Any truth to that?
__________________ In reality I love lenny |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score the second o2 sensor feed back triggers closed loop and open loop it is this that tries to keep the car stoich AFR while in closed loop keeping the MPG up
__________________ Piasini Tuned ![]() power mods=SRI/Autoexe TMIC 312whp/336 tq |
![]() Join Date: Jul 2008 Location: Edgewater, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Open loop does NOT use the O2. Closed loop does use the O2. you use open loop until the car reaches normal operation temps, is in WOT or a high throttle postion, or under decel with the throttle plate closed. there is great benefit in fuel economy and emissions to running in Closed loop, so car makers try to stay in it as much as is reasonable |
| Not Ranked : 0 score thats what i ment
Groans: 175
| Not Ranked : 0 score That means I'm right Dash hawk tells you what loop your in cause when I started the car tonight it was at "O" and after I let it warm up and started driving normal it goes to "C". Under WOT I start at C then its goes to "L". On deccel out of gear its in open loop and deccel in gear its in closed loop
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
![]() Join Date: Mar 2008 Location: Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score So what the hell does the "L" stand for? I've seen that too...
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq |
Groans: 175
| Not Ranked : 0 score No Idea but when I'm wot I'm mainly in L
| Not Ranked : 0 score Here you go fockers Fuel System Status (C = Closed Loop, O = Open Loop, L = Open Loop due to Engine Load, F = Open Loop due to a Failure/Trouble Code, P = Closed Loop with Problems, - = Data not available, U = unknown status) When this value is displayed on the screen or on the PC from a data log, the following values are used: 0 = Unknown 1 = Open Loop 2 = Closed Loop 4 = Open Loop due to Engine Load 8 = Open Loop with Fault 16 = Closed Loop with Fault http://www.dashhawk.com/downloads/Da...er%20Guide.pdf
| The Following 8 Users Say Thank You to NYpest For This Useful Post: | booya620 (09-23-2008), Colonel Speed (09-23-2008), Darksun280 (09-23-2008), Fobio (09-23-2008), gsrtype1 (09-23-2008), kingpin748 (09-23-2008), SLS MS3 (09-23-2008), thejake (09-26-2008) |
Groans: 175
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
| Not Ranked : 0 score I said the rear o2 has significant change over the a/f ratio almost a year ago.... Our car doenst work liek traditional cars....that rear o2 is there for more reasons then just to monitor the cat. You don't beleive me? Install a diode in your 2nd o2, watch your commanded a/f ratios go from 14.7 to 14.2....yes its not good for gass mileage to have a 14.2 af ratio at idle and cruising, but lets think about partial throttle/transition parts of the rpm band.....could be the very reason my car is still alive today |
Groans: 175
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score you have a diode on your 2nd o2 chris? or are you saying dont do it.
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
Groans: 175
| Not Ranked : 0 score don't do it
![]() | | #19 | ![]() |
| Not Ranked : 0 score Phil we talked about this at the meet remmeber with out that rear o2 sensor feed back your cars is all confused on what its suposed to be doing
![]() | | #20 | ![]() |
| Not Ranked : 0 score actually i have installed it 3 days ago. With the cold weather i finally started getting the p0139 code. I was running 14.7 the second i installed the diode, 14.2 with my last tbe, the way they had the o2 positioned also commanded 14.2, then i switched to cpe's tbe and it went up to 14.7, now its back at 14.2 with the diode |
![]() | | #21 | ![]() |
__________________ Piasini Tuned ![]() power mods=SRI/Autoexe TMIC 312whp/336 tq | |
![]() | | #22 | ![]() |
| Not Ranked : 0 score its something i find helpfull. the car commands 14.2 not 14.7, meaning partial throttle its 14.2 then dips to the 12s the second you touch the gas. No partial boost and 14.7 a/f ratios. Why does it work? Who knows, i dont know the exact role of the 2nd o2, but like i said, it sure as hell isnt just to monitor the cat |
![]() | | #23 | ![]() |
Groans: 175
| Not Ranked : 0 score well mine reads 14.2 with the 02 extender. Chris you whore your suppose to let me know when you do things to your car...
![]() | | #24 | ![]() |
Groans: 106
| Not Ranked : 0 score im at 14.7 now. maybe ill throw on a diode when i install the SB.
![]() | | #25 | ![]() |
Groans: 175
| Not Ranked : 0 score but you WANT to be at 14.7 lol
![]() | | #26 | ![]() |
Groans: 106
| Not Ranked : 0 score damnit stop confusing me! lol so 14.7 is the goal here?
![]() | | #27 | ![]() |
Anyway cool
![]() | | #28 | ![]() |
| Not Ranked : 0 score I think hes saying that the 14.2 is helping him with the "lean" area @ onset of boost
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
| Not Ranked : 0 score MPG /NO2 !! Closed loop is supposed to keep you at 100% clean burn (14.7 afr) while crusing and at idel your in closed loop saving gas and being GREEN
| The Following User Says Thank You to NYpest For This Useful Post: | mordant80 (09-23-2008) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score it probably is, cause what a diode does is change whatever voltage goes through it to roughly .45-.50. That drop from whatever the original voltage was might make the ecu change what it thinks ti stoich.....once again this is all theory and i have no proof nor the tech know how to explain this in detail lol as for as beeing green lol, im an enviornmental scientist...i also run no cats |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
Open Loop - Input from the O2 sensors is ignored. The engine gets its fuel ratios from lookup tables designed to richen the fuel mixture for maximum power. The feedback loop is disconnected, i.e. "open."
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle | |
| The Following User Says Thank You to SLS MS3 For This Useful Post: | mordant80 (09-23-2008) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score never messed with part throttle stuff on the standback yet |
![]() | | #35 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
| Not Ranked : 0 score I'm at 14.2 at idle through MAF xfer changes via the standback
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Not Ranked : 0 score what were you at before. my maf xfer are 5 for the first row and 8 for half the 2nd row |
![]() | | #38 | ![]() |
getting really interesting.....
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 | |
![]() | | #39 | ![]() |
Groans: 106
| Not Ranked : 0 score yay! you guys do the hard work and ill just reap the benefits!
![]() | | #40 | ![]() |
![]() Join Date: Mar 2008 Location: Baltimore Md.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
| Not Ranked : 0 score yea with my first o2 out i stayed in open loop, with it in its closed at idle and so on
__________________ [SIGPIC][/SIGPIC] Gotta Love The Turbocharged Wagon |
| How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02 | 94jedi | MazdaSpeed 3/6 - ECU Computer Tuning | 22 | 05-13-2014 08:45 PM |
| Open/Closed Loop Transition, Some New Observations | superskaterxes | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-18-2008 11:35 AM |
| Open Arms in Open Wheels: reunited IndyCar season kicks off at Homestead | Haltech | Automotive News | 0 | 04-01-2008 09:20 AM |
| Alfa may buy closed factory from Big 3 for U.S. production | Haltech | Automotive News | 0 | 03-31-2008 02:10 PM |
| Expiring Creative HN-700 Closed-Back Circumaural Headphones w/ Active Noise Reduction $24.99AR | Haltech | Hot Deals Section | 0 | 03-31-2008 01:00 PM |
