  • 1 Post By MSMS3
 Old 09-18-2019, 01:44 PM   #1
deakgegi's Avatar
Posts: 8   (View Stats)
deakgegi will become famous soon enough
Default 100% WGDC, LOW LOAD, LOW BOOST
Hi!
I have a 3" catless exhaust, hpfp internals, fmic.
I installed the ots tune from Versatune for 98 octane high load high flow downpipe.
Unfortunately my WGDC quickly goes up, while my boost pressure drops with load as well.
No knock is detected.
Do I have a boost leak?
Whcih components do I have to check, like bpv and wastegate?
Thanks for the help!
deakgegi is offline   Reply With Quote
The Following User Says Thank You to deakgegi For This Useful Post:
zaclaw (02-11-2020)
 Old 09-18-2019, 01:48 PM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
LOL
Stockish
The Following User Says NO Thank You to Db09ms3 For This Un-useful Post:
MSMS3 (09-18-2019)
 Old 09-18-2019, 10:37 PM   #3
MSMS3's Avatar
Posts: 2,825   (View Stats)
LOL
Did you even look at his f’kin log, or do you know what to look for?
Db09ms3 likes this.
 Old 09-18-2019, 01:54 PM   #4
deakgegi's Avatar
Could you help please?
 Old 09-18-2019, 01:56 PM   #5
Db09ms3's Avatar
No
Stockish
MSMS3 (09-18-2019)
 Old 09-18-2019, 01:57 PM   #6
deakgegi's Avatar
Or atleast guide me to the right direction..
 Old 09-18-2019, 01:58 PM   #7
Db09ms3's Avatar
Any CEL's? Any changes in driveability?
Stockish
MSMS3 (09-18-2019)
 Old 09-18-2019, 01:58 PM   #8
deakgegi's Avatar
No CEL's, pretty same driving experience.
 Old 09-18-2019, 01:59 PM   #9
Db09ms3's Avatar
Time for a protune
Stockish
 Old 09-18-2019, 02:02 PM   #10
deakgegi's Avatar
Anything I should consider changing in the tune to get the expected load results and lower wgdc?
 Old 09-18-2019, 10:26 PM   #11
MSMS3's Avatar
Originally Posted by deakgegi View Post
Hi!
You have simply maxed out the flow of the K04 turbo. At 17 psi and 1.7 or so load, the turbo is doing all it can. The wastegate can be at or near 100% under those conditions. You might check for a leak, and there could be one, but you’ll not likely make more power. A custom tune would help smooth out fueling, AFR and tweak timing. The K04 is a fast spooling but smallish turbo. Running a 3” catless dp can max it out easily. Ask me how I know. See mods below.
The K04 cannot sustain 17 psi at high rpm on pump gas. It turns into a flamethrower and just superheats the air. Boost has to taper to 15 psi approaching redline to save itself, and that is what it is properly doing. You may get more power by reducing boost up high, increasing timing and keeping AFR rich.
What fuel? Run the best 93 octane or add a couple gallons of E85 per tank of gas.
 Old 09-18-2019, 11:30 PM   #12
deakgegi's Avatar
Thanks for the helpful review, I appreciate it!
I'm running on OMW MaxxMotion 100 in Europe.
I've seen others here running even 20 psi, and holding 18 psi under high rpm with the ko4
I'm only flowing around 220 g/s, isn't that too low?
Please tell more that can help me understand the situation.
Even the OTS map targets a higher boost and much lower WGDC, that's why I think I might have mechanical problem.
I'm really happy to learn if my situation is normal, but I want to know the reasons.
 Old 09-19-2019, 07:29 AM   #13
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
for sure, a tune won't help to make more boost when the wastegate duty is already maxed out on the turbo....(A proper tune have other benefits but not thoses)
But keep in mind the boost level isn't that revelant, it tell more about the restriction of your engine. One could be making twice your power with the exact same boost level with huge turbo and engine works....
What is strange is flow level, you actually have a less restrictive exaust that should allow for more flow at this wastegate duty level. I would be expecting 260-280g/s...
If you would have a leak after the turbo, that reading would just increase...
You could have a bad maf scaling into the tune against your intake size....this would be confirmed by the maf cal. process....
If you aren't very higher than sea level and all the above is ok, you may have something restrictive in the intake or exhaust path....
You may also have something wrong with your ebcs....you may try to disconnect it(electric) and see if it reduce your power a lot like it should happen. If not you may check if the bypass air path is ok and if the solenoid operate well.
You can also check if the wastegate rod is holding tight the flapper inside the turbo.
there is a lot more things that could make this....a damaged turbo wheel, leaking wastegate flapper, a bad filter etc...........
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
MSMS3 (09-19-2019)
 Old 09-19-2019, 07:58 AM   #14
deakgegi's Avatar
I currently have stock intake, so I'm using the ots calibration.
The tubing after the turbo has no leaks, holds 2 bar steady no problem.
My next tought is to check the wastegate and the ebcs as well.
If I disconnect the ebcs connector, I will be running on spring pressure, so I will lose some boost, right? If I make the same figures, it means something is wrong with the ebcs.
I have an open 3" exhaust with no cats, the car was serviced lately, so it should have nothing inside. Also sounds great, can't really hear anything special.
I will get some more logs today and post them here, thanks for the help!
 Old 09-19-2019, 09:52 AM   #15
Jeff23spl's Avatar
stock intake ? you mean the oem restrictive plastic box with a square paper filter ? or oem size maf hosing ?
i never tested a k04 on spring pressure with your conditions to validate but it would be like 0%wg duty....but restrictions in the vaccuum line returning to the turbo inlet hose would decrease the effect of the wastegate duty as well
Wife drive 2010 CX7
 Old 09-19-2019, 02:55 PM   #16
MSMS3's Avatar
I went back and looked at some of my old logs. At 220 g/s mass air flow, the wastegate was more at 55-60% duty cycle under load.
Know this, though: g/s alone is not the story. If the fuel is rich and timing is advanced, you can make a lot more power on the K04 than people realize based on air mass flow alone. I don't think my tune ever allowed more than 240-250 g/s with a good aftermarket high flow AEM/Mazdaspeed CAI and catless 3" dp/rp,. But, with very aggressive timing advance of 17-18 degrees at high rpm and rich AFR for cylinder cooling to permit that much timing without knock, it was making 300-310 whp on 93 pump gas on the little K04.
I think there must be a combination of low flow on the intake side and something going on regarding the operation of the wastegate (EBCS, wastegate actuator, wastegate flap or such). Just a suspicion. It's probably hitting target boost for the tune, but working way too hard to get there.)
 Old 09-20-2019, 02:37 PM   #17
Jeff23spl's Avatar
with full bolt on for my 6 and a 2.5'' exaust i was seeing above 260gs without going that high in wg duty for sure but i don't have much logs or the k04 to test again....
Wife drive 2010 CX7
MSMS3 (09-21-2019)
Overshooting load targets, low wgdc - what's wrong? mituc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 03-14-2016 08:05 AM
WGDC being pulled despite being well below boost/load targets MD1032 2010 MS3 - ECU Computer Tuning 5 12-04-2015 04:46 PM
WGDC Inconsistencies with Boost Tuning - Random flatline and no wgdc compensation phate 2010 MS3 - ECU Computer Tuning 38 02-10-2013 01:49 PM
No change in boost from 0% WGDC to 100% WGDC phate MazdaSpeed 3 - Engine, Transmission & Driveline 30 12-12-2011 03:27 AM
0 WGDC, High Load, Low Boost RJTSi
Cobb ATR Support
6 01-19-2010 10:04 AM
Page generated in 0.35415 seconds with 24 queries
