| Approved MSF Vendor ![]() Join Date: Aug 2014 Location: Tempe AZ
Rep Power: 113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I've opted to split off the various platforms to keep discussion on topic. More info per platform coming soon, please stand by!
__________________ TCE PERFORMANCE PRODUCTS Your one stop....for Wilwood Brakes. ![]() * Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * WRX *Super Duty * SHO * Mustang *...and more! |
(Thread Starter) | Not Ranked : 0 score MAZDA MX-5 (Miata) Kits will include: 1. Wilwood 11" FBDL front kit. 2. Wilwood 11" DP6 front kit. Same kit as the Mazda 3. 3. TCE/Wilwood 11.75" DPR front Track kit. Derived from the 11.75 MINI kit per request. 4. Wilwood 13" FNSL6 front kit. * 5. Wilwood 14" FNSL6 front kit. * Years: 1989-2005 *Years: 2006- current
(Thread Starter) | Not Ranked : 0 score 1. Wilwood 11" FBDL Front Kit. WILWOOD FRONT BRAKE KIT - VEHICLE COMPATIBILITY LISTING Kit Type 1: BRAKE KIT: Forged Dynalite Big Brake Front Brake Kit (Hat) Spindle Type: Factory Disc Spindle; VEHICLE MAKE: VEHICLE MODELS: Mazda Mazda MX-5 Miata 1989-2000 All Mazda Mazda MX-5 Miata 1990 All , from serial 152766 Mazda Mazda MX-5 Miata 1990 All , thru serial 152765 Mazda Mazda MX-5 Miata 2001-2005 All except Sports Suspension Mazda Mazda MX-5 Miata 1991-1993 w/ ABS Mazda Mazda MX-5 Miata 2002-2005 w/ Sports Suspension Mazda Mazda MX-5 Miata 2001 w/ Sports Suspension from VIN 206467 Mazda Mazda MX-5 Miata 2001 w/ Sports Suspension to VIN 206466 Mazda Mazda MX-5 Miata 1991-1993 w/o ABS Base priced with black anodized calipers and plain face rotors. Optional RED powder coat (and others) and cross drilled/slotted rotors. List priced at $629.99 plus ss flex hoses. TCE Price: much lower, please inquire.
| The Following User Says Thank You to Todd@TCE For This Useful Post: | SeanE (08-31-2014) |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Do options 1, 2, & 3 fit under 15" wheels? Is there a certain width/offset the wheel must be in order to fit over the caliper without touching? Ex: 15x9 +25
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
(Thread Starter) | Not Ranked : 0 score The 11" FBDL yes. The 11" DP6 yes. The converted MINI kit- proven to as a lot of guys track it What year is the car? I'll do some more data on it. Diameters are not so much your issue, nor "offset" but wheel design.
Groans: 1,143
| Not Ranked : 0 score No specific year Miata in mind. Was just asking for the benefit of everyone who still drives a Miata. The NB sport brakes barely fit 15x9's and you have to replace the banjo bolt on the brake line for just a few extra MM of clearance on the front. The sport brake rotors are 11" on the front and the rear is 10.9"
(Thread Starter) | Not Ranked : 0 score The converted MINI kit allows a larger rotor due to the caliper design. You probably would not get a 11.75 with the FBDL in there. And the DPR is a much better caliper.
Groans: 1,143
| Not Ranked : 0 score This kind of cheap alternative to the stock single piston calipers, and much easier pad swaps is definitely nice. Looking forward to seeing someone with this soon.
The major downfalls to the 11" kit for the "track user" is the FBDL caliper being too light weight for track use, pads being too thin and the rotors too light. *GT casting is ok. You see the common theme here...the converted kit uses a beefier yet lower fit caliper on a larger and meatier rotor and 16mm not 12mm thick pads. But: for a "to the door" cost of under $600 it's pretty compelling for anyone needing to replace stock parts anyhow and pick up some benefits.
__________________ TCE PERFORMANCE PRODUCTS Your one stop....for Wilwood Brakes. ![]() * Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * WRX *Super Duty * SHO * Mustang *...and more! | |
![]() Join Date: Jan 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Are these out yet? I am doing brakes here soon and would like to upgrade. I have a 1996 Miata. |
Absolutely. Full link to the kits on Wilwood's home page: Wilwood High-Performance - Mazda MX-5 Miata Disc Brakes Scroll the images if it doesn't pop up. Browse the listings by year and kit options and hit me up with the kit number you are most interested in. 140-xxxxx
| Not Ranked : 0 score Thank you for the fast response. Pm sent. |
| Display Modes | |
| TCE Wilwood Kits for 3 | Todd@TCE | TCE Performance | 131 | 05-25-2016 09:45 AM |
| TCE brings Wilwood and TCE/Wilwood to MSF | Todd@TCE | TCE Performance | 12 | 07-10-2015 08:55 AM |
| Wilwood Brake Kits at EdgeAutosport! | EdgeAutosport.com | EdgeAutosport.com | 280 | 02-13-2015 02:26 PM |
| Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com | Chimmike | Revolution Performance Motorsports | 46 | 02-11-2015 10:08 PM |
| TCE Wilwood kits for 6 | Todd@TCE | TCE Performance | 19 | 11-15-2014 12:31 PM |
