| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() | | #81 | ![]() |
![]() Join Date: Jun 2010 Location: Near sac, Amador County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Sent from my iPhone using Tapatalk |
![]() | | #82 | ![]() |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
Are you using gmail? Sometimes the attachment is hidden. So stupid.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD | |
![]() | | #83 | ![]() |
![]() | | #84 | ![]() |
I actually forgot. It works now. Try forwarding Justin's email to yourself. See if it shows up then. I hate what Google did to gmail.
![]() | | #85 | ![]() |
![]() Join Date: Jan 2014 Location: San Diego, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Pretty much wrapped up my 91 tune on the S4 with Justin. Cali 91 strikes again and we had to dial timing back because of knock. This thing is fun as hell to drive and the boost curve feels so damn smooth compared to the k04. I basically picked up 30hp and 30tq with the S4.
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff |
![]() | | #86 | ![]() |
307 on an S4? DAMN, 91 Octane!!!!! Shit. That's gotta be a vdyno thing. You gotta have more than that. I have been wanting a S3 and I'm in AZ, with only 91. Hmm.
![]() | | #87 | ![]() |
| Not Ranked : 0 score Yeah the 91 gas out here is just so damn unpredictable station to station so its best to play it on the safer side. I travel a lot. I'm everywhere and i cant necessarily fill up at the same shell gas station that i know has "good" gas. Oh well. Onto my E85 toon! Knock wont stand a chance!
![]() | | #88 | ![]() |
I'm in the same boat. I drive a lot. I don't have E85 in my near future. I just like to fill up and go. I not looking to be he fastest, also. Hmm. I may just go S4 then, after this post. ![]() How was the S4 install?
![]() | | #89 | ![]() |
| Not Ranked : 0 score The s4 is fully spooled by 3900rpm according to my logs. I'd say the s3 is a tad bit quicker. But not by much. Both turbos flow much better than the k04 and you can definitely feel it. They keep on making power all the way to redline where the k04 falls flat. The install was a piece of cake. If you remove the EGR valve, you wont have to remove the exhaust manifold which saves a ton of time. Also if you already have a down pipe installed, that helps too as removing the stock down pipe is a PITA. It can be done in a day but over a weekend is best to give you time. No fab of coolant lines or oil lines was necessary. Honestly the only sticking point i had was because i bought the turbo used, it didn't come with new down pipe studs and nuts. THAT was a b*tch extracting them and reusing them! GO FOR IT!
![]() | | #90 | ![]() |
All great info. Thanks!
![]() | | #91 | ![]() |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Here's my stock turbo on an E85 flash tune. uploadfromtaptalk1463458232183.jpg Sent from my SPH-L720 using Tapatalk | |
![]() | | #92 | ![]() |
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Yeah I guess it would be nice to have that on pump gas, you still on the stock block? Sent from my SPH-L720 using Tapatalk |
![]() | | #94 | ![]() |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score Look at both your vd's one is in 3rd gear the other in 4th, and almost an 1 inch difference in tire height. Hard to compare.
__________________ Cobb AP JBR Tru-3.0 CNT Catted DP "Gutted" CNT Catback JBR 88 RMM DM PMM and TMM 3 port, Turbosmart dual port FReaktune E33 |
| The Following User Says Thank You to PurplFox For This Useful Post: | iamareios (05-17-2016) |
![]() | | #95 | ![]() |
| Not Ranked : 0 score Yeah and i don't plan on building until i need to. The engine is running strong at 84k miles. I was around 272hp at a similar psi on the k04.
![]() | | #96 | ![]() |
That's about where I am now on my K0snore. Mine is at 143k and still running strong.
![]() | | #97 | ![]() |
| Not Ranked : 0 score Welp. Thats how you do it. E33 base map!
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nice man. Good numbers. What's up with the log numbers? I have a v2 also and my pedal position always reads 99 when I'm at WOT. And my open loop reads as .16, where your reads 0. Just found that odd and made me curious and to the difference. I cont wait to be in the 300's.
![]() | | #99 | ![]() |
![]() | | #100 | ![]() |
I do that too. But for me. I was meaning how your pedal position never goes to 99 and your LTFTs read 0, while mine read .16.
![]() | | #101 | ![]() |
| Not Ranked : 0 score Gen 2, Gen 1 difference?
![]() | | #102 | ![]() |
![]() | | #103 | ![]() |
| Not Ranked : 0 score Revision C e33 blend Are you convinced with e85 yet? Lol Sent from my SM-G935T using Tapatalk
![]() | | #104 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yep. Gonna wait til I get my S3 for E tho. Sent from my iPhone using Tapatalk
![]() | | #105 | ![]() |
![]() | | #106 | ![]() |
(Thread Starter) | Not Ranked : 0 score 143+k and running like new. Sent from my iPhone using Tapatalk
![]() | | #107 | ![]() |
| Not Ranked : 0 score I just passed 84k Sent from my SM-G935T using Tapatalk
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's all about how you treat her. I bought mine at 93k.
![]() | | #109 | ![]() |
![]() Join Date: May 2014 Location: Bloomsburg PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
| Not Ranked : 0 score I just finished my pump 93 tune with Freektune, it took 5 revisions from the OTS and I have to say there definitely is a difference in power from the OTS to being fully Freeked. The car pulls hard and strong with no drivability issues whatsoever which is important as my car is daily driven. I would definitely recommend going from Freek OTS to a full tune once your at a point in your mod process where you won't be adding more go fast parts. Now for the in tank methanol tune!
__________________ BNR S3 - FREEKTUNED on E33 |
![]() | | #110 | ![]() |
(Thread Starter) | Not Ranked : 0 score When my tune was completed, BAT's were about 120 max. Car was doing great, feeling great, running great. Then it heated up to 117 outside!!! KR started getting crazy when BAT's reached 140-150. One day it hit 5.96 and held for the last half of my 4th gear wot pull. It spiked, but then started dropping. It had dropped to 1.4 by the time I let off. I have not seen it that high ever and never again since then. But, I was still getting wacky KR numbers in the 2's very frequently in part throttle and as high as 2.5, with 140+ BAT's. I was told by a local Nator member to pop a gallon of E85 in and see what happens. So I did. KR disappeared. There were only few blips of .3's and .7's here and there. After 25 or so miles of testing her out; easing into the power, I got brave. I reverted my tune to an earlier revision, that had more boost and blasted out 3 pulls with High BATS... two 4th gear and one 3rd. one blip of .3 in all three runs!! Fuck you 91 Oct!! I did a morning wot pull the next day. I was VERY PLEASED. the car has been a joy to drive. E is magical. Now I want the E85 tune. You guys weren't kidding. ***Log names contain the starting BAT numbers. The VD is from the morning run. Side not: Yesterday, when I got home, I noticed my coolant reservoir was bubbling like crazy. I'm pretty sure its the high temps and the crack in my reservoir that's doing it. I have new reservoir coming and used JB Plastic Weld to, hopefully, hold it over. waiting for it to cure. Fingers crossed that the head gasket isn't toast. I have no smoke, care has full power (evident by VD, below) and cylinders are dry.
![]() | | #111 | ![]() |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Lol now you finally see why I kept trying to convince you!
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
![]() | | #112 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm shedding my noobish ways. Curious form when I get this tune... How exactly do you go about filling up, to make sure you have the correct mix? If the tank is about empty to put the 4 gals of E85 in first, correct? And what if you are almost empty but have a 1/4 or 1/2 tank? How will I know how much to mix, without having to go full-on math wiz?
![]() | | #113 | ![]() |
| Not Ranked : 0 score An e time will net you much closer to 300 without fear of knock I cant wait to finish my 93 just to get back on the e
| The Following User Says Thank You to PurplFox For This Useful Post: | Atticaz (06-08-2016) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score There's fuel mix cheat sheets on the forum. You'll have to know how many gallons you can fit typically you just fill up when you're low. Start experimenting now with regular and write down how many gallons you can put in at different intervals.... Don't ever expect to top off on an e85 tune but you can get real close
| The Following User Says Thank You to Omega For This Useful Post: | Atticaz (06-08-2016) |
![]() | | #115 | ![]() |
![]() | | #116 | ![]() |
![]() Join Date: Apr 2013 Location: NEW JERSEY
| Not Ranked : 0 score Hey guys question currently running e50 mix withe the ets top mount pushing about 360whp Will a tr8 fmic with a rich up tune give me more power or should I just stay where I am? |
![]() | | #117 | ![]() |
| Not Ranked : 0 score That would depend on if your having issues with heat soak. lot of info left out to make that decision
![]() | | #118 | ![]() |
I'm thinking of picking up a new exahust manifold and waiting on details about damond motorsports intake manifold adapter plate.
![]() | | #119 | ![]() |
I'd love to see your final revision vdyno pull, if you have one. I'm excited for my E33 tune. I need to do a few repairs first though. ![]() Sent from my iPhone using Tapatalk
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 06-14-2016 at 09:29 AM. | |
![]() | | #120 | ![]() |
![]() Join Date: Jul 2015 Location: Fontana, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score I'm moving back to Cali starting Friday. I feel like I'll have to do like an 91+e40 blend just get the same power I have with a 93 tune. But I'm in the same boat..can't wait to get some . Sent from my iPhone using Tapatalk
__________________ #BaseCrew. |
| Freektune or no? | Castillo817 | 2010 MS3 - ECU Computer Tuning | 37 | 02-17-2015 07:04 AM |
| Freektune | jseams | 2010 MS3 - ECU Computer Tuning | 14 | 12-02-2013 11:48 PM |
| Freektune and BT = Better MPG? | NCspecV81 | 2010 MS3 - Big Turbo Builds | 34 | 09-11-2013 11:27 AM |
| My Freektune | atvfreek | 2010 MS3 - Dyno Sheets/Discussions | 12 | 02-19-2012 08:01 AM |
