| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
(Thread Starter) | Not Ranked : 0 score I have yet to drive the required miles to send in the new log to @Justin@Freektune;. But, I'll get them to you soon and toss up some new vdynos. By the way: I set my OCC Weight at 160 w/ tire height of 25.09. ------ FREEK Base Map OTS+ ------ FREEK Revision 1 OTS+
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
| The Following 3 Users Say Thank You to Atticaz For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Did another few pulls on my lunch break. All were a bit lower than the first vdyno above. Here is the best one out of the batch. EDIT: I am pretty sure I had wheel spin on this pull. Comparing the logs. This second one looks better, from what I have learned so far. I will post the logs soon. Not sure how to tell by looking at the logs if I had spin. My tires are pretty quiet when they spin.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-04-2016 at 08:04 AM. |
![]() Join Date: Jan 2015 Location: Williamsburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Awesome numbers! I was running a cobb OTS map which I didn't really like and then switched to the free Stratified OTS stage 2 map which is seems to have my car running much better. I've heard great things about Freektune so I'm sure you will be completely satisfied! |
| The Following User Says Thank You to Snowing For This Useful Post: | Atticaz (02-04-2016) |
(Thread Starter) | Not Ranked : 0 score I was gonna type this above. But I got called away from the computer. All in all, the car feels incredible. The power is there when I need it, now. Before, the car was peppy, but it felt a little disconnected. Much more at my command now... even when driving while staying out of boost. I will definitely go full custom FREEKTUNE, when I get my larger intake and CS turbo. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Atticaz For This Useful Post: | Justin@Freektune (02-03-2016) |
(Thread Starter) | Not Ranked : 0 score Here are the 2 logs I have handy. Base map and MAF cal w/ couple adjustments to the boost control tables.
(Thread Starter) | Not Ranked : 0 score For some reason I could upload both logs in the last reply. Here's the other.
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score I just finished my E85 tune by @Justin@Freektune; and am pretty happy with his work. I also have a 93 tune through him as well. I definitely need to get a better turbo though, a bit disappointed i didn't reach 300whp being fully bolted....but speed6. Justin, your tunes are awesome...thanks again.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
| The Following User Says Thank You to wes3id For This Useful Post: | Atticaz (02-04-2016) |
![]() Join Date: Dec 2010 Location: Houston, TX
__________________ 2008.5 Speed3 GT Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49 | |
| The Following User Says Thank You to hollar1211 For This Useful Post: | Snowing (02-06-2016) |
I don't trust virtual dyno #'s too much, but it gives a rough estimate.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ | |
Not sure how much I trust vdyno either. My first pull was 272. Everyone after has been 265-/+ car feels great though. I'm gonna try to not get so hung up on numbers. TRY. LOL I just use it to roughly track my gains. Sent from my iPhone using Tapatalk
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD | |
| The Following User Says Thank You to Atticaz For This Useful Post: | Snowing (02-06-2016) |
| Not Ranked : 0 score Ya i'm "Trying" not to either, but it's hard not being disappointed when you see the numbers
| The Following User Says Thank You to wes3id For This Useful Post: | Snowing (02-06-2016) |
(Thread Starter) | Not Ranked : 0 score Just did my first 4th gear pull, today. Car is still feeling great. I kinda hoped for more constant horsepower pass its peak around, as all the OTS+ vdyno's on here I have seen seem to. But, it is what it is, right? One revision. I've had the car for 2 years, now. I think I've done well so far and gained a shit-ton of knowledge from you guys. I wish I woulda known to go larger intake when I picked mine up. But I was super noob, then. Can't wait for the day I can pick up the CS turbo, larger intake and full tune. It may be a while though, unless business picks up. Here is a newer vdyno and wot log. EDIT: Concern....Should I be concerned about the WGDC hitting 99.9!?? @Justin@Freektune;
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-06-2016 at 07:13 PM. Reason: Added concern after reviewing the log further. and added another 4th gear vDyno |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score No. 99.9 is fine
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| The Following User Says Thank You to speedfreak44 For This Useful Post: | Atticaz (02-06-2016) |
(Thread Starter) | Not Ranked : 0 score Ok good. What does it exactly mean. The WG is letting exhaust gas bypass the compressor or its holding it in? I know noob question. I admit I have a bit more to learn. Sent from my iPhone using Tapatalk
| Not Ranked : 0 score It means the wg is attempting its best to stay closed and build more boost. Basically you have hit the limit of the turbo
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
| Not Ranked : 0 score I can tell just by the sharp of your VD curves that your logging roads are very inconsistent. No Mazdaspeed will ever have peak hp at 4200 rpms as you are seeing in some of your logs Sent from my iPhone using Tapatalk
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway |
| The Following User Says Thank You to Justin@Freektune For This Useful Post: | Atticaz (02-07-2016) |
Ok. I wasn't sure if it needed to be the same road. I did see on another forum late lastnight that the road used needs to be the same and flat, free of bumps. I will try to find one and stick to it. The road on my logs I sent you for the base and revision was a bit bumpy. It's hard to find smooth roads by my house and traffic is pretty congested by my work. Hope that didn't mess with my chances of gaining more power. Looks like I need to figure out what road I used for that smooth vdyno run? What conditions cause the vdyno to read peak hp so soon like that, I can know what roads to stay away from using? Sent from my iPhone using Tapatalk
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-07-2016 at 08:12 AM. | |
I think ideal roads would be flat and smooth. I redid some of my logs last night because a portion of the road was bumpy. I wasn't even sure if it mattered but I did them in a different spot anways. Both my logs from the flat smooth road read the EXACT same hp/tq numbers so I was pretty impressed with the consistency of VD in that respect. Sent from my iPhone using Tapatalk
__________________ 2012 Mazdaspeed 3 CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22 Purple Drank Tune in process | |
| The Following User Says Thank You to Snowing For This Useful Post: | Atticaz (02-07-2016) |
![]() | | #19 | ![]() |
Exactly this. If you can't get two logs to lay perfectly on top of each other and be smooth. Then the road isn't sufficient for what you are trying to do. Ideally you should be able to log in both direction on the same road and get the same numbers. Pretty hard to find a road that flat though and a reason to take VD numbers with a grain of salt. Sent from my iPhone using Tapatalk
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score With that said, I found my log road will be using, for further evaluations; Damn near, identical gaphs in both directions. It's closest I am gonna get. It was the road I used for the more well rounded run, above, just further down it. @Justin@Freektune; half of this run was in high 12's for AFR? thought that was danger zone.
![]() | | #22 | ![]() |
| Not Ranked : 0 score took another 4th gear pull on a different stretch of road.....best i've gotten so far
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nice. Looks great. Smooth. I'm spooked about the AFR's in my last run.
![]() | | #24 | ![]() |
| Not Ranked : 0 score ya you might want to trying cleaning MAF sensor and monitor your AFR at idle and cruising to make sure they are set where they need to be before going WOT.
![]() | | #25 | ![]() |
Just cleaned the MAF sensor before buying the OTS+. Justin said everything looked great. Sent from my iPhone using Tapatalk
![]() | | #26 | ![]() |
| Not Ranked : 0 score have you tried emailing him that log for him to look at? did you try a different road and compare?
![]() | | #27 | ![]() |
I have tried several roads. Never seen this before. That's why it freaked me out. No changes were done and all of a sudden... I did email him but it would not go through for some reason. Kept coming back. So I tagged him here. Sent from my iPhone using Tapatalk
![]() | | #28 | ![]() |
| Not Ranked : 0 score try sending him a quick PM. i know emailing him can take days because he's a busy guy. I'm not a fan of bugging people, but if you are really worried about it...i'd try to reach him and ask if he can take a quick look.
![]() | | #29 | ![]() |
| Not Ranked : 0 score I would grab another log and see if it repeats. If so. You have a leak or hardware issue Sent from my iPhone using Tapatalk
![]() | | #30 | ![]() |
I'll grab a few more tomorrow. If I am just doing WOT logs to check AFR at WOT, does it sill need to be the same road, or is that just for vDyno? Just a thought. My AP was glitching earlier. I am hoping this is the issue. I did two WOT runs and the AP overlapped them as one. Weird.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-07-2016 at 09:38 PM. | |
![]() | | #31 | ![]() |
I would think that no matter the road conditions you should be under 12 a/f. Sent from my iPhone using Tapatalk
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just noticed I had the CF set wrong in my last vdyno. Will fix when get home. Can't fix the above CF. Mistakingly deleted the logs. Shit
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-09-2016 at 06:44 PM. |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is my latest vDyno. For whatever reason, I have been running lean for the first half of some pulls and only at the beginning of some of my WOT pulls. (Seen in the most recent vDyno above.) One most recent was 12.9's for the first half of the pull. Most of the pulls, AFR's are falling within mid to high 11's. I am pretty sure its not tune related. Something is off. If it were tune related it wouldn't be so erratic. But the cool thing about having a tuner is they are all about helping you out. Justin is a great guy and is helping troubleshoot this. So far I have double checked the torque on all DP bolts, looked for exhaust leaks, went back to the stock BPV, pulled a few more logs and sent them off to him. So far, the issue hasn't shown up again. At the beginning of one log the AFR's were lean for a about 4-5 cells of the CSV spreadsheet, which I believe is a very short time and nothing to worry about. I hope. This shit freaks me out <- pun not intended. So far, I have been hanging around 268/270 average whp. Can't complain too much for an OTS. Car feels great. After I figure out the lean issue and complete my TBE, by getting the CNT CBE, I think I am going full tune. Can't wait for the BT. Need moar powa.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-10-2016 at 04:07 PM. Reason: Typo corrections |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Just ordered a BNR S3 and will go full Freaktune for both 93 and E85...coming soon
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I believe I got this lean AFR at WOT shizz all figured out. Thanks to this thread... Very last post. SU Turbosmart - 10-20psi or 20-25psi spring for stock k04?? Thanks Street Unit. #sarcasm I have the proper spring on order and the OEM BPV installed for the time being.
| The Following User Says Thank You to Atticaz For This Useful Post: | Justin@Freektune (02-11-2016) |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score @Justin@Freektune; I have the stronger spring on the way, for my BPV. Meanwhile, I'm leaving the stock BPV in. I decided that I am going to buy a full tune from you VERY soon. But I am picking up a CS 3" intake first. That is on its way too. Is the $75 OTS+ tune still a credit towards the full tune?
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just got my 3" CS Intake in and ordered my full custom Freektune. The OTS+ was great. But it's time to move on.
![]() | | #39 | ![]() |
![]() Join Date: May 2014 Location: Bloomsburg PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
| Not Ranked : 0 score Why not 3.5" intake? If I could do it over again, I'd do it right the first time and get a 3.5" intake. I probably will eventually with a battery box as well, especially when I go to upgrade the turbo. I can't wait until spring to do my in tank meth tune with Freektune!
__________________ BNR S3 - FREEKTUNED on E33 |
![]() | | #40 | ![]() |
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 | |
| Display Modes | |
| local tune or inet tune | RACER_X | Gen2 MS3 General Discussion | 19 | 11-13-2014 02:05 PM |
| cobb ap: is safe tune quicker than stage 0 tune? | Fusion_MS3 | 2010 MS3 - ECU Computer Tuning | 14 | 12-16-2012 02:27 AM |
| WOT-Tune (My experience) | akbrazil | 2010 MS3 - ECU Computer Tuning | 3 | 07-09-2012 08:09 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
