Like Tree59Likes
 Old 03-19-2015, 10:49 AM   #121
torquemaniac's Avatar
Posts: 733   (View Stats)
I have a couple questions about the positioning of the meth nozzles, and since this is the place to be when talking about meth injection, I will post this here…
First off, I have an Aquamist HFS-4 to go with my big turbo build…the goal is to push around 400awhp/400awtq (or whatever satisfy my ungoing appetite for more power…without breaking the transmission)
In my setup, the turbo is top-mounted and the intake is facing the passenger side (no intake…just a filter on the 4’’ compressor side), I run a water/air intercooler and the MAF is located in between the intercooler and throttle body (3.125 ID pipe with honeycomb straightener)
The distance between the intercooler and throttle body is just 8’’, and I need to position the MAF sensor and meth injection port in this small space
Now for the questions :
- Will injecting 2.5’’ before the throttle plate affect uniformity of dispersion? (jet hitting the throttle plate before full dispersion)(I don’t want to use a throttle spacer because I prefer to weld a bung on the MAF pipe…less trouble for me)
- Does injecting 3’’ to 4’’ away from the MAF have any drawback?
- What is the logic in saying that injecting pre-throttle (5’’+ inches away) will promote the greatest charge cooling (vs post-throttle)…you may get a cooler MAP reading with pre-throttle injection, but the post-throttle injection will cool the charge the same but it may not show on the MAP reading…heck, one of the benefit of direct injection engine is that the fuel is atomized directly in the cylinders to aid in cooling…
2011 CX-7 AWD 2.3 turbo
 Old 03-19-2015, 06:19 PM   #122
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
If you haven't already, check out this thread. A lot of what you are asking was discussed.
Not sure about the MAF sensor being so close to where you are injecting. I've seen pics and videos of water with dye in it, and when it's injected that shit literally goes everywhere, even backwards. I don't think you want that on your MAF.
Someone with more expertise should chime in though.
Throttle Body Spacer with 2 Meth Ports
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
 Old 03-20-2015, 04:42 AM   #123
Thanks mize13...didnt see this thread...very informative
 Old 03-21-2015, 07:35 PM   #124
Minipax's Avatar
Posts: 18   (View Stats)
Minipax will become famous soon enough
I bought MD's throttle body spacer, hopefully that will be enough.
Minipax is offline   Reply With Quote
 Old 05-24-2016, 10:16 PM   #125
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
I know this thread hasn't been active for a while but posting it in case it could help others out. Sorry if this has been covered already.
Issue: meth leaking from push to connect fitting (nylon part)
Fix: instead of getting another push to connect fitting, I went with brass compression fitting/sleeve (I personally used a plastic washer sleeve but a brass will work). This makes for a totally secure connection with zero leak. My setup was leaking at the injection point but now (cause of the good result) I'm thinking of doing the same on the pump side as well.
Example
Justin@Freektune likes this.
The Following 2 Users Say Thank You to specvspeedfreak For This Useful Post:
Justin@Freektune (05-25-2016), torquemaniac (05-25-2016)
 Old 05-25-2016, 08:14 AM   #126
Aquamist also sell compression fitting for meth injection tubing...this is what I use and wouldnt trust anything else for 100% meth
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
MS3Shadow (05-25-2016), specvspeedfreak (05-25-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f699/methanol-injection-info-176351/
Port Injection WMI, help This thread Pingback 04-06-2015 01:17 PM
w/m injection questions This thread Refback 03-20-2015 12:03 PM
Best way to take meth This thread Pingback 03-20-2015 11:43 AM
Meth failsafe solenoid placement This thread Pingback 03-20-2015 07:29 AM
methanol injection MAF failsafe bigmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 07-25-2015 11:00 AM
Methanol Direct Injection phate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 290 10-01-2014 09:34 PM
Pre-turbo methanol injection KoukiS14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 10-19-2009 04:20 PM
Page generated in 0.28208 seconds with 24 queries
