Like Tree59Likes
 Old 10-30-2014, 11:41 PM   #81
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
FWIW, and it may be just my bad luck, but I had a nozzle crack off right at the cold pipe from what I would presume to be metal fatigue. I just had one of the DO 90 degree fittings hanging on it. Hanging a solenoid and other fittings on your nozzle just might multiply the forces and create a similar result.
The Following 3 Users Say Thank You to CosmicArkie For This Useful Post:
Easter Bunny (11-03-2014), Mauro_Penguin (11-12-2014), rfinkle2 (10-31-2014)
 Old 11-03-2014, 05:23 AM   #82
Noob question here. I'm running a D07. If I wanted to run one of these TB plates with dual nozzles for cross-spray action would there be anything wrong with running a D03 and a D04 with them being different flow rates?
Easter Bunny (11-03-2014), rfinkle2 (11-03-2014)
 Old 11-03-2014, 08:46 AM   #83
No. As a matter of fact, after seeing some videos of nozzles facing eachother vs. a single nozzle set-up, I feel there are better distribution possibilities (from looking @ the vids only by eye) if you have two opposing nozzles.
@neganox; check out ms6mil's video of his dual nozzle spray pattern.
Justin@Freektune likes this.
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
cocoanton (11-03-2014), cshunter (11-03-2014), Easter Bunny (11-03-2014), Justin@Freektune (11-03-2014), ms6mil (11-03-2014), mxlplx71 (11-26-2014), neganox (11-03-2014), senor blanco ms3 (11-11-2014), WetzMS3 (11-03-2014)
 Old 11-03-2014, 10:28 AM   #84
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Dual D07 Test - YouTube
So you are saying 2 smaller nozzles (equaling the same flow as a larger) might be better?
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
Mauro_Penguin (11-12-2014), rfinkle2 (11-03-2014)
 Old 11-03-2014, 10:37 AM   #85
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
Groaned at 7 Times in 4 Posts
I have encountered a number of installation issues with my meth setup. This info covers most of the problems you will encounter. I approve this message.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
 Old 11-03-2014, 10:43 AM   #86
Although I am afraid to say anything @ all, yes, I am saying that I feel that way.
@maisonvi; the only caveat is that increasing nozzles increases connections which increases the possibilities of leaks.
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
adamizme (11-03-2014), Easter Bunny (11-03-2014), maisonvi (11-03-2014), Mauro_Penguin (11-12-2014), ms6mil (11-12-2014), WetzMS3 (11-03-2014)
 Old 11-03-2014, 10:53 AM   #87
maisonvi's Avatar
Groans: 75
haha, Im not coming at you guns blazing. (thanks for the back up in the other thread BTW)
Im just wondering becuase Im setting up my AIS meth kit with a dual nozzle capable system. I made myself a throttle body plate with 4 holes, but was just planning on going DO10 nozzle. I have afew other smaller nozzles that I could split up. Curious to see the benefits (or lack of) for one nozzle vs multiple, or if there is a noticeable difference.
 Old 11-11-2014, 12:47 AM   #88
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
so glad this thread exists. answered a lot of my questions.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
rfinkle2 (11-11-2014)
 Old 11-12-2014, 09:26 PM   #89
LSMS3TMB's Avatar
Posts: 51   (View Stats)
LSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud of
This thread made me feel really dumb. I read the whole thing and still have no idea what the hell I'm supposed to do regarding a WMI install.
2011 LSM Mazdaspeed3 w/tech
JBR SRI+TIH and RSB // AT HPFP // AP V3 // Bosch 3bar // ATP catless downpipe // Ultimate Racing catback // Treadstone TR8 FMIC Kit // ATP GTX3076 // Kozmic Oil Feed // SP63 Vented Oil Cap // AquaMist HFS-3.1 // CorkSport Injector Seals // Corksport Short Throw Shifter and 85A RMM // Damond Motorsports Short Shift Plate // CP-E TiaL QR BPV // H&R 15mm spacers // H&R Coilovers // SPC Camber arms // WhiteLine front and rear adjustable end links // Muteki SR48s Red
Hypnotic Tuned
93+Meth- 402whp/384wtq
Sold.
LSMS3TMB is offline   Reply With Quote
The Following User Says Thank You to LSMS3TMB For This Useful Post:
rfinkle2 (11-13-2014)
 Old 11-12-2014, 09:34 PM   #90
ButtholeRedMS3's Avatar
Posts: 784   (View Stats)
ButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the world
Buy a good WMI kit with quality check valves and the DM throttle body plate and a tune and call it good. That's what you do.
2007 BM MS6 - Sold
2010 VRM MS3 Tech - Sold
ButtholeRedMS3 is offline   Reply With Quote
The Following User Says Thank You to ButtholeRedMS3 For This Useful Post:
 Old 11-12-2014, 09:36 PM   #91
LSMS3TMB's Avatar
Oh, that much I got. Installing and mantaining it proficiently... That's another story lol.
Hypnotic Tuned
Sold.
ButtholeRedMS3 (11-12-2014)
 Old 11-13-2014, 06:32 AM   #92
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Nailed it. Check valve also serves to keep meth from draining into the intake mani when the car is off, but otherwise^^^100% on point.
So @rfinkle2;, I ordered one of the check valve equipped nozzle holders from Snow to replace my chunky DO nozzle holder, and I was searching around for other peoples opinions of it before I install it. I came across a thread on a VW forum stating that the cracking pressure is only 10 psi for the check valve equipped nozzle holder. My car usually idles at like 11 psi of vacuum, so is that going to cause the valve to open or does it only open when pressure is on the backside of the valve where the pump is pushing from?
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
 Old 11-13-2014, 08:06 AM   #93
I'd be surprised if it caused an issue. I ran one for a long while, and know some others running it as well.
Maintenance would include :
1) logging @ least once a week.
2) making sure the tank is full
3) inspecting connections
4) maybe every oil change, rinsing check valves with h20...
5) maybe overkill, but spraying (outside of car) some h20 through the system on occasion if using 100% meth.
6) monitor your bat's (bat's are a tell tale sign you are spraying meth).
PUGENE, Mauro_Penguin and WetzMS3 like this.
Last edited by rfinkle2; 11-13-2014 at 08:06 AM. Reason: MSF Database - Automerged Doublepost
Addikted To Boost (11-13-2014), LSMS3TMB (11-13-2014), Mauro_Penguin (11-13-2014), PUGENE (11-13-2014)
 Old 11-13-2014, 12:23 PM   #94
LSMS3TMB's Avatar
Thanks for the specifics. Guess I know what my next performance mod will be.
Hypnotic Tuned
Sold.
 Old 11-26-2014, 02:01 PM   #95
tikous360's Avatar
Posts: 182   (View Stats)
tikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the world
What length of SS Lines should I order to install my WMI kit on the engine bay area? and How to install the check valve close to the nozzle with a SS line?
Thanks for the advice
tikous360 is offline   Reply With Quote
 Old 11-26-2014, 10:06 PM   #96
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Originally Posted by tikous360 View Post
What length of SS Lines should I order to install my WMI kit on the engine bay area? and How to install the check valve close to the nozzle with a SS line? Thanks for the advice
There is no way to tell what length you need until you get everything situated. As far as mounting the check valve, you can get a female to female coupler from summit racing to go from nozzle holder to check valve.
tikous360 (11-27-2014)
 Old 01-02-2015, 04:27 AM   #97
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
Ok so I am a little paranoid about keeping five gallons of pure methanol/ethanol in my car with your basic meth tank/plastic gas tank like I have right now. I was thinking of getting this fuel cell and connecting it to my pump (300 psi) with some AN to brass barb fittings and run standard meth hose. Then I will add a vent port coming out of my car as well.
Here is the tank I am speaking of http://www.summitracing.com/parts/sum-290101
Would this work? I really do not understand how these fuel cells work.
Also I thing I have found useful is running barb fittings instead of push to connect. It is obviously cheaper than AN fittings and SS lines, and this way nothing ever leaks unlike push to connect. The only downside is that once your hose is on the barbed fitting, it won't come off until you cut it.
Additionally, you can go crazy with barbed fittings and mount your nozzles with them with these.
Anderson Metals Brass Hose Fitting, Connector, 1/8" Barb x 1/8" Female Pipe: Amazon.com: Industrial & ScientificAnderson Metals Brass Hose Fitting, Connector, 1/8" Barb x 1/8" Female Pipe: Amazon.com: Industrial & Scientific
Note in fact you need about a 1/8 hose id on your barbed fitting. Most of the time your local Lowes does not go down this small, so I just order it online.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-02-2015, 05:43 AM   #98
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
I keep 4 gallons in the car. Non issue.
Mods: stock
Mauro_Penguin (01-02-2015)
 Old 01-03-2015, 09:13 PM   #99
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
Default Methanol Injection info
You can ask @maisonvi; for pics of his setup with a 3 gal(I think) fuel cell. Or if you're patient, @Matt@HTP; said he has an aluminum one coming out soon for in the engine bay(check HTP section for details).
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following User Says Thank You to Oni For This Useful Post:
Micha (01-04-2015)
 Old 01-03-2015, 09:16 PM   #100
faeker's Avatar
Groans: 731
Again I counter with.....no worries ever. 4 gallons for 2 years in the trunk. No out of car venting, no odors, no issues.
Mods: stock
The Following 3 Users Say Thank You to faeker For This Useful Post:
levon.mark (01-04-2015), Mauro_Penguin (01-04-2015), Micha (01-04-2015)
 Old 01-03-2015, 09:26 PM   #101
maisonvi's Avatar
Groans: 75
Additionally, you can go crazy with barbed fittings and mount your nozzles with them with these. Anderson Metals Brass Hose Fitting, Connector, 1/8" Barb x 1/8" Female Pipe: Amazon.com: Industrial & Scientific
Here is the set up I had and the install thread I made for it. I debated on running the vent outside the car, but really, I dont see an issue with it. The evaporation rate of the methanol is slow and I open the door enough for it to not matter.
AIS Stage 1 Trunk Mount Meth Kit
 Old 01-04-2015, 02:48 AM   #102
levon.mark's Avatar
Ya same here. But what if a accident occurs? lawls.
Ya i ordered an aluminum fuel cell then quickly cancelled it today because I was not thinking about the problem with 100% methanol or ethanol sitting in a aluminum tank.
YEEMARKS
Old Time in S3:
12.4 @ 111
Last edited by levon.mark; 01-04-2015 at 02:48 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to levon.mark For This Useful Post:
dterry5 (01-29-2015)
 Old 01-09-2015, 11:29 PM   #103
levon.mark's Avatar
Went ahead and got fuel cell, works great.
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following 3 Users Say Thank You to levon.mark For This Useful Post:
rymanmazda (01-10-2015), senor blanco ms3 (01-10-2015), tbcota25 (01-10-2015)
 Old 01-10-2015, 12:19 AM   #104
More info on the fuel cell. I think I'm going this direction too.
A lot of mods
 Old 01-10-2015, 01:06 AM   #105
levon.mark's Avatar
What do you want to know?
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-10-2015, 09:24 AM   #106
Never mind...I used the Google thingy and found what I needed.
A lot of mods
 Old 01-10-2015, 01:50 PM   #107
levon.mark's Avatar
The cell is a Chinese cell from the looks of it (and the price). The company is a Speed Master. The welds are meh but at least it doesn't leak. I have someone with the same cell that will be pressure testing it later on. They advertise it as a foamed cell, but It comes with cheap foam on one corner that I ripped out because it was going to interrupt the fuel level sensor. Also, you need a fuel level gauge for the cell; your low indicator light won't work. Any gauge from 0 to 90 ohms will work. I tested the low fuel sensor with my multimeter and it works great, i just need a gauge. I am probably going to get the Glowshift gauge on amazon.
The fittings on the tank are -10 An that which I used a brass bushing to barbed fitting contraption. Just go to your local plumping store or rubber/hose store and they should set it up for you. They charged me 20 bucks for everything and I got extra 6 feet of 1/4 nylon hose (cheap meth hose that doesn't crack like the refrigerator Lowes hose). ( I can't find the receipt so I can't give you the exact part numbers right now).
YEEMARKS
Old Time in S3:
12.4 @ 111
senor blanco ms3 (01-15-2015)
 Old 01-29-2015, 08:16 AM   #108
dterry5's Avatar
Posts: 40   (View Stats)
dterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond repute
I was under the assumption methanol & aluminum don't agree well with each other? Especially 100% meth. I know the MSDS for methanol says powdered aluminum should be avoided with methanol, but I would have to believe that could cause premature failure on an aluminum cell. Guess it all depends on pH.
I guess I'm just thinking maybe those with an aluminum cell should keep a close eye on it and inspect the tank regularly.
-2013 Ford ST
GTX2867r, Freek'd
dterry5 is offline   Reply With Quote
 Old 01-29-2015, 08:32 AM   #109
faeker's Avatar
Groans: 731
Htp made a note about that on their meth tank thread.
Mods: stock
Mauro_Penguin (01-29-2015)
 Old 01-29-2015, 08:39 AM   #110
Justin@Freektune's Avatar
Posts: 954   (View Stats)
I run a plastic tank on my setup. I only run 100% meth in my car as well. Myself personally would be very hesitant to use an alum tank or any metal for a meth tank. Especially being here in the north east where everything corrodes from the outside as well.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
 Old 01-29-2015, 08:57 AM   #111
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Great wrote up thanks guys
Jdraps13 is offline   Reply With Quote
 Old 01-29-2015, 09:05 AM   #112
dterry5's Avatar
Kind of what I was thinking, just happened to see that aluminum tank posted above and figured it might be of some importance to note!
-2013 Ford ST
GTX2867r, Freek'd
 Old 01-29-2015, 08:31 PM   #113
levon.mark's Avatar
Here is Interesting info from Matt from HTP about Aluminum and Meth.
"100% meth is very flammable and in an accident, where there is no firewall separating, it can spell disaster. This is why you will find that all meth manufactures will state that a non flammable mixture be used.
It is true that 100% methanol is corrosive to aluminum, but for it to take effect, it takes a very, very long time. We have conducted a long term test because this face value claim pops up immediately when discussing it. We have tested this on cast alum, 3003 alum, 5352 alum (what we use for tanks), 6061 alum, & anodized alum (5352 & 6061). Due to the protective oxide layer that forms on the surface of alum when exposed to air, it is protected from corrosion for the most part.
Where we saw any type of corrosion was on cast, and over the length of 2 years, it was very minimal. All types of alum did surprisingly well over this period, the only spots that we saw signs of any type of etching is where we had put a scratch through the oxide layer and the HAZ area around a weld. Even this was very minimal and would have no effect on a methanol injection system. Anodized alum had zero effects.
This was all tested with 99.999% meth. Keep in mind that Methanol is hydrophilic, meaning that it attracts water and will absorb it, self diluting. So fresh methanol was constantly changed to keep the purity levels up. As I have studied these results and researched findings from corrosion engineers, I'm a little let down by this claim that everyone spouts so freely. Just as little as a couple percent of dilution of water, and the corrosive effects are gone."
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following 2 Users Say Thank You to levon.mark For This Useful Post:
mize13 (01-30-2015), torquemaniac (02-04-2015)
 Old 02-01-2015, 09:36 AM   #114
Minipax's Avatar
Posts: 18   (View Stats)
Minipax will become famous soon enough
Thanks for the info. I recently bought an aquamist system. Haven't installed it yet until I gather all the right info that I need.
Minipax is offline   Reply With Quote
 Old 02-23-2015, 09:41 PM   #115
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Anyone truck mounted using push fittings? I am thinking of going this route since I will be running 50/50 instead of 100%. Can't buy 100% unless I want to drive 1.5 hours to get it but i can get 50/50 shipped to my house.
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 02-26-2015, 06:42 AM   #116
Lacey28's Avatar
Posts: 557   (View Stats)
Lacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the world
I was using push connect. Why do u need parts?
Lacey28 is offline   Reply With Quote
 Old 02-27-2015, 02:25 PM   #117
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Thought I would add a quick meth hack. I have replaced the nylon meth lines a few times. I have found the AEM 25' roll for $10.00 readily available at many mail order retailers and this is 1/2 price of others with better availability.
MINI H1 6.0 - CAR LED TAILS
WetzMS3 (07-08-2015)
 Old 02-27-2015, 02:52 PM   #118
blake0521's Avatar
Yep I am going to need parts. Just trying to decide if push connect will cut it or not. Sound like it should be good enough.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 02-27-2015, 03:33 PM   #119
jdmage_mx5's Avatar
I would not want to run PTC from the trunk. I know the stainless is a lot more but to me is worth it. Of course I went with stainless and it's mounted in the front bumper.
 Old 02-28-2015, 01:08 PM   #120
Lacey28's Avatar
I would not want to run PTC from the truck. I know the stainless is a lot more but to me is worth it. Of course I went with stainless and it's mounted in the front bumper.
I had ptc and it leaked my tank dry 3x in my truck. I upgraded to s.s. And havent had a problem since.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f699/methanol-injection-info-176351/
Port Injection WMI, help This thread Pingback 04-06-2015 01:17 PM
w/m injection questions This thread Refback 03-20-2015 12:03 PM
Best way to take meth This thread Pingback 03-20-2015 11:43 AM
Meth failsafe solenoid placement This thread Pingback 03-20-2015 07:29 AM
methanol injection MAF failsafe bigmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 07-25-2015 11:00 AM
Methanol Direct Injection phate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 290 10-01-2014 09:34 PM
Pre-turbo methanol injection KoukiS14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 10-19-2009 04:20 PM
Page generated in 0.63088 seconds with 41 queries
