| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() | | #41 | ![]() |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| The Following User Says Thank You to ms6mil For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #42 | ![]() |
![]() Join Date: Aug 2013 Location: NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score ^^^^agreed so much better and cleane... Instead of drilling into the intercooler piping. |
| The Following User Says Thank You to Sebs6 For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #43 | ![]() |
![]() Join Date: Aug 2012 Location: Hartland, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,583
Groans: 42
| Not Ranked : 0 score @Gr8Speed; for when you go FMIC. |
![]() | | #44 | ![]() |
![]() Join Date: Jun 2012 Location: Asia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 112
| Not Ranked : 0 score Awesome product. Gives the kit a nice thermal insulator and it will complete the kit even more! Pretty sure everyone won't mind paying a little more for it. Last edited by KCi; 09-20-2014 at 07:01 AM. |
| The Following User Says Thank You to KCi For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #45 | ![]() |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score Neat idea! Something to note. With this spacer added, you will need to use a solenoid before the nozzle, since the nozzle will be after the throttle plate. Correct me if I'm wrong. |
| The Following User Says Thank You to 09TrueRedGTX For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score A solenoid is used when the tank is higher than the nozzle and to prevent unwanted siphoning. How would having it behind the tb make a difference? I wouldn't think any additional vaccuum would exist post tb vs pre. tapped by satan
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #47 | ![]() |
"When mounting nozzles, we recommend before the throttle body/ throttle plate. If you mount the nozzle after the throttle body/plate, a solenoid upgrade must be used to prevent siphoning at Idle." | |
![]() | | #48 | ![]() |
Groans: 731
| Not Ranked : 0 score Hm. Wouldn't think there would be any post vac. Well, since it's said by a alcohol system manufacturer there....why would you ask if it's needed? I believe they know what they're talking about. If snow says it's needed, I think they've put some work into it and came to that conclusion. It is good to bring that to attention though since someone may just toss it in willy nilly without properly fleshing out the proper parts list. tapped by satan
![]() | | #49 | ![]() |
| Not Ranked : 0 score I wasn't asking. Lol. I was noting it for ppl interested in the spacer. |
![]() | | #50 | ![]() |
Groans: 731
| Not Ranked : 0 score It's early. I read things differently when I'm barely awake. tapped by satan
| The Following User Says Thank You to faeker For This Useful Post: | Mauro_Penguin (09-21-2014) |
![]() | | #51 | ![]() |
| Banned ![]() Join Date: Nov 2011 Location: McGuire AFB NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score Waiting on robs testing |
| The Following User Says Thank You to Lacey28 For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score You guys are both right. To prevent any siphoning or drip while the car is in vacuum or off, a solenoid or check valve is used. If you think about direct port (intake manifold) meth injection, usually each nozzle has either a solenoid or check valve or one right before the distribution block. |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | faeker (09-20-2014), Mauro_Penguin (09-21-2014) |
![]() | | #53 | ![]() |
![]() Join Date: May 2011 Location: Ft. Worth TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
After talking to DO, they do not recommend putting a check valve on each nozzle for direct port. Something about it having too much crack pressure with 4 check valves. In the end, I put the check valve right before the block. Not sure about the solenoid for direct port..
__________________ 07Speed3 TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. || | |
| The Following 2 Users Say Thank You to radbrad For This Useful Post: | Mauro_Penguin (09-21-2014), rfinkle2 (09-20-2014) |
![]() | | #54 | ![]() |
A solenoid has no crack pressure. Thank you @radbrad; Initial testing and pics. | |
![]() | | #55 | ![]() |
![]() Join Date: Feb 2011 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34,434
| Not Ranked : 0 score Correct me if I'm wrong, but this isn't quite right. In a pressurized container, the same outward force is acting on every point. The problem with multiple check valves is that they won't all open at exactly the same pressure/time. There is a chance that once two or three are open that there will not be enough pressure to crack the remaining valve(s). Swapping to a single valve prior to the block solves the cracking problem, but leaves a length of tubing between the valve and nozzle. Solenoids can be synchronized to open at the same time and located on the nozzles.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial |
| The Following 2 Users Say Thank You to magicka For This Useful Post: | Mauro_Penguin (09-21-2014), rfinkle2 (09-20-2014) |
![]() | | #56 | ![]() |
My understanding is that the nozzles are rated for a given flow pressure. It is usually a curve that rises exponentially to a certain flow point. The crack pressure usually is figured into the thought of how much a give nozzle will put out given pump pressure - crack pressure. What you say makes perfect sense as well. I would have to test that but if the lines are all 100% equal length, all should crack @ the same time. (assuming they aren't $2 springs and rubber stoppers, and have a tight tolerance, which they don't LOL) | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | magicka (09-20-2014), Mauro_Penguin (09-21-2014) |
![]() | | #57 | ![]() |
I have no idea how much pressure drops in the system once the valves open. I'll have to do some looking from a computer tomorrow. As long as you aren't running huge nozzles and massive amounts of boost (since actual cracking pressure will be spring pressure + manifold pressure), you should still be able to exceed cracking pressure for four check valves. The $2 springs worry me, though.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial | |
| The Following User Says Thank You to magicka For This Useful Post: | rfinkle2 (09-20-2014) |
![]() | | #58 | ![]() |
Not that I am not down for intellectual conversation, but anyone running a meth kit without a check valve or solenoid is asking for trouble. | |
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #59 | ![]() |
Also, fuck push loc fittings. AN or bust.
![]() | | #60 | ![]() |
BTW, I should have said .20 spring. LOL. | |
![]() | | #61 | ![]() |
Groans: 307
| Not Ranked : 0 score @rfinkle2; Are you just testing for a single nozzle or are you trying alternate configurations other than having the solenoid right at the plate? If running dual setup, are there any draw backs from running the meth line into the solenoid then dual lines to the JM plate with two inline check valves at the nozzles. This is the configuration I was planning, previously had them connecting to the DO nozzle taps to the Intercooler pipe. Looks like you have tested with the solenoid/nozzle directly to the plate, would a second solenoid be recommended in lieu of the check valves (dual setup). I guess I'm not really following the discussion of crack pressures in regards to this plate and Direct Port. DO is recommending 'NOT' to run check valves for Direct Port or multiple nozzles because of cracking pressure, they also recommend to NOT run more than a 50/50 mix (we know how that goes). I'm assuming that @Nitr0EngiE; setup mentioned above was running without issue minus his obvious concerns. So in regard to this plate and all dual or multiple nozzle setups, are we seeing any problems with check valves and their cracking pressures in relation to inadequate meth pump pressures? Also, is there a concern of substantial vacuum post throttle body to warrant an upgrade from check valve to solenoid? I am ready to get this dual nozzle setup put in, but will wait on this plate to be released, if nothing else to test how the dual setup with check valves and/or solenoids in place. Hopefully the wait won't be too long...
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | Mauro_Penguin (09-21-2014), rfinkle2 (09-21-2014) |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score There is going to have to be a second revision for guys with stock manis and I have some ideas about how it can be improved upon, but so far in my car and will spray today. |
| The Following 9 Users Say Thank You to rfinkle2 For This Useful Post: | Easter Bunny (10-07-2014), faeker (09-21-2014), Gr8Speed (09-22-2014), maisonvi (09-22-2014), Mauro_Penguin (09-21-2014), Micha (10-01-2014), ms6mil (09-21-2014), pzr2874 (10-08-2014), Scare Dem (09-21-2014) |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Whomever tests the stock mani or eventually gets one for the jmf and needs a hand.. I may know where to get fittings and what is available. |
| The Following 5 Users Say Thank You to rfinkle2 For This Useful Post: | faeker (09-21-2014), Mauro_Penguin (09-21-2014), Micha (10-01-2014), Scare Dem (09-21-2014), WetzMS3 (09-22-2014) |
![]() | | #64 | ![]() |
Groans: 731
| Not Ranked : 0 score Dude, I love seeing all your toys and parts in the garage. I need to swing over again just to take it all in.
| The Following 4 Users Say Thank You to faeker For This Useful Post: |
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Hook it up! I bought a jmf mani with direct port methanol injection.
__________________ 417whp 428tq 12.037@117.2mph |
![]() | | #67 | ![]() |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
Thanks Arman!
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | rfinkle2 (09-22-2014) |
![]() | | #68 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score This plate is a great solution for some custom fmic guys like myself. My setup left me not very much space between the tb and bpv for a proper wmi setup. |
| The Following 2 Users Say Thank You to Mistersix For This Useful Post: | mmikepetch (09-28-2014), rfinkle2 (10-07-2014) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score JMF has it on their site now. I placed my order earlier today and had a tracking number by the end of the day. I guess we shall see how it fits with oem intake manifold/ throttle body and cpe FMIC.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | rfinkle2 (10-07-2014) |
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is going on as well. These guys are all long time ms3 and ms6 owners and heavily involved on msf and their local nator chapter. Damond Motorsports has always put out ultra high quality stuff and this design has a smaller foot print and more nozzle mounting options. http://damondmotorsports.com/products/mazdaspeed-3-6-tb-spacer-with-injection-ports-pre-buy Last edited by rfinkle2; 10-08-2014 at 09:55 AM. |
| The Following 6 Users Say Thank You to rfinkle2 For This Useful Post: | Easter Bunny (10-07-2014), Farhan@DM (10-30-2014), jdmage_mx5 (10-07-2014), Micha (10-30-2014), ms6mil (10-07-2014), WetzMS3 (10-08-2014) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score Yea, I saw that and was about to buy the MD one. I know a few people are getting MD so I'll get the JMF to provide some input on it. Options make the world go around....or something like that. Edit: I'll spread the love, I just ordered one from MD also. I'll see which I like better and make someone's day better with the other.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with Last edited by jdmage_mx5; 10-07-2014 at 07:05 PM. |
| The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post: |
![]() | | #72 | ![]() |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Easter Bunny (10-08-2014), WetzMS3 (10-08-2014) |
![]() | | #73 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score I'm running the original DM prototype on my car. I can say, and @rfinkle2; can confirm it works very well. Especially if you don't try to spray way too much meth. ![]() I also may have heard that the final version for sale will get gussied up and made prettier, not that the one I have doesn't look good in there.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 4 Users Say Thank You to WetzMS3 For This Useful Post: |
![]() | | #74 | ![]() |
Groans: 307
| Not Ranked : 0 score Got my JMF throttle spacer Friday. I was able to get it installed with the stock Intake Manifold. Gonna get some testing done tomorrow. Dual Nozzle Meth Install I upgraded to all -4AN fittings and SS lines. Had some fun trying to get the spacer to work the way I wanted, but all is well. @rfinkle2; those silver 90* nozzle holder FPT to -4AN could have made the day a little easier. Where did you pick those up at? I couldn't find em when I was purchasing everything for the install.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 10-12-2014 at 07:23 AM. | |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score He was trying to spray the equivalent of 20 gph on the k04. That was most likely my fault due to mis-communication. |
![]() | | #76 | ![]() |
I completely misunderstood our discussion and mistook a future set-up for what should be run currently. So I setup the plate with 2 nozzles spraying around 12gph each, on my k04. It was entertaining and comically slow, but way too much meth.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #77 | ![]() |
Groans: 307
I think the only negative thing about this spacer, at least on my setup, is when I want to change nozzles I will have to remove everything. Depending on how things go with the dual DO7's I will be swapping them out for the DO10's Thanks again.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
| The Following User Says Thank You to ms6mil For This Useful Post: | rfinkle2 (10-15-2014) |
![]() | | #78 | ![]() |
Enjoy testing!
![]() | | #79 | ![]() |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score Great info in this thread thanks Rob and everyone who has contributed so far. I just got done installing my DO MAF kit yesterday and have a couple questions. First is about the check valve, I am just trying to make sure I understand its function correctly. So is the check valve performing two functions? The first of which would be keeping boost pressure from cramming water back through the line into the pump (at boost levels lower than the setpoint to actuate the pump), and second since it has a "cracking pressure" it is keeping the water in the line from being sucked in while the IM is in vacuum? I assume they must design the cracking pressure to be higher than any vacuum level the engine might produce. Also, I used the MD spacer, its awesome
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() | | #80 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f699/methanol-injection-info-176351/ | ||||
| Port Injection WMI, help | This thread | Pingback | 04-06-2015 01:17 PM | |
| w/m injection questions | This thread | Refback | 03-20-2015 12:03 PM | |
| Best way to take meth | This thread | Pingback | 03-20-2015 11:43 AM | |
| Meth failsafe solenoid placement | This thread | Pingback | 03-20-2015 07:29 AM | |
| methanol injection MAF failsafe | bigmike | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 12 | 07-25-2015 11:00 AM |
| Methanol Direct Injection | phate | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 290 | 10-01-2014 09:34 PM |
| Pre-turbo methanol injection | KoukiS14 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 26 | 10-19-2009 04:20 PM |
