| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() | | #481 | ![]() |
![]() Join Date: Nov 2015 Location: Newport Beach, Ca
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score
![]() | | #482 | ![]() |
![]() Join Date: Jun 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 15
![]() | | #483 | ![]() |
| Not Ranked : 0 score I hear ya, I was looking through mine and everything looked amazing right off the bat. No KR anywhere, I'm trying to figure out how he's going to improve on it! |
![]() | | #484 | ![]() |
| Not Ranked : 0 score I have more KR than I'd like. His base map only made 225 whp on vdyno for me, so I'm hoping for big improvements |
![]() | | #485 | ![]() |
![]() | | #486 | ![]() |
![]() Join Date: Sep 2013 Location: Mt. Greenwood, Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 583
| Not Ranked : 0 score "Good things come to those who wait." - someone. Settle down, let the man do his work!
__________________ 2010 CBM Mazdaspeed3 Freektune 93 CorkSport SRI, TIP & Race Pipe CP-E Stage 2 RMM & TMIC Cobb Accessport V3 Autotech HPFP Internals Pilot Super Sport 235/40/18 - Stock Pu Pilot Alpin PA3 215/50/17 - Sport Edition CE 2016.5 MGM Mazda CX-5 Touring |
![]() | | #487 | ![]() |
| Not Ranked : 0 score ran more logs tonight and got 255 twice which is much better. BAT's were down 20 degrees compared to prior runs. One log was with "bad" gas, then I filled up with shell 93, ran another. Same power curve and peak numbers, but the logs with shell had much less knock. I told Justin when I sent my original logs I wanted to upgrade to a full tune, so this shouldn't be a big deal. Glad I figured out what it was and the car is making ok power on the base map. Vdyno isn't all that accurate by itself. You use it more to gauge changes. |
![]() | | #488 | ![]() |
![]() Join Date: Oct 2013 Location: Kingston, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 706
| Not Ranked : 0 score Call ups with the slip and complain, my gf works for a service and the other drivers are always complaining about the ones who do that, they'll could actually get written up. What's the worst that happens? He keeps not ringing the bell? I usually just set all my packages to hold for pickup so I don't have to deal with the slips
__________________ 2013 Black MS3 CS SRI & TIP / CPE Catted DP / AT Internals / Cobb AP V3 [FREEKTUNED] COBB RMM / COBB shift weight & Shift knob / JBR SSP / CPE EGR Delete |
![]() | | #489 | ![]() |
| Not Ranked : 0 score got my revision. took a log. Numbers seem pretty low, but the tune looks safe. I'll grab a couple more and see if anything changes. If not, guess I'll ask about it. Hoping V Dyno is full of shit because the car feels like it pulls hard
__________________ AP V3 Damond RMM Test Pipe Autotech HPFP internals Cobb SRI + TIP ETS TMIC cp-e Triton CBE Hypnotic 272/330 93, 294/321 E85 (still tuning) Last edited by Speedy955; 09-29-2016 at 06:24 PM. |
![]() | | #490 | ![]() |
I also trust Vdyno as much as I trust the tap water in Mexico. Wanna get this thing on the dyno, wanna see what I'm putting down. Also VERY happy | |
![]() | | #491 | ![]() |
| Not Ranked : 0 score The VD should be pretty accurate at cf 1.01 and smoothing 3. Road is flat. There was like 10 mph of wind which might affect something, not sure to what extent. I will try again. Edit: So V Dyno is full of shit. 4th gear dyno, same road, same direction, same temp, same wind, and 278 hp.
__________________ AP V3 Damond RMM Test Pipe Autotech HPFP internals Cobb SRI + TIP ETS TMIC cp-e Triton CBE Hypnotic 272/330 93, 294/321 E85 (still tuning) Last edited by Speedy955; 09-29-2016 at 11:54 PM. |
![]() | | #492 | ![]() |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
It's why I don't use the software anymore. Unless you can lay down several logs and have them over lay identical. You're just going to pull your hair out chasing numbers. Haha. Happy to hear the recent feedback on the ots plus maps though, and glad you guys are enjoying them! Sent from my iPhone using Tapatalk
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
![]() | | #493 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Fuck Vdyno, I've done 3 back to back runs previously exact same stretch of road all the data looked identical such as BATS etc. They had 3 different vdyno readings of 460whp, 420whp and 500whp.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| The Following User Says Thank You to shaneski For This Useful Post: | Speedy955 (10-01-2016) |
![]() | | #494 | ![]() |
![]() Join Date: Jan 2013 Location: Manchester, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
| Not Ranked : 0 score My Virtualdyno numbers are horrible (under 240), but the car feels good. I don't worry too much about the numbers.
__________________ 2011 Mazdaspeed 3 VRM W/Tech CorkSport: 3" Power Series SRI, BPV & hose, Boost tubes, Battery box, HPFP internals, Short shifter and bushings. ETS TMIC, Ultimate Racing test pipe, Damond dual OCCs, Damond TMM, CP-E S2 RMM, COBB APv3, Freektune OTS+ 93 Oct. Rice: RallyArmor, Morimoto XB LED Fogs, VLeds Triton Reverse Lights, Redline boots and armrest cover, Maisonvi shift knob. Audio: Pioneer AVIC-7100NEX |
![]() | | #495 | ![]() |
| Not Ranked : 0 score now I'm just waiting for that corn tune to show up in my mailbox so I can unleash the beast
__________________ AP V3 Damond RMM Test Pipe Autotech HPFP internals Cobb SRI + TIP ETS TMIC cp-e Triton CBE Hypnotic 272/330 93, 294/321 E85 (still tuning) |
![]() | | #496 | ![]() |
![]() | | #497 | ![]() |
| Not Ranked : 0 score I got mine earlier but haven't had a chance to flash it. This thing rips on 93. I took another log for fun and looks like 3rd gear wheelspin or something. So E85 will be interesting.
![]() | | #498 | ![]() |
| Not Ranked : 0 score Made a couple changes. Ditched su RMM for diamond, upgraded to V3 ap, and swapped cpe tmic for ETS because the cpe was genwon. Weather was high 60's The car was RIPPING on 93. Felt way faster than before. Burned off enough 93 to mix e85. flashed the e85 map and.... Well... Jesus. This thing PULLS
![]() | | #499 | ![]() |
![]() Join Date: Apr 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score hi guys, While logging and testing on my own i have noticed an interesting issue with vertual dyno. Your maf calibration effects the numbers BIGTIME. The calibration for Injen cai was showing way more hp than actually there it seems. While using a cob sri the vd numbers are very very close to actual dynotech numbers. I just had my car dyno'd at granite state dyno and got 309whp/326tq. The 4th gear pulls on VD the previous days were very close 300-320whp variance (ambient temp differences). BUT the torque from VD seems to be at least 10 pct higher on average than actual dyno numbers. Just wanted to point out some facts i discovered. I hope to get a dyno tune for my S3 turbo next spring from Justin. New England Dragway look out!
__________________ --------------------------------------------------- 2012speedy3: cobb sri,tip, accessport, rmm, aem wmi, tbe(with meow),fuel pump innards,fmi self-tuned @ 309whp/326tq 13.522 @105 mph ![]() |
![]() | | #500 | ![]() |
__________________ 2013 Black MS3 CS SRI & TIP / CPE Catted DP / AT Internals / Cobb AP V3 [FREEKTUNED] COBB RMM / COBB shift weight & Shift knob / JBR SSP / CPE EGR Delete | |
| The Following User Says Thank You to AwAfrican For This Useful Post: | Gerbilo (10-14-2016) |
![]() | | #501 | ![]() |
![]() Join Date: Aug 2015 Location: Springfield, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score I haven't even ever paid attention to vdyno. After the OTS+ revision, I did half a dyno (like 3k rpm to 4.5k) before a deer jumped out ahead and I left off/braked. It said I was making 448 whp Theres no way with a bolted ms6 with a ko4 on its last legs, catted dp, and stock tmic haha |
| Display Modes | |
