  • 1 Post By jonspeed3
 Old 06-02-2015, 08:46 PM   #1
jonspeed3's Avatar
Posts: 1,059   (View Stats)
jonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the world
Groans: 58
Groaned at 134 Times in 68 Posts
Exclamation Gen 1 W/ GEN 2 motor + tranny tuning
Long story short, my motor popped on my Gen 1 last month and I sourced a Gen2 motor+tranny with 16k miles on it and the stock ko4. The car desperately needs a tune now as it bolted with my old mods + some new ones that came with the new motor. The car feels so sluggish, even though its running the same tune as my old motor. I was hitting 21/22 psi on my old motor and felt the monster torque, this one feels stock/sluggish and im barely hitting 17psi.
Old mods on new motor
CS TBE
COBB FMIC
CS SRI +TIP
EGR BP
COOLANT TB BYPASS
and i think thats it.
New mods that came with new motor
OCC
AT FP Internals (I used to have KMD V3)
Attached are logs, I've contacted Justin/Freekfune for pricing and turn around time, in the mean time can you guys please take a look at these logs, cause I dont know shit about tuning.
PS: I know the GEN 2 motor has different pistons, will that affect the power delivery from the current tune? Is the compression ratio different? Also since im running the Gen2 tranny, the gears are longer right? Do i need to be tuned in ATR to reflect that for the gearing??
THANKS GUYS!
Awal likes this.
US ARMY
07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me.
96 Red Miata // Not stock**
Missing home... Florida
jonspeed3 is offline   Reply With Quote
The Following User Says Thank You to jonspeed3 For This Useful Post:
Awal (06-02-2015)
 Old 06-02-2015, 08:52 PM   #2
LatinKraze's Avatar
Posts: 804   (View Stats)
Maybe you need the gen2 throttle tables. Is the tune exactly the same as before?
2016 CX-5 GT AWD
 Old 06-02-2015, 08:53 PM   #3
jonspeed3's Avatar
Groans: 58
yes tune is the same, havent touched it, its configed for my old motor/tranny
US ARMY
 Old 06-02-2015, 09:08 PM   #4
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
good luck with tune troubleshooting, I'm sure you'll get it sorted.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 06-02-2015, 09:08 PM   #5
spl
spl's Avatar
Posts: 185   (View Stats)
spl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the world
Imgur
I'll post this here as well for future reference or whatever since chat will get cleared.
2010 BM - FREEKTUNED - BNRS3
spl is offline   Reply With Quote
 Old 06-02-2015, 11:05 PM   #6
jeoje's Avatar
Posts: 180   (View Stats)
jeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the world
As far as the logs go, only a couple of things jump out at me with my limited tuning experience:
- AFR's seem slightly rich unless things have changed since I last tuned (shouldn't affect performance to the extent you're saying I don't think)
- You're not hitting boost targets, so maybe your WGDC needs to be tweaked considering you barely hit 75% (although my own car didn't go over 50% for 18PSI, they're all different)
* Different waste gate on the turbo
I'd imagine folks smarter than me will ask for a log with a 3rd or 4th gear pull from 2500RPM as well if you're comfortable doing so. It's harder to get good data points with shifts in there. I expect though, with the logs you posted, you're trying to represent how it's sluggish with normal driving.
Regardless, I think I would personally load a more tame OTS map and drive it lightly until I had someone more knowledgeable to talk to. Tunes are different enough between cars of the same gen/year, let alone a gen 1 ECU paired with a gen 2 engine. But I'm also overly paranoid.
2011 Liquid Silver Metallic MAZDASPEED3 -Traded...
Cobb AP | Autotech Internals | UR Catted DP | UR Resonated TP | UR CBE | Cobb TIP | CP-E Xcel Nano | CP-E RMM | JBR TMM & PMM | JBR OCC S2 | JBR SSP S2 | JBR EGR Delete | NGK Iridium IX
2015 Volkswagen Golf R - DCC, no mods
jeoje is offline   Reply With Quote
 Old 06-03-2015, 01:03 AM   #7
LatinKraze's Avatar
Well, the Gen2 has different gear ratios. I'd start by changing the gear ratios in ATR from Gen1 to Gen2 and then the throttle tables to Gen2 as well.
2016 CX-5 GT AWD
 Old 06-03-2015, 07:50 AM   #8
jonspeed3's Avatar
Groans: 58
Last night I changed the gear ratios in atr to match the gen 2 tranny. (Took me a while to figure it out) and it felt a little bit better but still slow compared to how it used to be. Hopefully freek tune can chime in, do I pay first and where do I send $$$ to?
US ARMY
 Old 06-03-2015, 08:12 AM   #9
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
I would start by checking out his website.
09TrueRedGTX is offline   Reply With Quote
 Old 06-03-2015, 08:31 AM   #10
MSP6's Avatar
Posts: 1,246   (View Stats)
Instead of changing a whole crap ton of tables in your Gen Juan map, why not start with a Gen 2 OTS and change the simpler tables. I.E AFR, WGDC etc from your old map. Then you know the guts of the GenPu tables are good to go.
The Following 2 Users Say Thank You to MSP6 For This Useful Post:
Awal (06-03-2015), CWP_MS3 (06-03-2015)
 Old 06-03-2015, 12:59 PM   #11
Awal's Avatar
That's exactly what I thought last night when we were chatting about it in shout, pretty sure I mentioned it. Maybe since it's a Genwon ECU still the AP won't let you load Pu maps? not sure, but it would be super nice/convenient to just flash it with even a factory Pu map and start tuning from there.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
 Old 06-03-2015, 03:17 PM   #12
jonspeed3's Avatar
Groans: 58
@Justin@Freektune;
US ARMY
 Old 05-24-2016, 08:47 PM   #13
yes sir's Avatar
Posts: 3   (View Stats)
yes sir is an unknown quantity at this point
Hey man, I saw that you swapped the engine of the gen 2 into the gen 1. Could you give me a run down of adjustments that you had to make. By my reading it looks like you have to relocate the power steering pump. Where you able to just bolt the gen 1 power steering pump right onto the gen 2 block? Were you able to every get it running good? Sounds like you were having trouble with it not running as good as the original motor, did you get it figured out? Did you do the gen2 ots maps with it?
Thanks for any input. Im looking to do the gen 2 swap into my speed6.
yes sir is offline   Reply With Quote
 Old 05-24-2016, 09:19 PM   #14
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
the only difference is the pistons and p/s pumps. the computer is still going to be the one that came in the car. no major difference.
gen one map in a gen one car.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-24-2016, 09:33 PM   #15
yes sir's Avatar
Alright, awesome! Just trying to weigh my options, but it would be compatible if I was just to put the gen 2 long block in and bolt up everything else to it? Are the Gen2 pistons lower or higher compression?
Thanks for your help!
 Old 05-24-2016, 10:01 PM   #16
mxlplx71's Avatar
Groans: 128
same, just updated.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
'11 motor/tranny into '10 chassis DarkPasseng3r 2010 MS3 - Engine, Transmission & Driveline 31 06-05-2012 09:44 AM
GT-R tuning update: Amuse breaks 600 hp, tranny woes at MCR Haltech Automotive News 0 04-28-2008 04:40 PM
Page generated in 0.36875 seconds with 29 queries
