| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Jun 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
Groans: 58
Groaned at 134 Times in 68 Posts
(Thread Starter) | Not Ranked : 0 score Old mods on new motor CS TBE COBB FMIC CS SRI +TIP EGR BP COOLANT TB BYPASS and i think thats it. New mods that came with new motor OCC AT FP Internals (I used to have KMD V3) Attached are logs, I've contacted Justin/Freekfune for pricing and turn around time, in the mean time can you guys please take a look at these logs, cause I dont know shit about tuning. PS: I know the GEN 2 motor has different pistons, will that affect the power delivery from the current tune? Is the compression ratio different? Also since im running the Gen2 tranny, the gears are longer right? Do i need to be tuned in ATR to reflect that for the gearing?? THANKS GUYS!
__________________ US ARMY 07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me. 96 Red Miata // Not stock** Missing home... Florida ![]() |
| The Following User Says Thank You to jonspeed3 For This Useful Post: | Awal (06-02-2015) |
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
| Not Ranked : 0 score Maybe you need the gen2 throttle tables. Is the tune exactly the same as before?
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
Groans: 58
(Thread Starter) | Not Ranked : 0 score yes tune is the same, havent touched it, its configed for my old motor/tranny
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 303 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
| Not Ranked : 0 score good luck with tune troubleshooting, I'm sure you'll get it sorted.
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s |
![]() Join Date: Jul 2014 Location: Saskatoon, SK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
__________________ 2010 BM - FREEKTUNED - BNRS3 |
![]() Join Date: Sep 2011 Location: Secaucus, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
| Not Ranked : 0 score As far as the logs go, only a couple of things jump out at me with my limited tuning experience: - AFR's seem slightly rich unless things have changed since I last tuned (shouldn't affect performance to the extent you're saying I don't think) - You're not hitting boost targets, so maybe your WGDC needs to be tweaked considering you barely hit 75% (although my own car didn't go over 50% for 18PSI, they're all different) * Different waste gate on the turbo I'd imagine folks smarter than me will ask for a log with a 3rd or 4th gear pull from 2500RPM as well if you're comfortable doing so. It's harder to get good data points with shifts in there. I expect though, with the logs you posted, you're trying to represent how it's sluggish with normal driving. Regardless, I think I would personally load a more tame OTS map and drive it lightly until I had someone more knowledgeable to talk to. Tunes are different enough between cars of the same gen/year, let alone a gen 1 ECU paired with a gen 2 engine. But I'm also overly paranoid.
__________________ 2011 Liquid Silver Metallic MAZDASPEED3 -Traded... Cobb AP | Autotech Internals | UR Catted DP | UR Resonated TP | UR CBE | Cobb TIP | CP-E Xcel Nano | CP-E RMM | JBR TMM & PMM | JBR OCC S2 | JBR SSP S2 | JBR EGR Delete | NGK Iridium IX 2015 Volkswagen Golf R - DCC, no mods |
| Not Ranked : 0 score Well, the Gen2 has different gear ratios. I'd start by changing the gear ratios in ATR from Gen1 to Gen2 and then the throttle tables to Gen2 as well.
Groans: 58
(Thread Starter) | Not Ranked : 0 score Last night I changed the gear ratios in atr to match the gen 2 tranny. (Took me a while to figure it out) and it felt a little bit better but still slow compared to how it used to be. Hopefully freek tune can chime in, do I pay first and where do I send $$$ to?
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score I would start by checking out his website. |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Instead of changing a whole crap ton of tables in your Gen Juan map, why not start with a Gen 2 OTS and change the simpler tables. I.E AFR, WGDC etc from your old map. Then you know the guts of the GenPu tables are good to go.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| Not Ranked : 0 score That's exactly what I thought last night when we were chatting about it in shout, pretty sure I mentioned it. Maybe since it's a Genwon ECU still the AP won't let you load Pu maps? not sure, but it would be super nice/convenient to just flash it with even a factory Pu map and start tuning from there.
Groans: 58
![]() Join Date: Mar 2013
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hey man, I saw that you swapped the engine of the gen 2 into the gen 1. Could you give me a run down of adjustments that you had to make. By my reading it looks like you have to relocate the power steering pump. Where you able to just bolt the gen 1 power steering pump right onto the gen 2 block? Were you able to every get it running good? Sounds like you were having trouble with it not running as good as the original motor, did you get it figured out? Did you do the gen2 ots maps with it? Thanks for any input. Im looking to do the gen 2 swap into my speed6. |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
gen one map in a gen one car.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. | |
| Not Ranked : 0 score Alright, awesome! Just trying to weigh my options, but it would be compatible if I was just to put the gen 2 long block in and bolt up everything else to it? Are the Gen2 pistons lower or higher compression? Thanks for your help! |
Groans: 128
| Not Ranked : 0 score same, just updated.
| '11 motor/tranny into '10 chassis | DarkPasseng3r | 2010 MS3 - Engine, Transmission & Driveline | 31 | 06-05-2012 09:44 AM |
| GT-R tuning update: Amuse breaks 600 hp, tranny woes at MCR | Haltech | Automotive News | 0 | 04-28-2008 04:40 PM |
