| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Apr 2010 Location: Schaumburg, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 325
(Thread Starter) | Not Ranked : 0 score Sorry if this was posted or clarified previously didn't see it spelled out anywhere.
__________________ 2007 True Red Mazdaspeed 3 GT Power - Cobb AP v3, AT HPFP internals, Ultimate racing DP, Borla CBE, Forge v2 bpv, CP-E TIP, Mazdaspeed OEM CAI Handling - CS Genwin Steering wheel, Maisonvi custom shift knob, Koni FSD shocks, Hotchkis f+r sway bars, Damond RMM, EBC USR rotors + Yellowstuff pads, JBR SSP + weight + bushings Soon - FMIC Followed by a protune 2008.5 CWP Mazdaspeed 3 SOLD |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score if you only want a tune for e its probably just the 200. i run e30 there isnt much to gain by using more e, just a chance of black death at 50%+e
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score I think he means a full tune for E85, not a tune for "full" E85. Full meaning not an OTS+ deal.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score I believe it he price is for both because you can buy a 93 tune for $200 and later add an e85 tune for $75. Which is what I'm doing now
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
(Thread Starter) | Not Ranked : 0 score Thanks for your feedback all That's what I thought! Thats rad AF if that is the case
Groans: 33
| Not Ranked : 0 score E85 tune is "just" a continuation of the completed 93 tune, where you raise timing/boost and adjust other related parameters to get the most out of your setup.
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | ms_3 (06-17-2016) |
(Thread Starter) | Not Ranked : 0 score Thank you brother! Stoked to get this ball rolling
Groans: 128
makes it really easy, no mixing.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. | |
| Not Ranked : 0 score E30 bmw pump? Sent from my iPhone using my stinky little fingers
Groans: 128
| Not Ranked : 0 score e85 or e30 at the station
(Thread Starter) | Not Ranked : 0 score Justin emailed me a response and just to confirm for anyone that may not know, as macdiesel and speedrebirth stated, the $275 covers a fully dialed in 93 tune and an E85/mix tune
| The Following User Says Thank You to ms_3 For This Useful Post: | mxlplx71 (06-21-2016) |
Groans: 211
| Not Ranked : 0 score I think Justin is done with my 91 tune. His last email to me did not say one way or the other and had no revision attached. My last set of logs I sent him I pointed out fuel trims slightly off at normal cruising but fine at WOT. I mentioned they were fine with the previous map and most likely a boost leak I can track down easily. I sent the logs and his response was; Hey man Nothing should have changed with the maf cal. You can try loading rev C again. Could be boost leak, o2 sensor, purge valve, dirty maf, dirty air filter lol. Lot of things So I responded to him asking if we were done tuning. As I have no clue. Ugh. Frustrating. I'll have to wait 5 days before I hear back I am guessing. My MAF is brand new OEM, and everything else is clean, newish, etc. I made sure my ride was on a fresh tune up before starting with him. Anyhow, assuming he can do no more for me at 91 octane I want to do an E85 tune. I only paid for a 91 tune thus far. So do I pay $75 to do E30 mix or $200 again? I want to do E85 as I had high KR at 21 psi and none at 18 psi. Will I be able to run higher boost on an E30 mix? Is it worth it?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles Last edited by Thor Hammer; 07-07-2016 at 04:42 PM. |
Groans: 33
| Not Ranked : 0 score It is totally worth it. I would think your timing is around 10* on 91, after that it will knock. 93 is usually maxed out at round 12-14* timing. And with E85 you can go as high as 17-21*. How much timing you can run is also relative to how much boost you run. Heat and pressure is what causes knock. So hell yeah, go for it! And it should be $75 yes
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Once i was tuned with e there was no looking back. I use 93 only if I'm going on a trip where some hodgie will screw up my mix ratio by not letting me mix my own gas (cough jersey cough) or cant get to e85. It runs the motor safer and takes more heat out of the cylinders as well as giving mucho powa. Imo the extra for a e85 tune is cheap considering the timing has to be reworked.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | Thor Hammer (07-07-2016) |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score you won't regret going corn fed! DO IT!!
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
| The Following User Says Thank You to wes3id For This Useful Post: | Thor Hammer (07-07-2016) |
| ots + or full tune? | Me2speed3 | FREEKTUNE | 2 | 03-28-2016 05:19 PM |
| Freek OTS or full tune | Bug2110 | 2010 MS3 - ECU Computer Tuning | 13 | 05-28-2015 08:26 AM |
| Tune needed only for full TBE? | Speedstick | 2010 MS3 - Engine, Transmission & Driveline | 28 | 12-08-2010 08:19 PM |
| Cp-e Full Control Flash w/o standback & tune? | steven88 | MazdaSpeed 3 - Engine, Transmission & Driveline | 0 | 07-10-2009 10:32 AM |
| Cp-e Full Control Flash w/o standback & tune? | steven88 | MazdaSpeed 3/6 - ECU Computer Tuning | 57 | 07-09-2009 11:53 PM |
