| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Nov 2015 Location: Walworth, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score Just had a quick question, typically how long does it take between sending back logs and a new map revision. This isn't a complaint at all, I'm honestly just asking because I'm not sure if my e-mails are going through correctly or not. After placing my order I was amazed how fast I received my map, but I sent datalogs back about a week ago and haven't gotten a response. If it hasn't been done yet that is totally fine, just wanted to make sure they are being received correctly. I sent a question a few weeks ago (a few days before I bought the tune), but never received a response to that as well, I just figured it was because I had bought a tune so the question didn't need to be answered, but I'm starting to think it may be my email (I am using yahoo which I know some domains have issues with). Again, not a complaint at all, I know Freektune is fantastic, the first map I received blew me away as far as how on point it was in the first place. Just wanted to ask instead of waiting longer just to find out my email is screwy hahaha. Thank you! Brandon
__________________ 2006 Titanium Gray Metallic Mazdaspeed 6 GT ~144k Miles AP V3 with Freektune, BNR S2, Autotech Internals, Catless ebay dp, Cobb TIP+SF, HKS BOV, JBR RMM, CPE xFlex Rear Diff Mount, JBR EBCS, Bosch 3 Bar Map Sensor |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I typically receive mine every 3-4 business days. Depends on how busy he is of course and if he has any events that week.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
(Thread Starter) | Not Ranked : 0 score Thanks! Actually just got mine today hahaha, should have just been more patient. So pumped to go out and try it.
![]() Join Date: Jun 2015 Location: Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score I heard he tries to stay within 1-3 business days but it's probably a busy time of the year so I've been receiving mine closer to 3-5 business days...patience has been killing me over the past couple weeks |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Yeah I'm also waiting for my base map for my S4, it's been 4 days since I finished the install and the wait is agonizing! Sent from my SPH-L720 using Tapatalk |
Groans: 211
| Neutral : -1 score At this point I would expect a longer than usual wait before you hear back from him. I've been getting my maps back from him in 5-6 business days. He is very busy so patience is required...when you want the best! Its worth the wait. I'm close to my last revision but had to stop due to a sudden freak out of my trims. Might have developed a minor boost leak. And due to KR above 18psi had to turn it down. Totally cool with that as my car is about to tick over 100K! Even at 18psi I am MORE than happy with the power curve and how hard it hits. I actually never go WOT other than when doing logs for the tune. LOL.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
![]() Join Date: Aug 2015 Location: Kent, WA
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score I sent a general email and haven't received a response at all. I noticed that he took off the custom tune from the website so he's probably super booked. Can anyone recommend something in the meantime while Justin is catching up? Should I just load Cobb maps for now? |
__________________ 2006 Titanium Gray Metallic Mazdaspeed 6 GT ~144k Miles AP V3 with Freektune, BNR S2, Autotech Internals, Catless ebay dp, Cobb TIP+SF, HKS BOV, JBR RMM, CPE xFlex Rear Diff Mount, JBR EBCS, Bosch 3 Bar Map Sensor Last edited by BrandonM; 07-02-2016 at 11:47 AM. | ||
![]() Join Date: Jul 2014 Location: Haledon,NJ
Rep Power: 0 ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score I've been waiting for 18 days now since I sent my logs. Not sure what's goin on but it cant be that bad to not respond. At least a "sorry, still working on it".
__________________ 2006 MS6 Sport BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510 JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter) TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage 2013 Mitsubishi Outlander Sport SE Stock |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score sometimes emails don't go through. i was using yahoo to contact him and had many problems with them being not delivered, so i switched to my other hotmail address. if it has been 18 days, i would try a different email and reference your order #.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
I bought the car freektuned about a year ago and loved the reliability and power compared to other cars with similar mods which was the major reason I decided to freektune after turbo swap.
__________________ 2006 MS6 Sport BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510 JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter) TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage 2013 Mitsubishi Outlander Sport SE Stock Last edited by MS3Shadow; 07-04-2016 at 11:06 AM. | |
| Not Ranked : 0 score every email you send bumps you further down the list, so i would not send a bunch. Just send one asking whats going on and indicate that it's been 18 days.....then wait another 3-4 business days for a response. You could also shoot him a message on instagram, might be quicker
| Not Ranked : 0 score I have him on Facebook but don't want to call them out on Facebook. He doesn't have messenger. I don't have an Instagram. Never did and trying really hard not to open one. Facebook is bad enough. lol @wes3id are from jersey?
__________________ 2006 MS6 Sport BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510 JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter) TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage 2013 Mitsubishi Outlander Sport SE Stock Last edited by lescano88; 07-04-2016 at 10:59 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score no, why?
| Not Ranked : 0 score Your location shows Lodi. There a Lodi in jersey.
| Not Ranked : 0 score oh, nope..Lodi Ohio
| Not Ranked : 0 score @lescano88; i just messaged justin on instagram for you
![]() | | #19 | ![]() |
| Not Ranked : 0 score [@wes3id Thanks, I appreciate it a lot.
![]() | | #20 | ![]() |
| Not Ranked : 0 score Update: I received my revision today. I had send waves of bump emails then started a new email to him. Finally got his attention.
![]() | | #21 | ![]() |
![]() Join Date: Jan 2014 Location: San Diego, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score You will quickly learn doing that doesn't help. I know I did haha. Just be patient. It seemed right when I couldn't wait any longer for a response, I would get one.
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff |
![]() | | #22 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Bump emails move you further down the list. First in, first out. If you send a bump, bottom of the list chump.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
![]() | | #23 | ![]() |
![]() Join Date: Jun 2015 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
Groaned at 7 Times in 2 Posts
![]() I'm sure he had holiday plans just like the rest of us.
__________________ 2011 MS3 Velocity Red Mica BNR S3 - - - CS Catless Downpipe - - - JBR SRI/TIP - - - Cobb 3-Port EBCS CS 3.5bar MAP - - - JBR Thermal IM Gasket - - - CNT Catback- - -Ebay Test Pipe JBR 88 Duro RMM - - - JBR Tru Torsion 1.25" RSB - - - Swift Springs - - - Cobb Shifter Weight CS Adjustable Shocks/Struts - - - Damond EGR Delete - - - Autotech Internals FREEKTUNED | |
