| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Oct 2011 Location: Clifton Park, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score I am having rich at idle issues, and was wondering if this could be a culprit. Thanks!
__________________ 2006 Black Mica MS6 - COBB AP V2, OTS 93 Stage 3 Tune, BNR S3, Relentless IM, CX Racing FMIC, AEM CAI, Cobb EBCS, Autotech HPFP Internals, Magnaflow Cat-Back, ATP Catted DP (GONE) - 2008 Black Mica MS3 |
| The Following User Says NO Thank You to nebolskeetskeet For This Un-useful Post: | mituc (08-01-2018) |
| Not Ranked : 0 score No
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Vansquish (07-13-2018) |
| Not Ranked : 0 score If you have an s4 and your running a ots map kiss that motor goodbye. It’s a matter of time before she lets loose.
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score OP join date is 2011...7 years to research shit that will answer the questions 100 times over....then to top it off, posts in the wrong area of the forum to ask the obvious.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
I posted here because I wanted to know from a pro tuner if this was compounding to my issues. All I could find doing research is that a custom tune is needed for the ebcs, and not what happens if you don’t run a custom tune.
__________________ 2006 Black Mica MS6 - COBB AP V2, OTS 93 Stage 3 Tune, BNR S3, Relentless IM, CX Racing FMIC, AEM CAI, Cobb EBCS, Autotech HPFP Internals, Magnaflow Cat-Back, ATP Catted DP (GONE) - 2008 Black Mica MS3 | |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score non stock turbo = custom tune
Groans: 111
The rich at idle errors are usually caused by MAF calibrations. No matter where you have a leak in your intake, at idle you're pretty much under vacuum so the engine would pull unmetered air rather than loosing metered air. So probably the previous owner also had a different (larger) intake and the tune you now have on the car has the MAF cal for that intake, not for the smaller intake you have now. Usually this code appears when the difference between the target AFR and actual AFR is larger than 25% which is beyond the self-adjusting capabilities of the ECU logic, and also indicate a problem. Another cause for the rich condition may be faulty HPFP o-rings which favour fuel-oil mixing. In such cases though there is going to be so much fuel in the oil that the oil level (or whatever you can call the resulted fluid) will be way beyond the MAX mark on the dipstick. So check that as well. So nothing to do with the Cobb EBCS or Freektune. Please post in the right section next time.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following 2 Users Say Thank You to mituc For This Useful Post: | nebolskeetskeet (08-01-2018), Orimar (08-01-2018) |
I also appreciate your input, I have been doing a lot of research lately and what you say makes total sense. I am not getting any crazy amounts of gas in my oil so I think that the leaking o-ring wasn't the culprit. I recently replaced my radiator, thermostat, MAF, PCV valve, and corrected some incorrect routing of lines on my EBCS and I have not thrown the P2188 code in 200 miles and counting. However, I am noticing that my LTFTs are negative when cruising, so I suspect a MAF cal is needed. Like I said, I am kinda new to the tuning game and want to make sure the car is running safely. Thanks again for the help. Next time I will post in the appropriate forum.
Groans: 211
Are you really running an OTS tune with a BNRS3??? Also, fuel trims in the +/- 8-10% range are normal. Nothing to worry about.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
Yes, the previous owner told me that he was running Cobb's OTS Stage 3 tune. I am truly ashamed that I did not do the right research before committing to the car. So, right now I am on a mission to ensure the car is in the best working order before getting an e-tune. Depending on the bin, my LTFTs are between -10% to -20% while driving. Idle is around -5%.
| Not Ranked : 0 score If your intake system (from MAF to head) is without a doubt leak free, a proper MAFcal is needed.
![]() Join Date: Jul 2018
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I just swapped another motor due to my old Block blowing a hole out the back I installed everything there is just one plug for my Cooling fan that i can’t seem to find. Its a single pin plug with a red lock tab on it Any help please ! |
| The Following 2 Users Say NO Thank You to Derekst For This Un-useful Post: | mituc (08-01-2018), Thor Hammer (08-01-2018) |
When changing out my radiator I can across two plugs with red lock tabs: one on the throttle body, and the other connected to a sensor on the hood latch.
Groans: 211
Seriously, start your own thread noob.
| Cobb EBCS | m249saw | 2010 MS3 - Turbo Induction | 70 | 07-22-2012 09:17 PM |
