| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Jun 2013 Location: Belmont, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score I have yet to read anything negative about Justin on this entire site and that won't change with my review. He works wonders with these cars and he does it quickly and efficiently. I was delayed on getting him logs a few times and he still popped right back with the revision within a day. My car runs and feels great. I will recommend Justin to anyone looking to safely get the most out of their vehicle. I attached my vdyno plots from the final revision vs. my old k04. Very well done Justin. Thank you!
__________________ 2013 MS3 Black Mica GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3 CS HPFP Internals | CS Catted DP | CS RMM | TR6 FMIC w/ JBR Piping | HKS SSQV4 BPV CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium Freektuned 350/365 |
| The Following 5 Users Say Thank You to Porterhouse07 For This Useful Post: | Atticaz (01-23-2016), eliwwjd (01-19-2016), ericrapp0507@gmail.com (01-22-2016), Justin@Freektune (01-19-2016), sh4d0w (01-19-2016) |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Looks great! Justin is the tuning mad scientist! My car also runs great after he touched my car. Freektune simply the best!!!
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
| The Following User Says Thank You to eliwwjd For This Useful Post: | Justin@Freektune (01-19-2016) |
![]() Join Date: Jan 2014 Location: Harco MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Are you considering running meth to get those numbers a little higher? Even as a safe guard its nice to have.
__________________ 2008.5 CWP MazdaSpeed3 Purple Drank Tuned ATP GT3076R @ 26 psi 369.5whp & 348wtq.. yawn |
(Thread Starter) | Not Ranked : 0 score I most definitely am. Got a few parts to install this weekend and that's my next step. I just have to decide which kit I want. I'm currently leaning toward the aquamist HFS3. But that may change.
sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Porterhouse07 (01-19-2016) |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Was the k04 tuned by justin and were all the parts the same aside from the turbo swap?
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
(Thread Starter) | Not Ranked : 0 score I had a Cobb OTS tune with the k04. I did the larger intake and the CBE at the same time as the turbo swap. Before the swap, I had a CS SRI/TIP and the stock CBE with res deleted.
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
| Not Ranked : 0 score Nice numbers!! What were your mods in the K04 plot?
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
(Thread Starter) | Not Ranked : 0 score Catted DP, CS SRI/TIP, HPFP, FMIC, APv3
| The Following User Says Thank You to Porterhouse07 For This Useful Post: | Atticaz (01-23-2016) |
| Not Ranked : 0 score Nice!! Thanks. Sent from my iPhone using Tapatalk
| Very Satisfied Customer | pfp22972 | FREEKTUNE | 1 | 05-01-2014 08:00 PM |
| Another satisfied customer | Mikesp3 | Stratified Automotive Controls | 23 | 07-20-2013 09:25 AM |
| Yet another more than satisfied customer... | CCC | JAMES BARONE RACING | 6 | 11-12-2010 12:33 PM |
| Another satisfied JBR SSP Customer | mazdaspeeding | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-14-2010 10:51 AM |
| Another satisfied customer. MS6 SSP | fhaze | JAMES BARONE RACING | 1 | 05-03-2010 10:04 AM |
