Like Tree14Likes
 Old 12-17-2013, 09:46 AM   #1
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Originally Posted by thedoctor View Post
Got it, install took about 1 hour. Shipoing was super fast ordered it Friday got here(ny) on Monday.
Snapped one of the bolts that hold the bpv. So I haven't gotten to test it much. Just picked up new bpv bolts ill update once car is running again.
Sent from my SPH-L710 using Tapatalk 4
Just curious - how did you make out with the bolt ?
I just replaced my motor and put in a catless DP and internals - now I'm smoking like Cheech and Chong, even with idle at 950 and Rotella....
DAVEJ3587 likes this.
Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM
Mandinca is offline   Reply With Quote
 Old 12-17-2013, 11:55 AM   #2
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
You're going to have to get one and test it yourself. Some people (like myself) got rid of the smoking with the use of a properly sized restrictor bolt and some people didn't. It seems to be a case-by-case fix. It's a relatively inexpensive fix and if it doesn't work for you, you can turn around and sell it...
 Old 02-26-2014, 05:25 PM   #3
thedoctor's Avatar
Posts: 35   (View Stats)
thedoctor is a splendid one to beholdthedoctor is a splendid one to beholdthedoctor is a splendid one to beholdthedoctor is a splendid one to beholdthedoctor is a splendid one to beholdthedoctor is a splendid one to beholdthedoctor is a splendid one to behold
so far so good. i did get a bit of smoke a few times, but it no longer smells like im burning thru a qt a day and aside from the 2 times that i seen a bit of smoke after that, its been good.
2011 Black Speed3
AP, AutoTech Internals, Cp-e dp (No cat), K&N Typhoon, HTP 3" inlet, H&R coilovers, JBR camber arms, JBR RMM
Freeked
thedoctor is offline   Reply With Quote
The Following User Says Thank You to thedoctor For This Useful Post:
Matt@DamondMotorsports (02-26-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/stock-turbo-oil-restrictor-banjo-bolt-152336/
Zakman's Speed6 (previously Mz3) - Page 6 This thread Refback 08-13-2013 01:09 PM
Bnoon Banjo turbo restrictor bolt tburton101 MazdaSpeed 3/6 - Turbo Induction 24 07-13-2009 10:06 AM
Page generated in 0.28100 seconds with 23 queries
