| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Neutral : +1 score The Damond Motorsports Oil Pressure Sensor Adapter allows an aftermarket oil pressure sensor to be connected into your oil system, with very little modification. Our OPS adapter connects into the factory oil sensor connection, located on the oil filter housing, and adds a “T” to connect the factory sensor and connect an additional aftermarket sensor. This way, there is no need for a sandwich plate, which can minimize the size of oil filter you can run. Also, the OPS adapter works with the cartridge style filter housings, used on many 4 cylinder Mazdas. The Damond Motorsports OPS adapter comes with all the fittings you need to connect either a 1/8” NPT or 1/4” NPT oil pressure sensor, and enough hose to locate the sensors where you would like. We also include a bung, as to close off the additional connection, if, for some reason, the aftermarket sensor would need to be removed. http://damondmotorsports.com/collect...sensor-adapter Price: $29 free US shipping ![]() Last edited by Matt@DamondMotorsports; 10-29-2014 at 09:06 AM. |
| The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | Code Monkey (03-22-2013), dsb_chicago (02-13-2014), helmetface (03-22-2013), Hush (03-22-2013), Micha (03-27-2013), mike w (04-16-2013) |
| Display Modes | |
| Bad Fuel Pressure Sensor? | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 8 | 11-18-2013 07:51 PM |
| TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
