| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score Damond Motorsports Oil Catch Can kits come with everything you will possibly need for an optimized OCC system. A high quality Damond Motorsports OCC specially developed for the Mazdaspeeds, high quality oil and vacuum resistant hose, pre-cut to fit your vehicle perfectly, high quality check-valve, and all the components to tie everything together and mount it all up. This is a simple bolt-on/clamp-on kit, which does not require all the time and frustration that goes into: acquiring all the components separately, measuring, cutting, fabricating brackets, test-fitting, etc. The benefits of adding one of our OCC kits: enhanced engine reliability, cleaner intake passages, improvements in engine performance and response, and better fuel economy. For the MS6, there are 2 mounting locations: Version 1: Mounted on the horn bracket Allows space for some intercooler kits Included drain-plug, does not come with drain valve Most popular OCC kit for the MS6 Front bumper does NOT need to be removed for installation Version 2: Mounted below factory intake/short-ram intakes Designed to be used with all intakes, including the factory air box Allows space for most intercooler piping, except for the CP-E FMIC Comes with hose to attach to drain spout, making draining easier (you may need to drill into the undertray, in order to use the drain hose) For the 07-09 MS3 here's the 3 mounting locations: Version 1: Mounted below the factory intake/short-ram intakes Allows space for intercooler piping Easy to drain, the drain spout can be reached from above the engine Most popular OCC kit, for the MS3 Will NOT fit with cold-air intakes Version 2: Mounted under the windshield washer reservoir Designed for cars where a cold-air intake is already in place Allows space for intercooler piping The passenger untertray has to be removed, in order to drain Will NOT work on Canadian MS3's, due to having a larger washer tank Version 3: Mounted on the transmission, underneath the factory intake/short-ram intakes Designed to allow space with cold air intakes Easy to drain, the drain spout can be reached from above the engine Occupies the space for most front-mount intercooler piping For the Gen2 10-13 MS3, here are the 2 mounting locations: Version 1: Mounted below the factory intake/short-ram intakes Allows space for intercooler piping Easy to drain, the drain spout can be reached from above the engine Most popular OCC kit, for the Gen2 MS3 Will NOT fit with cold-air intakes Version 2: Mounted on the transmission, underneath the factory intake/short-ram intakes Designed to allow space with cold air intakes Easy to drain, the drain spout can be reached from above the engine Occupies the space for most front-mount intercooler piping We also make kits for the CX7. VTA OCC add-on: This allows the Damond Motorsports OCC to vent pressure when excess pressure is present in the crankcase. This option contains a VTA breather filter and check valve. The check valve allows one way flow of pressure out of the can, while the filter keeps debris away from the check valve. The filters are completely washable and re-usable. The Damond Motorsports VTA option is perfect for high boosting K04's, BNR's, and other bigger turbo options. Note: Not compatible with MS6 OCC Version 1 ![]() ![]() You can order directly off the site http://damondmotorsports.com/collections/occ prices for the kits are $185-225 depending on options, free US sipping. If you have any questions about the OCC kits, feel free to post up in here or shoot me a PM. If you have one of these kits, and you'd like to post a review up in here, that would be awesome. I have a thread going over the testing preformed on the OCC kits, to show y'all what's involved in making an awesome set-up to relieve the speeds of crankcase gunk. Last edited by Matt@DamondMotorsports; 01-22-2015 at 01:58 PM. |
| The Following 16 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | atvfreek (03-17-2013), Awal (11-13-2015), davychronic (08-20-2015), Dmurray06 (03-17-2013), Ferdball (09-11-2013), Format (09-24-2013), helmetface (03-18-2013), Kdawg207 (03-18-2013), Koke382 (03-17-2013), ms6mil (03-27-2013), n3farious (03-17-2013), PapaBruno (12-30-2016), Raider (03-18-2013), rfinkle2 (03-18-2013), SneakySin (03-18-2013), TiGraySpeed6 (03-13-2013) |
![]() Join Date: Mar 2011 Location: Plano, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score I have version 3 installed on my 08 MS3. It is a well made piece and was fairly easy to install (with a lift).
__________________ 2008 True Red MS3 BNR S1 Turbo, AEM CAI, Cobb AP v3, Cobb DP, Cobb TIP, AT FP Internals, Saikou Michi OCC, NGK LTR7IX-11, JBR CM RMM, H&R Coilovers, EBC Redstuff pads RichTune |
| The Following User Says Thank You to n3farious For This Useful Post: | Matt@DamondMotorsports (03-18-2013) |
| Not Ranked : 0 score I installed my dual occ setup and very impressed. Great quality parts! Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | Matt@DamondMotorsports (03-18-2013), rfinkle2 (03-18-2013) |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 507
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score I saw a few of these yesterday at Matt's place and I must say this is one high quality piece. I love the fact that it is easy to drain and it can be reached from the top. I will be replacing my current occ with a damond can in the near future. Glad to see this Matt and I'm excited for future products. Sent from my iPhone using Tapatalk 2
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
| The Following User Says Thank You to Jhornbrook For This Useful Post: | Matt@DamondMotorsports (03-18-2013) |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() Join Date: Jun 2012 Location: Elgin, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 656
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score @Damond Motorsports; occ kit and customer service is the absolute best! Timely replies and he stands behind all of his products with no hassle. Not that I've had any issues with my setup at all but he did assure me if there every was an issue, do not hesitate to contact him for a swift resolution. Definitely looking forward to doing more business with Damond Motorsports for sure! |
| The Following User Says Thank You to SneakySin For This Useful Post: | Matt@DamondMotorsports (03-18-2013) |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score I think I remember you offering an option to buy just the hose and check valve... Is this still an option? Also I love my can currently running the version 1 with no clearence issues at all an instructions were dead on.
__________________ TEAM LUXURY |
| The Following User Says Thank You to Sid3wayS For This Useful Post: | Matt@DamondMotorsports (03-18-2013) |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score I've been running a MD OCC (stage1) for 2 years now and I've never had any issues with it. Matt is a real down to earth dude who goes the extra mile to take care of his people.
__________________ |
| The Following 2 Users Say Thank You to helmetface For This Useful Post: | atvfreek (03-18-2013), Matt@DamondMotorsports (03-18-2013) |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score I could use one of these but I can't really justify the price (of any occ)
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | Matt@DamondMotorsports (03-18-2013) |
PM me your number, I don't think I have it.
I'll try and get it finished and posted in the next couple days. I was planning to tag you anyway in the thread lol.
Also, when you piece something together, using high quality hose, OCCs, CVs, etc. you can come out spending ALOT of cash. | ||||
| The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | atvfreek (03-18-2013), Boosted Beluga (03-18-2013) |
| Not Ranked : 0 score Matt when I have the money I absolutely need one of your occ's. I blew the hose off to the intake manifold yet again and it happened on the fucking highway. I need some strong clips the wont fail every time I go WOT. So I come to Damond motorsports. This blows by the way without a jack and stuck at a gas station. Sent from my iPhone using Tapatalk 2
![]() Join Date: Jul 2011 Location: Kelowna, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Hey guys, I couldn't find a better thread to ask this under, and didn't want to start a new one... Can anyone tell me if the butterfly valve on the bottom of the Saikou can is something I can buy anywhere or is it a custom piece I'd have to order from Matt or Saikou? Busted mine today :'(
__________________ 2007 Mazdaspeed 3 Red Cobb AP Stg 1 || Corksport SRI || Corksport TIP || JBR RMM || JBR Short Shift Plate || JBR Rigid shift bushings || JBR EGR Block-off || Saiku Michi OCC |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| The Following User Says Thank You to speed_freak91 For This Useful Post: | Matt@DamondMotorsports (09-11-2013) |
| Not Ranked : 0 score I managed to find one at LORDCO, thanks!
| The Following User Says Thank You to HeliBif For This Useful Post: | Matt@DamondMotorsports (09-11-2013) |
(Thread Starter) | Not Ranked : 0 score Yep, it's a 1/4" NPT. I think I have a few spares, where if you need one, just pay shipping. |
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | skeurton (09-11-2013) |
| Not Ranked : 0 score Thanks Matt! I really appreciate the offer. I'll let you know if the one I bought doesn't work.
| The Following User Says Thank You to HeliBif For This Useful Post: | Matt@DamondMotorsports (09-13-2013) |
(Thread Starter) | Not Ranked : 0 score Just make sure to put a bead of RTV around the threads, and don't tighten it in too crazy. Any air compressor drain valve should work well. |
![]() Join Date: Mar 2012 Location: Beaufort, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score Just ordered one of your catch cans tonight, can't wait till it gets here.
__________________ 2010 MS3 non tech // CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows// ![]() TUNED BY STRATIFIED![]() |
![]() | | #19 | ![]() |
![]() Kits are still back-ordered, for anyone looking to purchase one off the site. However, I am working on something to eliminate that, very soon. | |
| The Following User Says Thank You to Matt@DamondMotorsports For This Useful Post: | jtday (04-07-2014) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score It's all good, I can wait. Really appreciate you contacting me about it.
| The Following User Says Thank You to covelife1016 For This Useful Post: | Matt@DamondMotorsports (02-06-2014) |
![]() | | #21 | ![]() |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Matt, I ordered my OCC a couple of weeks ago and have not had an update since you told me you would send me one of your new kits. Getting a little worried...
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray |
![]() | | #22 | ![]() |
![]() Join Date: Oct 2013 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 814
| Not Ranked : 0 score I have two unanswered emails as well Sent from the flux capacitor
__________________ 2013 Mazdaspeed 3 - GTX3076R EWG Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Same here^^^^
![]() | | #24 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | TORQUERULES (04-29-2014) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Thanks. PM sent.
![]() | | #26 | ![]() |
![]() Join Date: Jan 2014 Location: Tampa Florida Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
| Not Ranked : 0 score Putting my order in at the end of the week. Cant wait to get my occ! |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey guys, sorry for the lack of response. I just shot y'all PMs. I've been sick lately, and it's kept me from getting much of anything done. |
| The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | jtday (04-30-2014), justinsane87 (04-30-2014) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score No problem. PM sent back.
| The Following User Says Thank You to TORQUERULES For This Useful Post: | Matt@DamondMotorsports (05-01-2014) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score I got my OCC on Monday. Thanks!
![]() | | #30 | ![]() |
| Not Ranked : 0 score So I paid for my catch can on may 1st and haven't received it yet. This is beyond ridiculous. @Matt@DamondMotorsports; @- POD -; have you heard anything recently?
![]() | | #31 | ![]() |
![]() Join Date: Apr 2013 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
I sent an e-mail this morning asking if they shipped last week and if there is a tracking number. Hopefully I hear back. If I do I'll post any info I receive.
__________________ 2012 MS3 SOLD, living in the world of Right Wheel Drive now Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs | |
| The Following User Says Thank You to - POD - For This Useful Post: | justinsane87 (06-29-2014) |
![]() | | #32 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score Wait for the nut swingers.... |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | Code Monkey (06-29-2014) |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score If anyone hasn't heard from me, please email with the title "URGENT" and I will get back ASAP! @justinsane87; @- POD -; |
![]() | | #34 | ![]() |
| The Following User Says Thank You to - POD - For This Useful Post: | justinsane87 (07-01-2014) |
![]() | | #35 | ![]() |
![]() Join Date: Sep 2012 Location: Mountainside, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Waiting for delivery on this guy, hopefully it comes tonight! |
| The Following User Says Thank You to bfak66 For This Useful Post: | Matt@DamondMotorsports (12-31-2014) |
![]() | | #36 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score @Matt@DamondMotorsports; is just so dang busy with all of his parts coming out soon.
__________________ I am slow again. 2017 Lightning Blue SuperCab Raptor ordered 1/3/17. Built 2/3/17. Delivered 2/8/17. I modded it a little. |
| The Following User Says Thank You to Micha For This Useful Post: | Farhan@DM (01-02-2015) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Priority mail was a pain in the ass this week. The tracking went two days without updating anything and it came in a week. Got the goodies yesterday and will be installed tomorrow, weather permitting. I'm a little concerned getting the hose off the pcv valve as my car is almost ten years old and the valve has never been touched. Any extra tips to get it off easily? |
![]() | | #38 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Small hands and patience. Mine was a pain getting the pcv hose off a 3 year old car. Sent from my iPhone using sausage fingers
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | bfak66 (01-04-2015) |
![]() | | #39 | ![]() |
![]() Join Date: Dec 2013 Location: East Bridgewater, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score Detach hose end for IM and leave attached to pcv. Use barb fitting into stock hose coming off the pcv and attach to the supplied hose. Win.
__________________ BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass FREEKTUNED |
| The Following User Says Thank You to lolwrx For This Useful Post: | bfak66 (01-04-2015) |
![]() | | #40 | ![]() |
| Mazdaspeeds UNITE!!! | SpeedE | Car Detailing | 14 | 04-13-2009 06:28 AM |
