| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score Check out our site here for more info or to purchase the kit: https://damondmotorsports.com/collec...nt=21148830340 This first run it pretty limited, but we should have more to go in less than 2 weeks. |
| The Following 9 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | Castillo817 (06-30-2016), g00s3y (07-01-2016), Hush (06-30-2016), Mauro_Penguin (07-01-2016), Mazdazilla6 (06-30-2016), MS3Shadow (06-30-2016), NC-MS3Rob (06-30-2016), SofaKingAwesome (07-01-2016), wes3id (06-30-2016) |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score I call dibbs on one from first batch for speed6!!
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
| i'll get this once TMIC is compatible
![]() Join Date: Nov 2015 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
__________________ AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip "The mind is like a parachute, it only works when open" |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I'm sure it's possible to run with a TMIC, but given the position of the ST's TB, it would take a long and pretty convoluted (read 180º) piece of hard pipe or silicone to meet up with the TB from the TMIC. While I'd like to run the ST mani as well, I think that if I go that route, it's going to mean switching to a FMIC to make life a little more straightforward. That said, I'm thinking about FMIC pipe routing for a vertical-flow intercooler, something like this: Given the location of the TB, it might work pretty well.
__________________ AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip "The mind is like a parachute, it only works when open" | ||
| The Following User Says Thank You to NC-MS3Rob For This Useful Post: | Vansquish (07-01-2016) |
You are correct sir. I haven't had my coffee yet.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to NC-MS3Rob For This Useful Post: | Farhan@DM (07-01-2016) |
| Not Ranked : 0 score Finished product looks fantastic guys! Another great part from DM! Now for that FMM
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Y'all need to invest in some front mounts.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Vansquish (07-01-2016) |
![]() Join Date: Jan 2014 Location: San Diego, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score In for working with my tmic. New manifolds, retune and I'm done on stock block setup.
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score waiting for genone port injection
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: Dec 2009 Location: Temecula
| Not Ranked : 0 score I am in if the TMIC can work as well. the 100 degree heat in SoCal means I wont be blocking my radiator anytime soon. But props go out to Matt for thinking outside the box and giving us more options for the platform. |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score So OEM gasket is used to seal the adapter flange to the head I assume. Or is there an o-ring channel grove where ST IM o-rings are used? Just looked at the machining in the 3rd pic. Assuming that OEM gasket is used, are people cutting centers of gasket out where it would sit in front of the split? Awesome product. I want one but cant justify spending $300 now, but I already have an ST mani so hopefully some day will get one. I assume I can figure out cold pipe routing and hopefully fitting Synapse and routing recerc tube wont be too hard.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
| Display Modes | |
| Damond Motorsports Mazdaspeed ST Manifold Adapter Kit | Atomic41 | Mazdaspeed3/6 General Discussion | 9 | 06-20-2016 10:39 AM |
| Mazdaspeed 6 FMIC Kits | CorkSport | CorkSport | 45 | 03-18-2016 07:23 PM |
| 2010 Mazdaspeed 3 Hub Adapter | Als996 | Mazdaspeed3/6 General Discussion | 2 | 01-10-2014 06:11 AM |
