Like Tree9Likes
 Old 02-14-2015, 12:55 PM   #81
Name is longer than yours
Posts: 209   (View Stats)
Originally Posted by Nel Mazdaspeed View Post
@Matt@DamondMotorsports; @Farhan@DM;
Is the installation on the V1 on the GenOne you have on your site the same for the VTA kit?
Am I routing the hoses the same way as a sealed can install and bracket location is the same?
I'm looking at the pic in the instructions and there doesn't look like there's room for the filter on top. plz correct me if I'm wrong Thanks in advance.
Yes, all that is pretty much the same. The VTA kit should've came with an angled bracket, as shown here:
The angled bracket is used to move the OCC more inward in the engine bay to allow the filter atop the OCC to clear the frame rail.
If you got a straight bracket instead, LMK so I can get you the bracket pictured above ASAP.
 Old 02-20-2015, 11:46 AM   #82
Nel Mazdaspeed's Avatar
Posts: 407   (View Stats)
Ok so I have a question... should I be seeing pressure come out of the catch can if I open the drain valve while the car is running? Because I heard a psshh...
Currently the IM w/the check valve is connected to the top port and the pcv is on the bottom port.
 Old 02-20-2015, 05:34 PM   #83
England15j's Avatar
Posts: 1,910   (View Stats)
You should have vacuum on the can/engine at idle not pressure
Nel Mazdaspeed likes this.
The Following User Says Thank You to England15j For This Useful Post:
Nel Mazdaspeed (02-20-2015)
 Old 02-20-2015, 05:37 PM   #84
Yeah I think it was vaccum.. Just heard a surge of air. .. Want sure if that was normal. . Thx
 Old 04-26-2015, 08:13 AM   #85
AccuTec's Avatar
Posts: 210   (View Stats)
AccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond reputeAccuTec has a reputation beyond repute
Just placed an order for a V1 and V2 OCC with a VTA Kit for the V2. Ordering a PERM Plate as well to reconfigure the entire PCV system as my stock PVC Valve is hosed.
Resurrection of an old arse thread, complete.
'07 MS 6 GT Black/Black
- BNR S4 Turbo
- HTP 3.5" Intake System
- CorkSport Catless Turbo Back Exhaust
- Cobb AP V3 Freektuned by Justin
- Auto Tech HPFP Internals
- Oil Restrictor Bolt (Damond)
- Vented and Sealed OCC (Damond)
- PERM Dual PCV Plate
- TurboSmart BPV
- Denso ITV22 Plugs
- SPEC Stage 3+ Clutch Kit w/Fidanza Flywheel
- EGR Delete Kit
- Bosch 3 Bar TMap Map Sensor with IAT
- JBR 3-Port Electronic Boost Control Solenoid
- CP-E DeltaCore Top Mount Intercooler
- JBR Trilogy Motor Mount Package 80A
AccuTec is offline   Reply With Quote
 Old 08-10-2015, 07:24 PM   #86
macdiesel's Avatar
Posts: 825   (View Stats)
@Matt@DamondMotorsports; I was thinking about adding another occ for the valve cover and considered mounting between my small battery tray and the bulkhead. I noticed the focus ST relocation bracket and wondered if it may assist in mounting in that location unless you have other ideas on mounting an occ for the valve breather.
Damond Motorsports OCC V1 review Justus Damond Motorsports 5 10-15-2013 07:02 PM
Welcome Damond Motorsports Haltech Damond Motorsports 46 08-25-2013 09:56 AM
Page generated in 0.27549 seconds with 25 queries
