| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
(Thread Starter) | Not Ranked : 0 score So I've been around here for a little while, gone through two gen wons, and plenty of motor mounts too. Ive had TRZ TMM, CPE Stage 1 and Stage 2 RMM as well as PMM, JBR 88 RMM, Sure RMM, and shit probably some others that I have forgotten about too. But when I saw Damond release his RMM design last year, I was intrigued. Decided to pick one up and swap it out for my CPE stage 2. I was thoroughly impressed with how it held the engine more securely (in my opinion) and actually had less vibes. I had ordered the PMM along with the RMM, so a couple days after installing the RMM, on went the PMM. Immediately I could hear lots of cool timing chain noises, along with some vibes from my passenger mirror when at very low rpms. No big deal though, factory PMM is a piece of shit and I have too much invested in my car for the motor to smack the highway at 120 mph+. The noise and some of the vibes subsided after about 1000 miles or so. I did still have some interior panel vibes when I had the windows up and A/C on, which was usually only when I had the ole lady in the car after she had just fixed her hair, but whatever I would just turn up the radio. So then came the TMM release, I ordered one within three minutes of getting the email from Damond that they were available for purchase, and received it yesterday. Like a fat kid on Halloween I rushed home after work to install it. Matt hadn't put up any install instructions on the site yet so I kind of had to guess on the orientation of the bushing, because one side of the bushing carrier protrudes a little more than the other, but I think I got it right because it went together with no issue. The difference that these mounts made was unbelievable. I was expecting a slight decrease in motor movement, but what I got was a motor that doesn't move at all, and the shifts are fucking unreal now. I had to relearn my clutch action because now I can actually feel the clutch engagement so much better, and the clutch engagement is also consistent every time now instead of varying depending on gear and engine load. The addition of the TMM was the icing on the cake to me, it's like driving a totally different car now, and there was only the slightest increase in vibes over just having the RMM and PMM, which will probably decrease over time like it did with the others. If you want to protect your engine and trans from catastrophic stock mount failure (which does happen just do some searching) without sacrificing a ton of NVH, then do yourself and your car a favor and order these mofos ASAP. @Matt@DamondMotorsports; and @Farhan@DM; keep up the excellent work and I will keep buying it
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s Last edited by Addikted To Boost; 09-01-2015 at 11:25 AM. Reason: added pictars |
| The Following 10 Users Say Thank You to Addikted To Boost For This Useful Post: | amoosenamedhank (09-03-2015), Atticaz (09-01-2015), jax ms3gt (09-01-2015), macdiesel (09-03-2015), Matt@DamondMotorsports (09-01-2015), Mauro_Penguin (09-01-2015), Micha (11-26-2015), MS3Shadow (09-01-2015), SpeedRebirth (09-01-2015), WetzMS3 (09-01-2015) |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
| Not Ranked : 0 score My CP-E rear bushing is shit again. Warranty will fix it, but I have been considering just getting a Damond rear... Much more likely after your review, and might have to really just get all three!
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
| The Following User Says Thank You to jax ms3gt For This Useful Post: | Addikted To Boost (09-01-2015) |
(Thread Starter) | Not Ranked : 0 score Can't go wrong man, added pics
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
| RPM store has a 10% off sale including all three DM mounts.
| The Following 4 Users Say Thank You to MS3Shadow For This Useful Post: | Addikted To Boost (09-01-2015), Funktionull (02-01-2016), jax ms3gt (09-01-2015), macdiesel (09-08-2015) |
(Thread Starter) | Not Ranked : 0 score Forgot that I actually bought the PMM and RMM together, just installed them a few days apart. Edited OP to clarify some.
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
| The Following 8 Users Say Thank You to WetzMS3 For This Useful Post: | Addikted To Boost (09-01-2015), Farhan@DM (09-01-2015), kolosok17 (09-01-2015), macdiesel (09-08-2015), Matt@DamondMotorsports (09-01-2015), Micha (11-26-2015), monkey.bones.007 (09-01-2015), nindoja (09-01-2015) |
![]() Join Date: Oct 2012 Location: Summit Hill, PA
| Not Ranked : 0 score I will be ordering the side mounts in about 5 minutes!! And with RPM's sale right now they are only 440 bucks for both!
__________________ Adapted Performance - (Gold engine covers and Shift hammer waiting for install) Blox - Gold type R shift knob Cobb - AP V3 Corksport - HPFP, 3.5 Bar MAP, TMIC, 3.5 inch intake, Battry box, Boost tubes, Recirc hose (Injector seals waiting for install) Cp-e - Catted DP, Stage 2 RMM Damond - PMM, TMM, (OCC and Full EGR delete waiting for install) DDM - High, Low, Fog 6k hids Grimmspeed - (EBCS waiting for install) JBR - RSB, Solid shifter bushings, Mud flaps (Crash bar and FMIC piping waiting for install) OBX - Catback with res delete Turbosmart - 50/50 BOV Treadstone - TR8 |
(Thread Starter) | Not Ranked : 0 score based on @King Scumbag;s review in the main TMM thread, I am thinking I might have installed the bushing backwards...fail Edit, according to Matt via pm I actually installed it correctly...
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s Last edited by Addikted To Boost; 09-01-2015 at 04:12 PM. |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
__________________ | |
| The Following User Says Thank You to Farhan@DM For This Useful Post: | Addikted To Boost (09-01-2015) |
Groans: 438
I'll be putting up a little review also in a week or so, but so far, the 3 of these feel amazing.
__________________ All good things must come to an end... | |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow | |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score If someone can tell the difference between JBR trilogy and this combo from DM ... in term of vibes and rattles. is it 25% less than the JBR Trilogy or maybe 15% harder (vibes and rattle) than the OEM ... something to give a good idea in term of vibes and rattle ... I already try the JBR Trilogy and it's way to much for me (the rear miror barely usebale and during winter here -30 Celcius (big rattle and vibes) but I really like the change they made (better shifting and no loss of power with the slop of the engine) but right now I just have the JBR RMM 88 duro, OEM TMM, OEM PMM. The car still be comfortable about vibes and rattle, I think I can have space for increase but I don't want a BIG difference. Thanks for your help about this
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 |
| The Following 4 Users Say Thank You to WetzMS3 For This Useful Post: | macdiesel (09-03-2015), Matt@DamondMotorsports (09-01-2015), monkey.bones.007 (09-01-2015), Nliiitend1 (09-01-2015) |
Groans: 171
| Not Ranked : 0 score How are these things when engine braking or coasting? I'm really on the edge about replacing my current trilogy. Vibes and mirrors are fine but the noise is annoying. When engine braking the whole car feels like a rollercoaster ride that Jim Bob at the carnival put together with only stripped nuts, a hammer, and a crescent wrench.
Sent from my SM-G925V using Tapatalk
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s | |
| The Following 3 Users Say Thank You to Addikted To Boost For This Useful Post: |
| Not Ranked : 0 score From everything I have read so far I would say it cant be much at all. I would say 10-15% increase over stock with upgraded RMM? Right now I have the Cp-e stage 2 rmm and the only time I notice any vibes at all is when putting strain on the motor at low speeds and a high gear other than that I would compare it mostly to stock now after 15k miles. I just ordered the PMM and TMM today so I can back that up a lot better once they are installed.
| Not Ranked : 0 score After break in period ... what is your feeling about these mounts ... Someone put almost 1000-1500 km on it ... to know if the NVH and rattle settle down and these mounts became more silent ...
(Thread Starter) | Not Ranked : 0 score They are great, but you're never going to have a silent car with aftermarket mounts. If you want silent and sloppy then stick with the stock mounts. Sent from my SM-G925V using Tapatalk
![]() | | #19 | ![]() |
| From what i heard, they are pretty quiet for aftermarket mounts to begin with. They are going to fail eventually, might as do them right.
![]() | | #20 | ![]() |
| Not Ranked : 0 score My question is just if they will settle down after break in period and if yes the feedback from a user that already drive 1000 to 1500 km with them ...
![]() | | #21 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Yes they will. Many people have stated this; it's a normal thing with aftermarket mounts due to the bushings.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | WetzMS3 (09-08-2015) |
![]() | | #22 | ![]() |
If you've read the reviews I directed you towards earlier in this thread, read this and other reviews as well, but are still concerned about vibrations, I am guessing aftermarket side mounts are simply not for you. Any aftermarket side mount has increased vibrations. According to most reviews, the DM set has less than others, but still increases vibrations over OEM. In all reality, unless you have a lot of power, and race in some form often, OEM side mounts hold up just fine. Shifting will always be more sloppy than it would with aftermarket mounts, but seriously, if all of the opinions and reviews out there do not give you enough information to calm your concerns about vibration, vibration simply is not for you. It's ok.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Micha (11-26-2015) |
![]() | | #23 | ![]() |
I think they're just unreliable OEM parts. 2¢
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score I, like @Addikted To Boost; , had the Damond RMM and PMM prior to purchasing the TMM. Personally, this is a set of mounts best enjoyed together. Felt like I had more vibes before adding the TMM. Maybe the oem TMM was on its way out. I ussually put mounts thru the wife test. She can tell right away when installed but she didn't even notice having all three in place. And I have a bsd as well. I'll take some vibes over wheel hop any day. Haven't experienced wheel hop at all since installing all 3. Car feels well planted and much more engaging to drive.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following 7 Users Say Thank You to macdiesel For This Useful Post: | Farhan@DM (09-08-2015), JgamB (09-08-2015), Matt@DamondMotorsports (09-09-2015), Mauro_Penguin (09-09-2015), MD1032 (09-12-2015), Micha (11-26-2015), MS3Shadow (09-08-2015) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score @Addikted To Boost; Update man about your trilogy DM ... how is it now after many miles on it ... do you like it as a DD ... NVH is it fine !?!??! With the colder climate ... do you feel more vibes and rattle ???
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 Last edited by Atomic41; 11-27-2015 at 06:31 AM. |
| Damond Motorsports PMM Review | 2.0t03speed | Damond Motorsports | 90 | 03-31-2016 10:29 PM |
| 88 Duro Trilogy review | brandon3212 | JAMES BARONE RACING | 3 | 11-01-2014 08:41 PM |
| 88/88/80 Trilogy Review | Gr8Speed | JAMES BARONE RACING | 24 | 03-29-2014 10:30 PM |
