Like Tree46Likes
 Old 09-25-2014, 08:21 AM   #1
BrownBear
Farhan@DM's Avatar
Posts: 241   (View Stats)
Default Damond Motorsports TB Meth Injection spacer
Need a nice clean setup to inject additional fluid into your air stream? Don't want to tap pipes on your car? Look no further.
The Damond Motorsports Throttle Body Spacer has 6 1/8" NPT ports to hook up whatever you want to inject right before the intake manifold. It sandwiches between your throttle body and intake manifold and allows you to thread in multiple nozzles, lines, or injectors for as much as 800 hp of fuel! The spacer comes with all the hardware you need for an easy install, including bolts, washers, and all the plugs you'll need.
Pricing:
$69 no gaskets
$79 1 OEM TB gasket
$94 2 OEM TB gaskets
USPS Priority shipping is included in the USA 48.
http://damondmotorsports.com/product...-ports-pre-buy
This spacer uses a stock throttle body gasket on each side, so you need 2 total. Please select the option you need for additional gaskets. Supplied gaskets will be OEM gaskets.
Will work with stock TMIC on Mazdaspeed 3 2007-2013 and Mazdaspeed 6 2007. You will need to trim the cold side boost tube 16mm.
Will NOT work with Mazdaspeed6 stock cold pipe.
Injectors and/or nozzles are not included.
Shown with Coolingmist injection nozzles (not included).
Last edited by Matt@DamondMotorsports; 10-28-2014 at 03:34 PM. Reason: add pictarz!
The Following 51 Users Say Thank You to Farhan@DM For This Useful Post:
Agent_Orange (09-25-2014), Alpha (09-25-2014), Bob-o (09-25-2014), breakfstincluded (09-25-2014), Cheapspeed (09-27-2014), Cyclops (09-25-2014), dereeek (09-25-2014), Easter Bunny (09-25-2014), franz (09-25-2014), fredricktsang (09-28-2014), Funkster777 (10-16-2014), gdawg25 (09-25-2014), Gr8Speed (09-25-2014), Hammology (09-25-2014), Hargarbl (09-25-2014), helmetface (09-27-2014), jack_hammer (09-26-2014), JgamB (09-26-2014), joeyspeed3 (09-25-2014), Justin@Freektune (09-25-2014), Kyle Undefined (10-09-2014), LatinKraze (09-25-2014), magicka (09-25-2014), Matt@DamondMotorsports (09-25-2014), Mauro_Penguin (09-26-2014), memin (09-28-2014), Micha (09-25-2014), Mike@Stratified (09-25-2014), Mistersix (10-18-2014), mituc (10-14-2014), ms6mil (09-25-2014), naoandlater (09-25-2014), PapaSmurf (09-25-2014), Poohster (09-27-2014), rfinkle2 (09-25-2014), robertof (09-30-2014), Sergeant_M (10-09-2014), shadesofgray19 (09-25-2014), silvapain (09-28-2014), speed3 britz (09-26-2014), SpeedRebirth (09-25-2014), Swinger13 (09-27-2014), taf0422 (09-25-2014), The Nut (10-09-2014), TiGraySpeed6 (09-25-2014), Vader (09-25-2014), VegasChef (12-07-2014), Voltwings (09-25-2014), WetzMS3 (09-25-2014), YABBAMZR (10-18-2014), [R]usty (09-25-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/damond-motorsports-tb-meth-injection-spacer-177745/
Meth injection throttle body spacers This thread Pingback 09-25-2014 03:23 PM
Damond Motorsports MS3 PMM Matt@DamondMotorsports Damond Motorsports 141 10-16-2019 05:40 AM
Introducing the all new Damond Motorsports OCC Matt@DamondMotorsports Damond Motorsports 85 08-10-2015 07:24 PM
Damond Motorsports OCC V1 review Justus Damond Motorsports 5 10-15-2013 07:02 PM
Welcome Damond Motorsports Haltech Damond Motorsports 46 08-25-2013 09:56 AM
Page generated in 0.66386 seconds with 44 queries
